| SAB Heli Division 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support |
For those with new OWB, does it autorotate noticable better? I'm having a hard time with my autorotations on my Goblin. I'm sure it's 85% me, but anything helps
Nano CPX, 130x, Trex250, 450Pro, 550 & 600EFL Pro. SAB Goblin 500 & 700 - Lynx Team Pilot - |
For sure it's better. I noticed an improvement. It seems on par with my 700e now.
Goblin 700, Goblin 500, Synergy E5-600, Fusion50, Rush7 HeliDirect, Team iKon, GrandRC |
#3 | |
#4 |
First time i autoed on the first batch goblin with the brass bushing and the stock 175G blades i almost crashed! LOL
Will try again now mine has new auto gear! Still 175g blades are a bit light in my book, they should have made them 185-195g |
#5 | |
#6 |
Yes, heavier blades are better for auto's. They store more energy.
For example : My gasser can hang for 3-4 secs. easy, after flaring, with 230 gr blades. With 175-180 gr. (can't remember exactly), it's pretty much just enough to land. ![]() It's a little heavier than the Goblin, at 6,5 kg. Do you run symm. pitch in th. hold? Setting pitch under mid-stick from 0-6 degrees will help in that it will be easier to find the sweet spot. Pitch will be less sensitive under mid-stick.
minicopter Diabolo, Henseleit TDR, MA Spectra-G, Raptor 50T Futaba 2.4 GHz |
#7 |
Funny how so many ppl argued with me a couple months ago when I said the goblin lacked in the autorotation department. I guess it takes a new upgrade release for some to understand the obvious. (2+2=4)
Futaba -TP - Xera - Kontronik - Edge - Insane Canopy |
#8 | |
#9 |
OTS I never mentioned you my friend. But as you know many did disagree with us. I haven't had the chance to order a new owb hopefully when they get back in stock i can get one. Seems promising.
#10 |
The Capi - HF Support
Who autos a heli !!?!?
SAB Heli Canada / RotorQuest/Compass Team KBDD Spreading capibara awareness since 2006 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#11 | |
I think the new steel pinion helped as well. The mesh is much smoother which matters in the goblin since the owb is in the first stage.
#12 | |
I haven't gotten the pinion either. I guess i will end up with that also. Thanks
