Like Tree1Likes
Old 01-03-2014, 10:37 AM   #121 (permalink)
Originally Posted by mahbouni View Post
Well I just saw that eRCMarket was showing 1 Red/Yellow kit with blades in stock. Not long ago they sent me an email with a 14% discount coupon. Guess what I just did?
Nice!
Wayne
Logo 480 / Logo 600sx / Logo 690 / Logo 700 / Vbar Control
Mentalic is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 02:19 AM   #122 (permalink)
Hi Dave!
I just have ordered your JR ELS01 and ELG01 servo combo
Is it fit perfectly or do i have to make any modification?
Can i use with the stockYGE 90LV Power BEC?
Thx,
Laci
Mikado Logo 480 - Future
Mikado Logo 600SX - Silver Line Present
Fusion 50 - CGY750 Past
Trader is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 03:04 PM   #123 (permalink)
The fit with the pem nuts in the carbon frames is not exact with those servos, so Kyle just uses a washer on the servo screws without the grommets installed...essentially hard mounting the servos to the frames...which is nothing new, as Kyle has been hard mounting all his servos in all his helis for some years now. No issues.
Many guys are reluctant to hard mount servos in their helis, and I'm one of those guys (hold over from my airplane and nitro heli days). I still always use grommets if I can...makes sense to me, and certainly can't hurt.
But I can say from experience watching and maintaining Kyle's helis over the years, that hard mounting doesn't seem to negatively effect things...at least on electric helis.
Yes, you can us the YGE's BEC for power, as Kyle has his 480 set-up this way.
Hope this helps.
(-: Dave
dahld is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 03:32 PM   #124 (permalink)
Hi Dave,
is ther no way to fit them with the pem nuts in the frames? I´ve just ordered them and i think they will arrive tomorrow... Oh oh, i hope it wasn´t a bad buy.
Dan0111 is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 05:33 PM   #125 (permalink)
Originally Posted by Dan0111 View Post
Hi Dave,
not with the grommets for sure, they are a tad short. I am building one and discovered that. I like the idea of the washers that Dave mentioned, currently i have the grommets set half way to the outside but seems to hold the servo tight, nonetheless it is making me nervous if it will hold with 3D moves, I will try the hard mounting.
_____________
abanihani is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 06:14 PM   #126 (permalink)
Like abanihani said. No need to try and change the pem nut positions. Just remove the servo grommets, use a washer on the screw to allow maximum contact with the servo mounting lug, tighten down, and move-on.
All the servos in the world are different from different manufacturers, so there is no way one mounting position will work for all servos... but if hard mounted, all will fit no problem.
(-: Dave
Old 01-08-2014, 11:16 AM   #127 (permalink)
Tom Fourneau - Mikado logo 480xx (4 min 37 sec)
Sponsored by
Scorpion System motors
RC Take Off
Haiyin
tommeke is offline        Reply With Quote Quick reply to this message
Old 01-09-2014, 04:04 PM   #128 (permalink)
UPS delivered my kit today. Build starts this weekend
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 01-10-2014, 05:54 PM   #129 (permalink)
My kit has been officially ordered.
It's a super combo I found at a local shop. Thanks for the tip Tommeke.
Hoping it will arrive on monday!
Goblin 700 Competition (sold) | Logo 480 xxtreme (sold)
Lynx Oxy 5 Neo I Lynx Oxy 2 Neo
Vbar Control I AccuRC
TimZ is offline        Reply With Quote Quick reply to this message
Old 01-13-2014, 02:40 PM   #130 (permalink)
JR servos(ELS01 & ELG01) have been arrived
I could't find any spec about Hz and CENTER-POSITION PULSE-LENGTH....
Do you know it
ID:	478930   Click image for larger version
ID:	478931   Click image for larger version
ID:	478932   Click image for larger version
Old 01-19-2014, 02:40 AM   #131 (permalink)
I bought myself a Logo 480 XXtreme
The setup Will be:
YGE 120lv
Scorpion 3226-1400kv
Swash servos: JR DS3421HV's
Tailservo: JR MPH83Ghv
FBL unit: Fullsize Vbar Silverline
Futaba 7008sb
Lipos: start with my old gens ace 6s 3300mahs
Verstuurd vanaf mijn C6903 met Tapatalk
tf-zuid is offline        Reply With Quote Quick reply to this message
Old 01-24-2014, 07:14 PM   #132 (permalink)
That's what I was thinking as well, stretch it and fly with SAB 500mm blades.
Originally Posted by Trader View Post
Do you think these...:
MIK4070 Drive belt 608XL
MIK4071 Tailboom 600mm LOGO 500
MIK4095 Carbon control rod for tail LOGO 500
One_eye is offline        Reply With Quote Quick reply to this message
Old 01-24-2014, 07:27 PM   #133 (permalink)
Hi guys,
Does the throttle below mean the throttle curve percentage? I am using a Futaba 14SG. When I program my jive, I leave my atv at default value and go thru the setup, does this mean ATV not adjusted?
Throttle curve 100% = 80% in mr mel calculator
Or
Throttle curve 80% = 80% in mr mel calculator
Anything more that 80% will not do anything?
TIA
Here's two calculations from Mr Mel. Both are 6s 1100KV 18T pinion 153T main gear and Jive mode 4 governor. The first one has no ATV adjustment. That means the throttle ATV are at +-100% in the Tx.
Throttle 55%: 2357
Throttle 60%: 2480
Throttle 63%: 2553
Throttle 67%: 2651
Throttle 70%: 2725
Throttle 73%: 2798
Throttle 76%: 2872
Throttle 80%: 2970
The second one has ATV adjustment. The throttle endpoints are calibrated to the Jive so that the ESC arms at bottom stick and the LED on the Jive comes on at full stick. Again this is not recommended by Kontronik.
Throttle 60%: 2382
Throttle 65%: 2455
Throttle 70%: 2529
Throttle 75%: 2602
Throttle 80%: 2676
Throttle 85%: 2749
Throttle 90%: 2823
Throttle 95%: 2896
As you can see with no ATV adjustment, 80% yields even higher RPM than 95% with ATV adjustment. From Mr Mel's calculator it is clear that 80% with no ATV adjustment is close to if not past 100% PWM.
Old 01-25-2014, 03:50 AM   #134 (permalink)
The Kontroniks governor works in a different way to most other ESCs. It doesn't actually try to keep the motor at a set rpm but turning at an output of a percentage of PWM. The motor speed isn't directly governed. The formula Kontronik use to convert throttle percentage to PWM is;
PWM=50+(TC/2) where TC = throttle curve setting.
The Jive governer needs ideally 20% PWM of headroom so the TC needs to be set at a value that gives 80 out of the above formula - 50+(60/2)=80 - so the TC needs to be at 60% flat for the Jive governor to do its thing properly.
So, with a Jive in Mode 4 or 11. Keep your throttle at 0 to 100 end points set Idle 1 as a flat 60% TC then use Mr. Mel's head speed calculator to find which pinion will get you closest to your desired head speed then acquire/use that pinion size in the model. With Jives it is best to keep the TC static and adjust the pinion.
If you intend to use idle 1 and 2 then set idle 2 tc at a flat 70% and pinion for that speed (not ideal settings but the governor will still have some head room to play with) then lower the TC in idle 1 to get the head speed you want.
On the Internet you can be anything you want.
It's strange that so many people choose to be stupid.
Jockpants is offline        Reply With Quote Quick reply to this message
Old 01-25-2014, 06:30 AM   #135 (permalink)
Based on your formula 50+TC@60/2=80%
My head speed will be governed at 2970 as per mr Mel calculator posted earlier?
Or 80% of 2970?
TiA
Old 01-25-2014, 11:00 AM   #136 (permalink)
Neither. Set TC at 60% and Governor will be working for 80% PWM which will equal a governed head speed of approx 2480 (60% TC on the calc listing above)
So for a further example, set the TC at 70% for a governed PWM of 85% which will equal a governed head speed of approx 2725 (70% TC on the calc listing above).
You don't want to take the TC above 70% in practice. What will happen is when the ESC sees a increase in load it will start increasing the PWM to hold head speed but if the PWM hits 100% the ESC will keep it at 100% PWM for the remainder of the flight.
Old 01-25-2014, 11:10 AM   #137 (permalink)
just remember those values are with a pyro and different gearing.
Stock 4015-1070 with 23T gives the following values
Throttle 55%: 2115
Throttle 60%: 2224
Throttle 63%: 2290
Throttle 67%: 2378
Throttle 70%: 2444
Throttle 73%: 2510
Throttle 76%: 2576
Throttle 80%: 2664
So that is around 2200~2300rpm with sufficient headroom.
GAUI X5 with Eznov Neuron and T10J
DannyvG is offline        Reply With Quote Quick reply to this message
Old 01-25-2014, 07:30 PM   #138 (permalink)
Thanks guys, I have been running it at 80% on my TC which based on the formula it will be at 90% PWM but I dont feel the headspeed extremely high and the motor and esc is only warm. My country outside temperature is about 30 degC now and I fly mild 3D. I did turn on KSA mode as well.
Old 01-26-2014, 04:36 AM   #139 (permalink)
Maidened mine yesterday. 1st battery was without the canopy, landing several times to increase Vbar gains. 2nd battery with the canopy on I went into full 3D. We tached the head speed at 2550rpm with a WR Chinnook. With a Revolectrix 30C 6s 3900mAh pack (577g) I flew for 4mins 30secs and I had 30% left at the end. The headspeed was enough to do everything I asked of it but I feel a little bit more would be more exciting for me. This is with a Pyro 600-11 and 18T mod .7 pinion. I ordered both 18T and 19T pinions but unfortunatelyby mistake I ordered ones with 5mm ID instead of 6mm ID. My friend drilled out the 18T pinion for me but I think it's slightly off center as I can't get a perfect mesh. I'm thinking rather than ask him to drill the 19T pinion for me I'm going to switch to mod 1 gears and use a 13T pinion. That should give me the slightly higher head speed I want.
Overall i think the heli flies awesome and it looks great in the air. I felt very confident with it on the 2nd battery. I'm going to be flying this heli a lot this year.
Old 01-26-2014, 05:04 AM   #140 (permalink)
Is there any one Who use the JR DS3421HV's? What modification did you guys make to fit this?
