Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
04-16-2009, 05:57 PM | #181 (permalink) |
Ive got a blade 400 with the hitec 5000 gyro combo, it holds really well but I'm also unable to get the tail to wag no matter how high i set the gain. I'm also using the largest servo horn on the furtherest hole.
TEAM REDGUM RC - Compass 7HV NITRO- 7HV ULT - 6HV ULT - Warp 360 |
04-21-2009, 01:27 AM | #182 (permalink) |
I can't go any further out on the servo horn either. The furion manual recommends 8mm on the tail servo horn, mine is already at 12mm and with the gain at 100% there is no tail wag!
04-21-2009, 02:27 AM | #183 (permalink) |
I am also at 12 mm, but the helli is locked in really well. Ive set the gain in the tx on 75, i am not going to worrie about getting the tail to wag. If the tail was drifting that would be a different story.
04-21-2009, 03:58 PM | #184 (permalink) |
I hear you mine is locked in as well but if I punch the collective the tail will sometimes blow out. Every gyro I have ever had you increase the gain until it wags and then you back off a little. The fact that it won't wag even at 100% makes me feel that the gyro is not locking as well as it could hence the blow outs.
04-21-2009, 04:06 PM | #185 (permalink) |
I am not having any problems with blow outs, but i was just viewing Finless video on the test flight of the beam and he had his actual gain set at about 50 which is 85 in the TX, very high but the Helli seemed locked in. Ive also found with the hitec if its not set up mechanically 100% you will have issues.
04-23-2009, 01:01 AM | #186 (permalink) |
Hey guys,
I recently got the HG5000 combo as well.... going to watch the videos & set it up tonight. I was wondering however - could I use this gyro on bigger sized heli's? say 500 or 550 Also for now I am using a hi-tech optic sport 6, guessing since its hi-tech gyro it should be all sweet? |
04-23-2009, 02:00 AM | #187 (permalink) | |
04-23-2009, 08:07 AM | #188 (permalink) |
Ah thanks for that
I am watching the videos now but I have run in to a problem with my radio that I have had ever since I got it. I can't work out how to change from "rate" mode to HH mode for the gyro. In its gyro menu all you get is a percentage to change & apart from different fly modes, you can't assign it to a channel. Any ideas or help would be unreal EDIT: Found the answer! "if you are using a 401 gyro and have it's control cable plugged into channel 5 and you have a value higher than 50% it will turn the gyro on in HH mode. I use 74% for mine in a Swift. A value lower than 50% will turn it off." & "On the Optic, you do not need to set the endpoints. The GYRO menu will have four toggles. These are flashing at the bottom of the GYRO menu. When you flip between NORM, ST1, ST2, and HOLD, you'll see the separate settings for the GYRO. From 1~49 is used to set RATE mode. The closer to "1", the higher the RATE gain. From 51~99 is used to set HEAD HOLD mode. The closer to 99, the higher the HEAD HOLD gain. You'll need to program the same gain numbers for all separate flight modes. Make sure you flip every switch just to be sure you don't miss something." Serves me right for not using the search function! |
04-23-2009, 12:36 PM | #189 (permalink) |
RaZzOR, keep in mind as you start working with this gyro that most folks settle on pretty high gain settings as compared to some other gyros.
07-24-2009, 11:50 PM | #190 (permalink) |
Servo speed tied to gear channel, nomal...?
I was playing with my gain (gear channel) and noticed that it directly controlled the servo speed for my 5083 servo (combo package).
This is a new combo that I got, didn't noticed this on a previous combo? Is this normal? |
10-28-2009, 10:45 AM | #191 (permalink) |
Hello Bob,
I wish to know which Gyro is best the Hitec HG5000 or the Futaba GY401, I want to know if I sale my servo Hitec5083MG or my Gyro GY401 to be able to mach a good pair by mistake I bought separetly and know I realize I can use it together!! |
10-28-2009, 12:08 PM | #192 (permalink) |
Member
Having experienced both, my opinion is that the Futaba GY401 is the better of the two.
10-29-2009, 05:53 PM | #193 (permalink) | |
I am curios
I am very curious and always want to have a better a clear understanding, can you tell me why you said this? whihc features make it better, so far I understand is easier to setup, but it appear that you and other believe HG-5000 is very solid, is this good or extremelly good? You may notice so far I am newbie to Heli´s, I appreciatte your coaching!. Also I am confuse because I see your video on HG-5000 and it appear to be a state of art gadget. I am wrong? |
10-29-2009, 07:01 PM | #194 (permalink) |
Team Taco VP
I did not like the piro rate on the hitech gyro. At max rudder of 150/150 it still had a slow piro rate. AT LEAST on the Beam Heli and a Trex.
Hold wise they are pretty much the same. Unless your into 3D with lots of fast piro's either is fine. Bob
"Don't Taco My Pack Dude!" NEW Video Link -> Safety Video #1 Video Link -> CAUTION using powerful tools! Video Link -> How to CRASH TWICE in one flight! Video Link -> Don't Taco! |
10-29-2009, 07:17 PM | #195 (permalink) | |
Member
The 401 on the other hand does not require a rate mode set-up. And once the delay is set properly so you don't get any bounce when you stop the tail, the 401 felt like it stopped and locked the tail a lot harder (better) than the 5000. It was very quick to set-up and tweak for great results. If I had to start over again and only had a choice of these two gyros, I would pick the GY401.
10-29-2009, 10:10 PM | #196 (permalink) |
Pretty Cool explanation and much more easier for a newbie to make a decision, thanks
12-12-2009, 09:50 AM | #197 (permalink) |
Which way should the hg5000 be facing when mounted on the heli?
E-Sky Hunter Co-axial. E-Sky BeltCp High Tech HG5000 Gyro & 5083Servo & all High Tech HS65hb servos.CopterX head & Tail. Trex 600 Nitro Limited Edition. - DX7. |
12-12-2009, 05:32 PM | #198 (permalink) |
The label has to be facing either up or down, with the mounting surface perpendicular to the mainshaft. Other than that, it doesn't make a difference which way it's oriented.
12-18-2009, 02:24 PM | #199 (permalink) |
Uncommanded piro / can't set end limits
I have recently purchase a second HG5000 (the first died in a rather spectacular crash). Using it on a e325 MiniTitan.
Anyway, twice now I have experienced an "uncommanded" piro (quite slow) in a clockwise direction. This has happened after the 3rd or 4th batteries, just as I'm coming in to land (head speed slow?). The first time resulted in a minor crash, the second I caught (just!). I have also been having lots of trouble getting the servo limits set correctly - I do the setup however they don't seem to stay set as the limits. This is odd because I had no difficulties in getting the first HG5000 set up (which worked brilliantly) Are these related? What could I do to ensure that the end limits are set (beyond what is in the manual / video)? Anyone experience this sort of slow piro? any advice appreciated, thanks |
12-19-2009, 12:19 PM | #200 (permalink) |
Team Taco VP
Some guys that have had weird problems like you describe do a Factory RESET on the unit. I forget where I read how to do this but there is a way to reset and thus recalibrate the gyro. Try a search. I think it is under Logictech 2100 gyro?
Bob
