Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Old 02-18-2017, 03:22 PM   #1 (permalink)
Default Newbie question....Flybarless vs Flybar
Just starting to learn to fly my my mCPx BL. I have been flying fixed pitched helis for a while now. When I started a while back, only the newest most expensive helis were flybarless. Now even the micro fixed pitch helis have gone flybarless.
Obviously flybarless have fewer parts and are Mechanically less complicated,,,, but it seems to me that the missing flybar has to be replaced by Something..... My guess is some kind of software control in the esc.
My question is: What do you experienced Heli people prefer? Does it even make a difference?
Redharris is offline        Reply With Quote Quick reply to this message
Old 02-18-2017, 04:05 PM   #2 (permalink)
Yes it's replaced by the digital flybar, AKA the fbl unit/controller. Mechanical setup is easier but the electronic setup is more involved.
Lucky for us most of the fbl controllers are very user friendly and have amazing tunability and all sorts of wonderful features that make a huge difference.
Bank limits/stability modes that make a cp fly like a fixed pitch, bailout that can save your butt by flipping a switch when you get into trouble. You can tune it to fly a lot like a flybarred heli or you can take advantage of the faster flip/roll rates a fbl heli is capable of. Logging, vibe analysis, all kinds of good stuff.
AR7200BX is a popular one to start with since it's quick and easy to setup without a PC, but there are many great units available.
Mini Protos 6s stretch/XK K110/Trex 450sport v2 fbl/Rochobby Nemesis NXT/RareBear funfighter620mm
~Problem Child~
learnedthehardway is offline        Reply With Quote Quick reply to this message
Old 02-18-2017, 05:01 PM   #3 (permalink)
Your going to love MCPX BL. It's the little helicopter that thinks it's a 450.
Don't be afraid to take it outdoors and let it fly.
Ron MCPX-BL (2 min 4 sec)
I learned on both fly bar and FBL. They have a little different feel. I'd suggest sticking with FBL if your buying new. Although there are plenty of fly bar 450's around used, and they can be had relatively inexpensive.
Ether way hope you enjoy the hobby.
Ron
Petrolia Ontario Canada.
Electric, MCPX-BL,450X, Trex 550E Nitro Hirobo SCEADU Evolution 50
Imzzaudae is offline        Reply With Quote Quick reply to this message
Old 02-18-2017, 05:46 PM   #4 (permalink)
The gyro now does cyclic and tail advance air surface computing to keep the unit stabilized, customize unit flying style, and tune the model. It's def the way to go...flybar kept me out of the hobby, now that I've pretty much gotten fbl down it makes flybar easier to digest.
The standard is now fbl but enthusiasts love both.
They both have their quarks.
Écureuil AS355n.50 600mm - Lynx 450xl ntm1700kv 350mm- KDS Chase 360mm Scorpion 1880kv SK720be/Ikon
Waxxingibbous is offline        Reply With Quote Quick reply to this message
Old 02-18-2017, 06:07 PM   #5 (permalink)
I agree that if $ are the key concern, get a flybarred Trex 450 or 500 next. If not, I'd get a flybarless in that size range, as it is less fussy mechanically to repair and will allow you to tune performance to your liking.
Logo 600 (VBar Neo), Gaui X5 FES (BD3SX), Warp 360 (MiniVbar), Trex 450 Pro FBL (Spirit Pro), OXY 3 stretch (Spirit), OMP M2 Explore, two 180CFX (one uSpirit), 130X, XK110, Nano CPX
PassinThru is offline        Reply With Quote Quick reply to this message
Old 02-19-2017, 08:10 PM   #6 (permalink)
Thanks for all the Info!
I had no Idea the FBL were SO programmable. What sort of process is necessary to program them? Do you hook em up to a computer and adjust parameters,,,,, or do you do it with your radio? Is every manufacturer different, or is it more of a Standard Procedure?
I'm guessing there must still be a fair amount of mechanical tinkering involved...
Old 02-20-2017, 05:30 AM   #7 (permalink)
They all use different interfaces to program. Some use a pc/smartphone interface, some use the transmitter, some use a combination of both. Best bet is just to pick one unit and learn it inside out.
As for what is involved in setting them up, they basically need calibrating to your head geometry, end points setting, agility setting and control gains tuning. The simple FBL unit in your mCPX doesn't need any setting up other than basic transmitter programming. Most units work pretty well on their default settings too, usually just need to tune the tail gyro gain after basic geometry setup. Then as your flying improves you can start to get into the other more detailed settings to suit your model and flying style.
Goblin 380 KSE, OXY 3, 180 CFX, 130 X, nQX, mCX2
DX8, BeastX, Heli-X, neXt
peteski is offline        Reply With Quote Quick reply to this message
