Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters
Synergy Model Helicopters Synergy Model Helicopters Support
Old 08-03-2014, 08:13 AM   #1 (permalink)
Default first synergy heli
hey guys, just ordered my first synergy heli. got an E5 on its way! super excited. my question to you is, has anyone flown an E5s on 6s? i plan on using my existing 5300mah glacier 6s packs with an edge 130 esc. not sure on motor yet. i would like to fly lower head speeds as i am still a novice in this hobby. i only fly sport with some loops and rolls as of yet. wasnt sure if stretching it was a good idea to make up for the heavy packs or if i should just leave it stock? more interested in longer flight times than all out performance. thanx.
Synergy E5
Gaui X3
Blade nano qx
JR x9303
bonin1 is offline        Reply With Quote Quick reply to this message
Old 08-03-2014, 08:42 AM   #2 (permalink)
I have a stretch kit on the way, that I plan on running on 6s. I have 2x 4400 packs and 2x 4500 pack I currently use and plan on using when I stretch it. I'm going to go with 626 mains though, and maybe bump up the tail to 106s. I have yet to order the blades though.
So to answer your question, yes, you can run a E5s on 6c. There are many others that have done this as well.
Grimmy is offline        Reply With Quote Quick reply to this message
Old 08-03-2014, 08:55 AM   #3 (permalink)
Awesome thanx
Synergy E5
Gaui X3
Blade nano qx
JR x9303
Old 08-03-2014, 09:04 AM   #4 (permalink)
Have fun with the new heli!
/#Team BK Servos//#Team Pulse/#Team AMain Hobbies// /Team Canomod//
Greg Jackson 2017 Team USA F3N https://www.youtube.com/channel/UCci..._R4nja0RYeXykg
GJacksonF3N is offline        Reply With Quote Quick reply to this message
Old 08-03-2014, 09:59 AM   #5 (permalink)
Yes lots of people fly it on 6S, better on Rails 556 but will also work on Rails 606 (if you stretch it). Motor for 6S 556mm blades should be 1100 KV. Have fun.
Team Rail blades,
Team Scorpion motors,
V-Team
ClubCRASH is offline        Reply With Quote Quick reply to this message
Old 08-03-2014, 10:35 AM   #6 (permalink)
Ok. Any recommendations on motor if I stretch it and run 6s? Again, I'm more interested in efficiency and flite time than raw power.
Synergy E5
Gaui X3
Blade nano qx
JR x9303
Old 08-03-2014, 10:40 AM   #7 (permalink)
I'm running the 4025-1100 Scorpion motor, as it is a very popular one for this model.
I suppose one of these day's I'll make myself a signature with my stuff in it so I remember it all.
Old 08-03-2014, 10:54 AM   #8 (permalink)
Speed up the tail for low headspeeds though. I am waiting on my e5s to show up aswell. I did order the 4.5:1 tail gears so I can lower my hs down.
B400(retired),Mini Titan V1(Retired),Radikal G20 (scrapped),Align T-Rex 500pro DFC,Synergy E5s
Digger1973 is offline        Reply With Quote Quick reply to this message
Old 08-03-2014, 12:14 PM   #9 (permalink)
Guy I fly with has an e5s on 6s with the scorpion 1100kv. Flies just like u describe
Specter 700 x 2--Diabolo UL--Compass 6hvu--Logo 600--oxy5+, oxy5, Oxy3, oxy2, SAB Mini Comet
Cajun Aircraft
B.Ewing is offline        Reply With Quote Quick reply to this message
Old 08-03-2014, 01:46 PM   #10 (permalink)
Great. Thanx guys
Synergy E5
Gaui X3
Blade nano qx
JR x9303
Old 08-03-2014, 04:21 PM   #11 (permalink)
So I ordered a stretch kit with sped up tail ratio. What would be a good target headspeed for slow smooth sport flying swinging 606s?
Synergy E5
Gaui X3
Blade nano qx
JR x9303
Old 08-03-2014, 05:23 PM   #12 (permalink)
I am shooting for 2200 on mine, but I also throw in what passes for limited 3D .
Old 08-03-2014, 07:03 PM   #13 (permalink)
I fly my E5S with 4035-560 on 6s, at about 1300 rpm, on Rail 606's.
If you want low headspeed and 8 min flights it works just fine...then I can put a 12s pack in and fly 2600 or more if I want.
Retired2011 is offline        Reply With Quote Quick reply to this message
Old 08-05-2014, 06:01 PM   #14 (permalink)
Damn thats low!
Synergy E5
Gaui X3
Blade nano qx
JR x9303
Old 08-05-2014, 06:36 PM   #15 (permalink)
Check this vid with Matt flying the same setup...he says 1100 rpm, so it might actually be lower than 1300.
Synergy E5 Stretch - Extreme Low Head Speed (9 min 34 sec)
Old 08-05-2014, 07:52 PM   #16 (permalink)
Thats nuts!
Synergy E5
Gaui X3
Blade nano qx
JR x9303
Old 08-15-2014, 11:49 AM   #17 (permalink)
I love watching Botos fly low headspeeds
Really anyone, its so nice being able to see what the heli is really doing.
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs.
Old 08-16-2014, 06:12 PM   #18 (permalink)
Default Old Hippie
Whats the Highest RPM that can be run with a 560kv Motor
Thanks.....Dave
AMA 6679
IRCHA 675
VHA 11
Dave Willis is offline        Reply With Quote Quick reply to this message
Old 08-16-2014, 08:27 PM   #19 (permalink)
Mr mels says 2700 on 15t pinion, 2500 on 14t, 2100 on 12t. Governed though. I assume you run a gov. And 12cell. 6 cell is from 12t-1048hs, 14t-1223hs, 15t-1311hs
Old 08-16-2014, 11:34 PM   #20 (permalink)
When you ordered the kit with the speed up gears, was the gears just an add on item or were you able to get the gears in leu of the original gears?
Where did you order from?
Dw87 is offline        Reply With Quote Quick reply to this message
