Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis > Raptor G4/E720
Raptor G4/E720 Thunder Tiger Raptor G4/E720 Helicopters
Old 11-08-2013, 10:40 AM   #1 (permalink)
Default Which blades for E700
Guys,
could someone pls give me the required spec's on the main blades?
Will go with 690's - what is needed?
Hole 5mm?
Grip 12 or 14mm?
Thanks a lot!
fulcrum2 is offline        Reply With Quote Quick reply to this message
Old 11-08-2013, 12:12 PM   #2 (permalink)
Default Re: Which blades for E700
I'd try rail 696s, U won't be disappointed
Sent from my GT-I9300T using Tapatalk 2
VControl, Vbar Neo, Scorpion power systems, Optiguard, BK servos, Mikado Logo 700
Phil777 is offline        Reply With Quote Quick reply to this message
Old 11-08-2013, 12:40 PM   #3 (permalink)
I had Rail 969 on mt e700 and they flew nice. Now have a set of Helix blades which are very nice
Sent from my GT-I9505 using Tapatalk
JamesGreen is offline        Reply With Quote Quick reply to this message
Old 11-08-2013, 01:47 PM   #4 (permalink)
Thanks fellas. I need the root and hole dimension, not a certain type... Thanks again
My heli kit has not arrived yet and i want to order blades...
Old 11-08-2013, 02:55 PM   #5 (permalink)
Most popular 690mm blades come with 5mm hole (same size as e700 blade bolts) and 12mm root. They also come with washers if you need them. The TT 690 fbl blades listed in the e700 manual are 5mm, 12mm root.
http://www.modelhelicopters.co.uk/th...on-blades.html
So, you should be pretty safe buying any 690mm blades (or 693mm if Edge) with a 5mm hole and 12mm root. Not really sure if the e700 grip is 12 or 14mm but if it is 14mm you will just need a couple of 1mm washers on each blade.
Cheers,
TomC
Blade nQX,mCPX-BL,450x,500x Bell 222(bd3sx),550x(bd3sx)
TT X50E, 10s, bd3sx
Now also a FPV addict; Quads and Planes (soon to try heli's!)
TomC is offline        Reply With Quote Quick reply to this message
Old 11-08-2013, 03:03 PM   #6 (permalink)
Thanks Tom, I really appreciate your help
Old 11-08-2013, 08:12 PM   #7 (permalink)
Can you run 710mm on this heli? I have a couple pairs of edge 713mm that I wanted to use.
Logo 550sx Fat Boom
14SG
yachtheli is offline        Reply With Quote Quick reply to this message
Old 11-08-2013, 09:55 PM   #8 (permalink)
No, as per the e700 manual 690-700mm mainblades.
Cheers,
TomC
TT X50E, 10s, bd3sx
Old 11-09-2013, 07:31 AM   #9 (permalink)
710’s are way too long for the E700 – it is designed for best performance with 690 blades.
If you want to use longer blades get the E720. Edge 713's are what i run on my E720 and it's perfect.
RC Mike is offline        Reply With Quote Quick reply to this message
Old 11-14-2013, 05:38 PM   #10 (permalink)
Cyclone 695's are probably the best match for a heli like this and they will give you longer flight time with more pop.
I really like them on my TDR and was getting 1.5 minute longer flights at 1550 rpm vs. my Radix Blades. FYI, my Radix blades gave me longer flight times than Rail.
Also when I put the Cyclones on I had to REDUCE my tail gain quite a bit.
If I were building one I would use the following:
Cyclone 695mm mains
KBDD 112mm tails
I need to stop visiting this forum....
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
Old 11-14-2013, 08:29 PM   #11 (permalink)
Question
What was the problem with the 713 edge?
https://www.helifreak.com/showthread...=514882&page=6
Post #103
Logo 550sx Fat Boom
14SG
Old 11-14-2013, 10:41 PM   #12 (permalink)
You'll definitely want to run 112-116's on the tail. Wouldn't go beyond 700's for the mains in any event.
I'm running KBDD 112's and Helix 695's at 1850rpm.
Team Futaba
see_e_oh is offline        Reply With Quote Quick reply to this message
Old 11-14-2013, 10:55 PM   #13 (permalink)
Cyclone is my first pick. 695 perfect fit.
Sent from my SCH-I545 using Tapatalk
Washed up has been who should keep his trap shut
BrainDrain_dx is offline        Reply With Quote Quick reply to this message
Old 11-15-2013, 12:17 AM   #14 (permalink)
I will try the gryphon 700mm, and some 116mm on tail.
They perform great on my other helis, so think whey also will on the 700E :-P
RasmusDK is offline        Reply With Quote Quick reply to this message
Old 11-15-2013, 01:59 AM   #15 (permalink)
Got link to gryphon?
I enjoyed my Cyclones until I crashed them Sunday. Hoping the Helix come available before I have to make a decision. Waiting on tail drive pulley...
PRÔTOS 500 Plastic, Logo 550SX/600SX, PRÔTOS Max2 up and flying!
Team MSH USA, Team Cyclone, Team Xnova
trickybit is offline        Reply With Quote Quick reply to this message
Old 11-15-2013, 02:53 AM   #16 (permalink)
Here's a link
http://www.gryphon-mall.com/product.php?id_product=84
Really great finish, and balance perfect from new.
Old 11-15-2013, 03:30 AM   #17 (permalink)
Here's a link
Thanks! They look great and visible. I'm sure we'd love to hear your impressions if you fly them.
Old 11-15-2013, 04:12 AM   #18 (permalink)
I will let you know. :-)
Old 01-10-2014, 11:34 AM   #19 (permalink)
HELIX. im running edge 690SE
Team Synergy and Rail
helienv is offline        Reply With Quote Quick reply to this message
Old 01-10-2014, 11:43 AM   #20 (permalink)
Helix long out of stock. Cyclones worked great for me, but I didn't have a lot of comparison.
