550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
06-14-2012, 07:43 PM | #21 (permalink) |
When I get mine I plan to use the following:
Turnigy T600 4030 - 1100kV Motor (with 16T pinion) 3 x Hyperion DH20X-SCD on cyclic Hyperion DH20X-GCD on rudder Castle ICE100 ESC CopterX - 3x1000 Flybarless unit - (running one now on my Swift NX with good results) Zippy Flightmax 6S 4500mAh 45C batteries (they have 8 AWG wires though!)
Blade 450 FBL, Trex 550 FBL |
06-14-2012, 08:02 PM | #22 (permalink) |
Ok i started the build. Started taking the screws out the frame and lock tighting them. Most were in tight. The motor mount ones are in very tight. The aluminum is strong. No worries about stripping them out. One of the main bearing screws were stripped. You can see where i replaced it with a 3mm screw. Just the screw not the metal. Installed the lamding gear.
06-14-2012, 08:13 PM | #23 (permalink) |
Thanks for the pictures! It is looking great!
06-14-2012, 08:17 PM | #24 (permalink) |
I found extra hardwear in anothe bag. Woo Hoo! Also the servo mounting hardwear plates look like metal.
06-14-2012, 08:33 PM | #25 (permalink) |
Great! So the the extra hardware included an extra screw to replace the one that stripped?
06-14-2012, 10:13 PM | #26 (permalink) |
Ok so in less than 3 hours. some time spent removing the servos from my 600. I have the 4 servos mounted. The mounting hardwear have metal backing that you screw into. The front aleron servos need to be spaced outward. Due to the face the back were pressing on each other. Mounted the boom. The tail i went through all the screws and locktighted them. The aluminum is also nice and strong. I will upload the picks soon. So far this is a solid kit.
06-14-2012, 10:16 PM | #27 (permalink) | |
The pictures also show it next to the 500 im working on and the 600 |
06-15-2012, 10:31 AM | #29 (permalink) |
Are those frameplates 2 mm? I have a set in the mail. Hobbyking support couldn't answer that question
Looking great btw!
Mikado Logo 600 mini Vbar - Outrage fusion50 ar7200bx - goblin 700 mini Vbar - dx7s - powerlab6 |
06-15-2012, 01:14 PM | #31 (permalink) |
Thanks. I've never used those kind of calipers, finding it hard to read them plus the fact that they're in inches doesn't help too
Good to see that the new hk 550 kits are of decent quality and all goes well with the build.
06-15-2012, 04:55 PM | #33 (permalink) | |
2mm= .07874 or about .08 1.5mm=.05906 or about .06. The caliper in the pic shows .07. Right in between the two.
Learning to walk was so much easier than learning to fly. |
06-15-2012, 06:22 PM | #34 (permalink) |
Ok i just used a ruler. I dont like those calipers. the frames are 1/16 in thick
06-15-2012, 06:26 PM | #36 (permalink) |
digital mm caliper... only way to go.
currently building my hk 450 fbl, not 110% perfect, but very cool, doing the swash/arms setup now. (with a few beers
honey bee king II |
06-15-2012, 10:01 PM | #38 (permalink) |
I cant seem to find a FBL Tarot head. What are you guys running? Or are you keeping it FB.
Trex 600efl Pro with Beastx, Blade 450 3D with ZYX Tarot FBL, Blade 450 3D stock, MCPX v2, Sr120, Spektrum DX8 |
06-15-2012, 10:03 PM | #39 (permalink) | |
06-15-2012, 10:19 PM | #40 (permalink) |
I think you can. I happen to be taking the seros from my 600. My other 600 heli i had was running jr servos that were about 35 each. Handles great. Unless your a hardcore 3d pilot. We tend to get drawn into the the next best servo or what the pros are using. Im in the mild 3d section. I will be into it for $300. Would be less but i bought a spartin while there on sale. Unless i need to upgrade the esc.
