Go Back   HeliFreak > R/C Electronics Support > Castle Creations ESC and Software
Castle Creations ESC and Software Castle Creations ESC Software and Hardware Support
Old 11-23-2015, 01:12 PM   #1 (permalink)
Default Changes in Chart Numbers with Graph Smoothing
Just brining it up because I have never noticed this until now and have been flying Castle for years as a big fan...and still am.
I usually view my Castle logs with the graph smoothing on "High".
This makes a nice chart to look at.
What I just noticed was this has an effect on the "numbers" displayed at the bottom of the chart concerning system performance.
For instance with Graph Smoothing set to "Low or High" the "Maximum Amp" number at the bottom of the chart shows 40 amps.
With the Graph Smoothing set to "Disabled" the "Maximum Amp" number jumps to 77 amps.
That's a difference from one setting in graph smoothing to the other of 37 amps!
I assume that the numbers shown with the graph smoothing disabled are the accurate numbers?
Most of the other numbers change as well.
I don't mind this fact, I just want to be looking at "reality" and not "pretty" when reviewing the numbers, especially when the difference in total amp draw is so different.
I thought smoothing the chart line did just that, smooth the line. I didn't know it would affect the chart numbers as well.
Anyone shed some light on this.
Velos Rotors<<SAB<<Compas<<Align<<Walkera <<Propel
A VIKING is offline        Reply With Quote Quick reply to this message
Old 11-23-2015, 02:08 PM   #2 (permalink)
Yes, the smoothing can really change the numbers. Its better the higher the frequency that you sample though since you have more data points..
I use the logging as a "black box" with full 10hz sampling and the ESC set to clear itself with every power up. I only get about 6 min worth of recording, so the only log is always the current flight which is the only important one if the heli goes down and I need to know why without missing something due to data sampling gaps.
Smoothing off to high is only about a 2A change on my logs
Tony
Synergy 516, Gaui R-5 Speed (RIP), Cypher Vtol Jet (RIP), Spirit FBL, Hobbywing and Scorpion Tribunus ESC, Xnova motors. The girl in my DX9 tells them all what to do
Xrayted is offline        Reply With Quote Quick reply to this message
Old 11-23-2015, 02:33 PM   #3 (permalink)
Turning off the data smoothing and turning up the sample rate in the esc can also help with governor tuning. You can get a better feel for how well it can maintain headspeed under load, how quickly it recovers, and how much it overshoots on recovery from bogs and overspeeds.
Fauropitotto is offline        Reply With Quote Quick reply to this message
Old 11-23-2015, 02:34 PM   #4 (permalink)
Good to know!
I can see a change of 2A with graph smoothing but I see 37A which really caught my attention.
Old 11-24-2015, 10:23 AM   #5 (permalink)
Default after more testing....
Just to add info to my previous posts on this subject I find, after experimenting, that with a steady state hover, the graph numbers do not change from having the graph smoothing "disabled "or on "maximum".
Only the big amp spikes are affected in smoothing the graph and the recorded numbers at the bottom of the graph reflect the smoothing of the plot.
So no big deal, I'll just leave the graph on "disabled" so my viewed numbers continue to be accurate.
Rock on!
Old 01-15-2016, 05:29 AM   #6 (permalink)
Direct from Castle.
To view the most accurate performance numbers in the data log "smoothing" should be set to "disabled" and sample rate should be set to 10Hz.
Smoothing the plotted line degrades accuracy of your log.
