Old 02-01-2017, 09:34 AM   #1 (permalink)
Default A question for Frenchdress
If I use a JR rj01 sat on the beast plus what range would I get and can I use gov mode,many thank's,Marty.
Align 470M,stock motor,Kontoniks 60 amp esc,Futaba 760r gyro,Theta 921 cyclic servos and Theta Sabre T1 tail servo.
MeekaMoMo is offline        Reply With Quote Quick reply to this message
Old 02-06-2017, 12:44 AM   #2 (permalink)
Hi,
yes you can use gov mode also with the RJ01 sat. The gov mode can be used in combination with any type of single wire receiver. It's just not available when using standard wiring layout because of the missing connections for throttle in/out and rpm.
Regarding range I have no exact spcifications I can tell you. RF range itself should not be a problem, but due to the missing antenna diversity the signal may get blocked when using on a larger heli and flying further away. Similar to Spektrum R/C single satellite configuration I would only recommend to use the RJ01 sat in combination with small helis (max. 450 size).
best regards from Germany
Stefan
BEASTX r&d Team
freakware.com
Frenchdress is offline        Reply With Quote Quick reply to this message
