Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
06-28-2015, 08:57 AM | #1 (permalink) |
Setup Swashplate question
I have not touched setup program for almost 1 year since my SK540. I am setting up my SK720BE now but I am not sure about the step to level swashplate and to get main blades 0 pitch.
I used PC software (under Swash Servos tab) to get servo horns as 90 degree as possible at mid-stick. Do I need to connect to PC software to level swashplate and main blade 0 pitch or not ? I am using Soko kit to achieve both of level swashplate and 0 pitch at mid-stick in one step. Thanks, Ching-Ho Cheng
Nano CPx, Hirobo Quark 250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar 450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540 465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE |
06-28-2015, 10:16 AM | #2 (permalink) | ||
You don't need the GUI or TX (can be off=horns at center) after you put the horns to 90 deg at this step: finish leveling the swash and then put the blades to zero pitch. After you finish that - back to the GUI: put your collective to max + and (-) and level the swash at both extremes using the Swash Plate travels in the GUI.
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks |
06-28-2015, 12:29 PM | #3 (permalink) | |
06-28-2015, 03:46 PM | #4 (permalink) |
A clarification: when I wrote "cancels the gyro compensation to movement (and also to stick movement) I meant built in compensation for tail drag for example when moving the collective up and down, or the compensation between collective (or cyclic) to tail - so you have to be connected as well while setting 0 pitch for the tail blades.
06-28-2015, 04:04 PM | #5 (permalink) |
=] also Known as "set up mode" !! 🚡
06-28-2015, 04:15 PM | #6 (permalink) | |
When I did the swashplate level, I used Soko kit along with my Tx in mid-stick position. Gyro was powered up via Rx battery pack, not from main battery. Main battery was not connected. I will redo swahplate level with gyro connected to USB to PC software. Thanks.
06-28-2015, 04:16 PM | #7 (permalink) |
06-28-2015, 11:07 PM | #9 (permalink) |
Good to have you back in the game
