Register | FAQ | PM | Events | Groups | Blogs | Calendar |
MA Glow Miniature Aircraft Glow Helicopter Support Forum |
04-21-2013, 01:40 PM | #1 (permalink) |
Stratus : engine alignment
Hello All,
first, I'd like to apologise if my english is not perfect but I do my best Ok, I have two stratus and have the same issue with the two. I am not able to have a perfect alignment between the engine and the clutch... The consequence is high frequency vibration and emulsion in the tank. Some of you were able to fix this in order to have a good working of the heli ? Thank you, Rms |
04-21-2013, 04:41 PM | #2 (permalink) |
All I do is spin the motor over with the starter before I tighten up the 4 motor mount plate bolts; I have them firm but not tight, then spin it over , just for a second or so.... Occasionally have to do it twice to get it right..
Have you balanced the fan ? Checked for no runout with the fan mounted to the motor ??
Peter .... Furion 6 FBL ; E,N and G Whiplash FBL ; 2 Spectra G FBL ; Stratus FBL ;MA Extreme+E Razor+N Razor +Fury 55 FBL;xcell 60+xcell 70: TSA 700N & G; TSA 600N Pro & Platinum ; All BeastX ; guided by XPS . |
04-22-2013, 01:03 AM | #3 (permalink) |
Thank you,
That is what I do also... I Will Try another time with the plug out because my YS have a lot of compression... Rms |
04-22-2013, 02:29 PM | #4 (permalink) |
I do almost the same as Peter.
But i do hover the heli, with the four screws, just snug/tighten very little, so the plate can move a bit. Then i stop the heli, lift it (dont tilt it to one side) and then i tighten the four screws. Do you have the side frame stiffeners installed? http://miniatureaircraftusa.com/heli...-stiffener-set
ChopperKnud, Team Heliwholesaler - Team Miniature Aircraft ThePitchbrothers.com |
04-23-2013, 06:31 AM | #5 (permalink) |
Yes, I have the stiffeners, my two helis are first stratus with the high ratio upgrade kit.
I Will try your method this afternoon ! Thanks |
04-27-2013, 03:02 PM | #6 (permalink) |
Hello all,
Some news from here: The heli si flying better and better after every flight. There is less and less foam in the tank. I did as you told, with the engine running. What helps also is that the engine starts to run well ( I'm breaking in it ), it's a new YS 91SRX. Again, thank you ! RMS |
