Old 12-06-2014, 03:26 AM   #21 (permalink)
I think that motor is similar in specs to the 4035-500 as that peaks at about 4.5 kw.
I regularly fly with a 4035-500 at up to 2700rpm and my 70HV has never got over warm. I do fly decently hard. I've done whole flights of tic tocs and horrible stick banging stuff or just loads of max collective flying and still the same. I'm coming on 2 years of using the 70HV and I sometimes fly in 38 degree weather with half a dozen back to back flights with no break. Fly, land, change packs and immediately fly again. It's testament to the robustness of the setup and how little the X5 draws on 520mm blades.
12S 4035-500 Gaui X5 Formula VBar, 6S 2520-1880 Gaui X3 AR7200BX, Phantom 3 Professional
FailureToFly is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 03:41 AM   #22 (permalink)
There's been a thread for this for a long time... https://www.helifreak.com/showthread.php?t=633567
100 amp HV ESC is way overkill for an X5. I run a 80 amp HV on my 570 and so do many others with no issue pushing it hard. But, as long as it fits, it won't hurt. Having to much ESC isn't a problem, having too little is.
SAB Goblin 600, Logo 480Xxtreme, Gaui X3, Compass 6HVU, Atom 500
Jmann841 is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 06:41 AM   #23 (permalink)
Originally Posted by Atomic Skull View Post
I like how they put strain reliefs on the wires. However what I would really prefer is 5.5mm bullet plugs in the ESC housing instead of wires. That way you never have to worry about messing up an ESC with a soldering mistake and can change the lead lenght at will.
The Castle Talons are like that. I got the impression there were some complaints/issues with their method, no?
Some bullets coming loose. And if you run the motor leads in directly, you don't have any flexible wire in the connection. If you do add an extension, then you now have 2 sets of bullets in the wiring, vs 1.
I guess it didn't sound like a clear-cut "win". But I don't have a Talon, this is just based on what I've read here and there.
Sent using Tapatalk.
Old 12-06-2014, 09:16 AM   #24 (permalink)
Default new hobbywing 160HV V3
I also plan on stretching to 550mm eventually, and that is another reason I want 100A. I also may want to get another 550 in the future after having the X5 a while? such as a Synergy E5, and that thing is heavy. I would use a 4035 for a E5 and would definitely need a 100A ESC for that. If I already had a 100A ESC on my X5 and I decided to get an E5, it would only require me to get a new motor and batteries. If I had a 80HV I would have I get a new ESC in addition to that.
Sent from my Gaui X3 using Pulse LiPo
BladeScraper is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 09:32 AM   #25 (permalink)
I think that even with a 600mm blade, you will have no problems running the 80amp ESC. It is all you need to do even hard flying on 12S. That is if you keep it reasonable, with 13 degrees of pitch max and less than 2400rpm.
Andreas M.
Compass 7HVU
Logo 600SX V2
Blade 450X
Heli.Maniac is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 09:47 AM   #26 (permalink)
Reasonable? Me?
With a 4035 on 600mm blades 80A seems a bit low...
Old 12-06-2014, 10:02 AM   #27 (permalink)
Do they have active freewheeling? Not a deal breaker either way for me, the low head speed stuff is cool.
Precipitate is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 10:21 AM   #28 (permalink)
I don't think so, but you can always throw a 6s or 7s pack in and get the same result
Old 12-06-2014, 11:40 AM   #29 (permalink)
This HW ESC looks nice and is probably priced right too just like its 50A and 100A V3 siblings. However, in my opinion, it would have been better if there was no built in BEC as I prefer to use Rx packs. It would also be nice if it has logging... If it did and is priced right I will be replacing my YGEs on my 7HVUs with this ESC.
From experience, the YGE governor is not as straightforward to program as the HW. Also the lack of any protection for the electronics in YGE ESCs except a piece of heat-shrink is a throwback from 5 years ago IMHO. I lost a YGE 120HV because the tabs broke in a crash resulting in shorted circuitry.
XLP Specter NME | Oxy 5 550, 5 HF 560, 5 HF 610 | Compass Chronos, 7HVU, 550U, Atom | Gaui X3
cyclo is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 04:54 PM   #30 (permalink)
I have been waiting for this esc ever since the rumors started for my 800s. I currently run Yge 160s and popped one on my Triabolo earlier this summer. So to me the 160 is the minimum I run now in most my 700s and def wont be running any less in my 8s. Hopefully like their little brothers they allow an outside gov, and I am not at all interested in their bec, as I run my separate flight packs. I am left wondering what they are going to price in at?
Old 12-06-2014, 10:27 PM   #31 (permalink)
Sure looks like a kosmik knock off to me but it is nice looking
Trex700ProDFCHV,Goblin 770,Goblin 570, 14SGH
TREX 700 Pro, TREX 700LTop, GauiX3, Futaba 14SGH
Excalibur3 is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 10:53 PM   #32 (permalink)
Hopefully cheaper lol.
And that it won't light up in flames like CC
||Mikado Logo 480XXtreme||
|Trex 450|
~Futaba 14SG~
_Kyle_ is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 10:57 PM   #33 (permalink)
4035-500 and 690mm blades I have only hit 140-150 amp max draws. I have tried but could not get a higher spike. I am running it with a Commander V 130a, it will handle the spikes fine.
Spartan Vortex, Scorpion Motors, ExperienceRC Batteries, OMG Servos
FrSky Taranis
DaveHolland is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 11:31 PM   #34 (permalink)
Anyone who runs this ESC should be kicked out of their club... I'm especially surprised @ AS
Tri$tate 3D | BK Servo | Switch Blades | HeliDirect | Canomod
cjpainten is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 11:31 PM   #35 (permalink)
LOL
Old 12-07-2014, 03:29 AM   #36 (permalink)
It's an ESC with a metal case. Not sure how that makes it a Kontronik clone.
Old 12-07-2014, 09:23 AM   #37 (permalink)
Agree with that AS. Just because it looks similar doesn't mean it's a knock off... It has a totally different firmware, it's not trying to be a Kosmik.
Old 12-07-2014, 09:34 AM   #38 (permalink)
It is no Kosmik clone but in my opinion Kosmik influenced... In design and features.
Old 12-07-2014, 09:38 AM   #39 (permalink)
How can anyone look at that case and not see the uncanny resemblance to the kosmik 160. Lol The real test will be if the bolt pattern lines up with my goblin kde lipo tray system which is specifically for the kosmik 160/200. I'm only referring to the look.
Old 12-07-2014, 10:29 AM   #40 (permalink)
Default esc
I have to agree with Atomic Skull , I know you just referring but . I dose not look like a knock off to me. Hobby wing has been around a while and are good esc. I would not buy a kosmik 160/200 for the life of me. Way too much money. people can argue there the best but I am not so sure. I have seen them go up in flames just like every other esc, and for the cost of 800.00 burnt esc is just not for me.
I think YGE is the best I have seen
TEAM:
CYCLONE BLADES
matt blaisdell is offline        Reply With Quote Quick reply to this message
