Main Forum - Helicopter Talk R/C Helicopters and the people who fly them. VENDOR TOPICS DO NOT GO HERE. Full Scale Heli threads go in OT please |
09-22-2016, 05:07 PM | #41 (permalink) | ||
I like them better than the PRC6 / HXT6 because the sides of the plugs are color coded which makes plugging two batteries into each other much less likely. They can also be used as separate shrouded bullets or linked together using a dovetail joint on the side of the housing. HK now sells these in single sets for the ESC and battery sides as well as a pack of 10 pairs for $12. Someone needs to make a doodad to hold the shrouds together though, the dovetail joint can come apart when left by itself. Looking at the design and shape of the shrouds it should be possible to make a snap or screw together thing that would provide a bigger grip and lock the two housings together. Quote:
09-23-2016, 01:44 AM | #42 (permalink) |
I stopped using EC5 about 2 years ago. Switched to simple bullet connectors. No plastic housing and therefore very easy to setup.
If I would use anything with plastic housing i most likely would go with 6 mm connectors. Main reason for me was that some EC5 for 750+ size helis simply got a bit to hot. So I stopped using 5 mm connectors.
Kontronik, Switch Blades, Bavarian Demon, TDR, TDF, Diabolo, HeliBaby, Takumi and Banshee |
09-23-2016, 09:14 AM | #43 (permalink) |
for less than a 100 amps I switched over to xt60's on a few things and really really like them over ec3/5's.. way to easy to solder when soldered sideways (my buddy was complaining how hard to solder.. I said did you turn them sideways to solder....lol)... switching everything under 100amps to them...
Anything else.... XT150's all the way!
450x- w/ sk3 4300 motor, Yep 100 X7- iKon, 850MX 12s, Yep 180 X7f- iKon, Xnova 4535-460 14s, YGE 320 Gaui x7 14s yge320 072515 (2 min 5 sec) |
09-23-2016, 10:38 AM | #44 (permalink) |
P.s. This is the wiring diagram advantage of the XT150's... but yes you have to be aware of what you are plugging ... but not a big deal so far...
09-23-2016, 11:40 AM | #45 (permalink) |
I, too, got rid of my EC5s this year. The cases keep splitting on me. I went to RCProPlus D6s on everything, and love em.
09-23-2016, 12:08 PM | #46 (permalink) |
Actually splitting? What life of abuse are these things living? Then again, I was a sailor and we could break an anvil, so I guess anything's possible.
09-23-2016, 12:35 PM | #47 (permalink) | |
I switched to these connectors a few months ago from EC5 as well. Really like them! I do wish they were colored for the - + but it's not a big deal. |
09-23-2016, 01:24 PM | #48 (permalink) |
I had several that were starting to come apart where the two halves would meet in the molding of the plastic, therefore it wasn't holding the pins very well and would actually pop out when I plugged a battery in. I had about 40 flights on those packs when it started to happen. I also didn't care for the style of plug, as they would start to get weak and wouldn't hold very well.
09-23-2016, 02:07 PM | #49 (permalink) |
There had to be something wrong with the install as I have never heard of that before. Been using EC-5s for years and never had that happen. Did you get solder on the ring joint used to hold it in place when you snap the connector in? Did you install the connectors when they were hot?
MikadoUSA Tech Support |
09-23-2016, 02:51 PM | #51 (permalink) |
Yep. I always use the blue ones for the series connection. That way, I'm always plugging like colors together. I have to be more careful when I use the one of the same packs on my DT520, but I know that red and black still will never be plugged together: only black and blue or red and blue.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Protos Max Evo 700 (Brain 2), Protos Max V2 770 (iKON 2), Synergy 516 (Brain 2), Oxy 2 (Falcon 12) Graupner MZ-32 Experience is something you gain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
09-23-2016, 06:09 PM | #52 (permalink) |
+1 on using blue for the series connection.
Jay - Diligentia, Vis, Celeritas
Lynx / OXY Team Pilot, Zeal Team Pilot |
09-24-2016, 12:55 PM | #53 (permalink) |
ok I get if ppl want to change from EC5 to SupraX connectors as as I see it its much better to solder on the supraX connectors
but what are the benefits from EC5 to XT150 , now I'm thinking on the soldering part
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct | |
09-24-2016, 04:46 PM | #54 (permalink) | |
XT150's are easier to solder with large gauge wire and they are inexpensive. And out of the "hermaphrodite" connectors (PRC6/HXT6 XT150 and SupraX) they are the only ones that are color coded on each side which makes it less likely that you'll accidentally plug two batteries together (you'd have to plug red into black). They can also be used as either a connector or as single shrouded bullets. You can even hook three of them up together into a motor connector. |
09-24-2016, 07:38 PM | #55 (permalink) |
I totally agree with this observation. The RJX EC5's are junk and the Eflite are great, it isn't a wonder that someone would have a problem with the cheap ones, they are almost impossible to solder and the Eflite's are easy.
09-24-2016, 07:43 PM | #56 (permalink) | |
09-25-2016, 02:59 PM | #57 (permalink) |
RC Proplus connectors
same question , maybe quicker answer here on the RC Proplus connectors
https://www.helifreak.com/showpost.p...8&postcount=46
09-25-2016, 03:00 PM | #58 (permalink) |
Last winter I changed all my connectors from the EC5 Series over to the Supra series connectors....having second thoughts now.
The attached photos are from a recent mishap on my series cable, the connection going from the batts to the ESC. Fortunately when the joint desoldered I was able to auto the Trex 700 in without damage. I had read somewhere before that this type of "spring loaded" connector was not as conductive as we might think. As it turns out the "theory" is correct. They are great for a rock solid connection as far as not coming apart during flight but as the photos reveal the only true point of contact is at the very end of the connection. This minimal contact point reduces the flow of electricity to a small area , thus increasing the amps (and heat) if I understand the principle of moving electrons correctly. I've had over 300 flights on the series cable so this desoldered joint may have been weakening over time. I went through all my connectors looking for similar "Charring" on the end but did not find another case of this taking place. It may have been a fluke, but it did happen. At the present I'm still flying with the Supra's but looking into swapping everything out again this coming winter.
Goblin 700C, Goblin 570, Goblin 700 Piuma Logo 550 |
