Old 02-15-2012, 11:01 AM   #61 (permalink)
here guys. a few pics. i use 3 shims on top of maingear. and 1 under it. hope im not wrong i would shoot my self
ID:	289845   Click image for larger version
Yoda DK is offline        Reply With Quote Quick reply to this message
Old 02-15-2012, 12:10 PM   #62 (permalink)
I don't have that problem. My main gear lines up nicely with my tail gear, using mod .5. I'll try some plastic blades.
e
Logo 6003D Mini VBar 5.2 12s \ Kontronik Jive 80HV \ Xera 470Kv \ 623mm
Mini Protos µBeast 3.x 6s \ Yge 60 \ Stretch 350mm
egaus is offline        Reply With Quote Quick reply to this message
Old 02-15-2012, 01:35 PM   #63 (permalink)
Hi Yoda,
Manual says 3 shims on top one below...
I see that you're using the hollow main shaft. On the 400 this shaft wears fast on the bearing positions. This might not be the cause of you're vibrations but a place to check. Many 400 flyers use the hardened main shaft (MIK 04180) Maybe first we have to wait until you've checked the standard blades and see how this works out... The fact that you're 3mm below with the tailgear is maybe due to the different maingear which "looks" higher in the foto's than the standard gear...
/Kurt
We don't stop playing because we grow old; We grow old because we stop playing!
LOGO700(2) - LOGO690SX - 700XXTREME - GOBLIN380 KSE - VBARCTRL
galensk is offline        Reply With Quote Quick reply to this message
Old 02-15-2012, 02:26 PM   #64 (permalink)
I have heard a lot of guys complain about bad vibes using mod 0.7 gears. I know it's a bitch to swap everything out for mod 0.5 but if you are out of ideas it might be worth it just to eliminate one more thing.
I really don't think mod 0.7 is needed on the 400, I am swinging 500mm blades and have never striped a gear...... except when I had a few brain fart moments
If you are looking for bigger plastic tail blades the logo 500 ones work very well.
Bullfrog98 is offline        Reply With Quote Quick reply to this message
Old 02-15-2012, 02:28 PM   #65 (permalink)
Hi Kurt
yes i'm using the hollow mainshaft. i will change wenn its worn out or if it cause vibes. maingear is almost twice as thick as the mod 0.5 but my tailgear is also mod 0.7 so they are same hight. i'l get back wenn i get the shims and tailblades with an update but i thank you and the other guys so much for your help so far
Danny
Old 02-15-2012, 02:35 PM   #66 (permalink)
Hi Bull
if every thing else go wrong i'll change to mod 0.5gears. reason i bought it was because guys have talked alot about gear stripping with the 0.5gears didn't know the caused vibes i'll take a look at the L500 plastic tail blades. i honestly don't care what the look like. the should just be vibe free!
Old 02-15-2012, 02:40 PM   #67 (permalink)
+1 ...might be a last bailout... and no need to thank...We've all had our problems and the Logo guys always helped me out too... take care
/Kurt
Old 02-15-2012, 09:09 PM   #68 (permalink)
Guys,
I just put on some plastic 85mm blades (white ones that came w/ my 600). I balanced the whole assembly, reset my boom at 90 - seems the vibrations were worse. I didn't analyze them but I can tell.
I also replaced the flanged bearings in the CF tail before doing this. I'm using the hardened main shaft.
I'm out of ideas. I've replaced every part that could matter, balanced over and over only to have the exact same result each time. Very frustrating.
e
Old 02-15-2012, 09:22 PM   #69 (permalink)
It might be time to put it on the shelf, fly your other helis for a few days or a week, then revisit the problem with a fresh mind after you cool off. I've had to do that more than once, it's easy to get ultra-fixated sometimes, I've overlooked a lot of things this way (more recently than I'd like to admit... ).
gravydrive is offline        Reply With Quote Quick reply to this message
Old 02-15-2012, 10:45 PM   #70 (permalink)
Yeah.. But I need a flying 500 size heli or else I might go and buy another, yikes.
Here's some pics, camera sucks and everything is really straight (lens distorts some). The gear mesh shown actually has less backlash than it looks (it is more loose). I run a strip of paper through it and it looks good.
e
Name:	DSC00235 (800x450).jpg
ID:	290121   Click image for larger version
Name:	DSC00244 (800x450).jpg
ID:	290122   Click image for larger version
Name:	DSC00245 (800x450).jpg
Old 02-16-2012, 12:23 AM   #71 (permalink)
One of those photos has a mistake in it . Can you spot it? Even when corrected, it didn't change anything.
˙pǝxıɟ ˙ʎɐʍ ƃuoɹʍ ǝɥʇ ƃuıɔɐɟ sı ƃuıɹɐǝq ǝƃuɐlɟ puɐɥ ʇɥƃıɹ ǝɥʇ :ɹǝʍsuɐ
e
Old 02-16-2012, 12:40 AM   #72 (permalink)
Man, you're not the only one getting despondent about this heli.
When you do your test runs on the bench do you disconnect the tail servo push rod? I'm clutching at straws here, but it's not maybe a jittery servo or something like that.
Also you say you can clearly see a vibration in the tail at the target head speed. Perhaps it is some sort of resonance issue that can be fixed with slightly shorter/longer tail support struts, or a brace between the struts? Struts are easy to make if you get the right thickness carbon rod from the LHS.
Apologies if these suggestions seem stupid, but I'm pretty much all out of ideas. I had some minor issues with the initial setup on my 400 but nothing like this. Perhaps you should just give it a break for a week and then give it a fresh look.
Old 02-16-2012, 02:02 AM   #73 (permalink)
egaus
just got really happy. thought you hat found what was wrong. but no such luck. i don't understand any of this. i have put alot of heli's together i have never had problems or vibes like this before
i think i'll take my heli apart today and do the build all over again. something must be wrong. i must admit that i already regret buying this heli. so many problems on a brand new heli and all the time spent on it instead of flying the thing
Old 02-16-2012, 06:21 AM   #74 (permalink)
Hi guys
a litle update. i got the 72mm edge to day.balanced them and put them on. heli was much smoother now. no loud and wild vibes. wenn spooling it up. but i do have 2 bad spikes
1: 11,70Hz rpm 702. vibes 428
2: 107,20Hz rpm 11232 vibes 760
after the vibes test i pulled the hole tail of. wenn spinning it slowly i get a click sound. so i guess i've got a bad bearing. i'll order new ones and try again..
Old 02-16-2012, 06:31 AM   #75 (permalink)
Got that one too, changed the bearings in the tailgear and clicking was gone. I wouldn't change a thing at the blades now and check the vibes after replacing the tailgearbearings.
/Kurt
Old 02-16-2012, 09:04 AM   #76 (permalink)
i found a spare bearing,and changed it. vibe test again no difference. i'm now changing to mod 0.5 gears. do you use 3 shims on top of maingear? if do that. it will hit lower frames
ID:	290234   Click image for larger version
ID:	290235   Click image for larger version
Old 02-16-2012, 11:11 AM   #77 (permalink)
Yoda, look at the manual, find online if you don't have one. It looks like you have the one-way in upside down? Check out my pic on the previous page. Hard for me to tell, I am at work right now but the gear should not be that low. Good job on getting your vibes down so far!
e
Old 02-16-2012, 11:59 AM   #78 (permalink)
your right i better take a break on this heli i'm starting to loosing it..
Old 02-17-2012, 04:03 AM   #79 (permalink)
@e : good job noticing this . If this is corrected the problem migth be solved !!!
Danny will be airborne soon !!!!
/Kurt
Old 02-17-2012, 09:22 AM   #80 (permalink)
I wish I had as much progress. Seems anything I do, the problem stays relatively the same. Messing with the boom angle and mesh is not doing much of anything it seems.
The thing that gets me is the heli spools up super smooth, up until the very end, at target RPM, where it gets loud and shakes. Argh.
e
