Go Back   HeliFreak > R/C Electronics Support > Castle Creations ESC and Software
Castle Creations ESC and Software Castle Creations ESC Software and Hardware Support
Old 09-27-2012, 09:19 PM   #21 (permalink)
Well I decided to try and set this auto mode up just for kicks and giggles. Bob is correct it will not function with a flat 30 normal throttle curve, it must have 0 at the first point which essentially takes away one of your 3d curves at least with DX7. Thence it takes some bizarre switch changing to get it back into soft start think I will just go back to my 3 headspeed 3D throttle curves and forgo this about to grenade fast spoolup.....
"It's not the crash so much as the sudden stop"
Compass 7HV, Compass 6HV, TRex450Pro, bunch of other junk in boxes ... Team Flybar Team Tail-In wannabe....
sarpilot is offline        Reply With Quote Quick reply to this message
Old 09-27-2012, 10:12 PM   #22 (permalink)
Member
sar,
Who really needs three Stunt modes? I see it as a luxury, not a necessity. Coming from nitro, Normal flight mode was necessary for starting and spooling up. Standard practice was to spool up in normal mode, lift off and then immediately switch to Stunt mode.
Now that I'm electric, I still have a Normal mode and two Stunt modes. Unless I'm going to do an aerobatic take-off, I still spool up in Normal mode. I don't have a desire to have a third stunt mode.
Old 09-27-2012, 10:40 PM   #23 (permalink)
I was just mentioning it as a point of fact. With 7 channel radio you lose one if you want this bailout faster spool thingy. Myself if I have to auto its gonna probably not be a good outcome in any case and its not gonna be pretty . More thought on it think I shall just go back to my 3 solid 3D headspeeds not that I am capable of doing much with any of them…
Sent from my DROID3 using Tapatalk 2
Old 09-27-2012, 10:48 PM   #24 (permalink)
Originally Posted by Bob O View Post
sar,
Welcome to Electric City. That explains it.....
In electric land we spool midstick in idle up…
:bang
Old 09-28-2012, 07:58 AM   #25 (permalink)
Well now that it is all setup I guess I will try your method Bob. Guess I better change the normal pitch curve from linear to maybe -5 at the bottom so it doesn't start flinging stuff everywhere on spoolup. What kind of headspeed change rate you running on your 6HV?
Old 09-28-2012, 08:24 AM   #26 (permalink)
Member
Sent from my phone
Old 09-28-2012, 10:59 AM   #27 (permalink)
12
Sent from my phone
Ty sir… what kind of normal pitch curve are you running? I'm copying from everyone else might as well copy from you as well…
Old 09-28-2012, 11:01 AM   #28 (permalink)
Member
LOL!
My normal pitch curve has gone unchanged from the day I started flying. 40-45-50-75-100
BTW, I don't "fly" in normal mode.
Sent from my phone
Old 09-28-2012, 11:58 AM   #29 (permalink)
LOL!
Sent from my phone
I think that is pretty close to how my 450 and 600 are currently setup. I concur normal I only use for testing/tracking etc.
Thx
Old 12-30-2012, 01:02 PM   #30 (permalink)
I have followed Bobs setup video to the T and cannot get it to calibrate. I have a 700 Goblin, with a CC 160, running a 2s lipo direct to the beastx.
I set my throttle curve to 0-50-100, end points at 30 on high and low, full throttle on the stick, plug in Rx pack, plug in main pack. I get the 12 tones for cell count, increase high side end point and listen for a tone but I get to the top range of end point and still hear no tone. I made sure I have no sub trim, no throttle hold, and my trim is in neutral possition, I even rebound the transmitter. What am I missing here? Is the issue with the beastx? can I just use a seperate Rx for calibrating then plug back into the beastx when calibrated?
#1 Goblin 770 Pyro 800-48-480kv, HW V4, Ikon 2
#2 Goblin 500 Xnova 4020-2Y-1200kv, HW V3,Ikon 2
#3 Goblin 380 Quantum 880kv, HW 100 V3, Ikon 2
snoshoe62 is offline        Reply With Quote Quick reply to this message
Old 01-02-2013, 08:19 AM   #31 (permalink)
Quick question. Do you calibrate throttle in fixed endpoints checked on castle or governor?
zosek is offline        Reply With Quote Quick reply to this message
Old 01-02-2013, 09:24 AM   #32 (permalink)
You do it with endpoints and with a linear throttle curve. Most of the time it will see 100 percent throttle without needing to change endpoints but if not add until you get the tones. To see 0 throttle you will most likely need to add at the bottom until it is happy, most of mine end up around 120 or so. After calibration you can change your normal throttle curve to 0 30 30 30 30 or whatever you like …
Old 02-10-2013, 01:20 PM   #33 (permalink)
Mine recognizes the high throttle endpoint at 106%, then as I lower the stick it recognizes the low throttle endpoint at 94%, but still on the top half of the throttle range (meaning 94% of the high throttle side, with the stick barely below top maximum. This can't be correct?! It does play both tones to indicate that it recognizes those endpoints at both 106% and 94%, but the motor won't spin. Any suggestions??
naturaly is offline        Reply With Quote Quick reply to this message
Old 04-28-2013, 10:17 AM   #34 (permalink)
My low and high end points are 70% low and 94% high. That's when I get the tones.
Brianp82 is offline        Reply With Quote Quick reply to this message
Old 05-23-2013, 05:47 AM   #35 (permalink)
I have a Castle Ice2 HV 120 and want to use the set rpm in governor mode... Do I have to do this calibration as well then?
T-Rex 250 pro DFC w/ BeastX - T-Rex 500FBL w/ BeastX - MD7 w/ Brain FBL - T-Rex 700E Pro DFC w/ Brain FBL
JHuygen is offline        Reply With Quote Quick reply to this message
Old 05-23-2013, 06:22 AM   #36 (permalink)
Default Re: Castle Creations Quick Tip videos
You only need to set throttle endpoints on initial setup. After that you can change anything you want in the software without affecting calibration setup....
Old 05-23-2013, 06:39 AM   #37 (permalink)
And I can do that just out of the box, without any pre-programming of the ESC?
Old 05-23-2013, 06:50 AM   #38 (permalink)
Pretty much... calibrate esc throttle endpoints using a linear throttle curve. After that use the castle link software to enter your motor and gearing info desired headspeed(s) etc. Then reset your throttle curves as the software requires. Most people use "set rpm" mode gives you 3 different governed speeds....
Old 05-23-2013, 06:51 AM   #39 (permalink)
Thanks for the help!
Old 05-23-2013, 07:00 AM   #40 (permalink)
