Old 07-29-2015, 12:57 PM   #1 (permalink)
Default Lube connectors for easier removal?
I was listening to the lastest RCHN podcast where they briefly discussed lubing the connectors for easier removal. Does any body routinely lube the connectors?
14S Specter 700 V2 NME/Tron 7/Kraken; 8S Tron Dnamic; 7S Kraken 580; 6S Buddy 380 KSE
VBCE/Neo/EVO, Jeti/Spirit, YGE "T" ESCs; LiFePO4 field charging batteries
Sims on Mac: Heli-X, neXt, AccuRC, Phoenix, AeroFly RC7 Ultimate
Amain Team Pilot
jhamel is online now        Reply With Quote Quick reply to this message
Old 07-29-2015, 01:12 PM   #2 (permalink)
If i could find a lube without hydro carbons and was also conductive, i would certainly do that. Maybe light bulb grease but i would have to research if it was compatible with plastics.
redsox is offline        Reply With Quote Quick reply to this message
Old 07-29-2015, 01:20 PM   #3 (permalink)
They mentioned something about light bulb grease. I've never heard of such thing before. I'll have to research this connector lube subject. My guess is that the automotive folks may be able to impart some wisdom on this subject.
Amain Team Pilot
Old 07-29-2015, 01:22 PM   #4 (permalink)
The Airetic
The only ones I do is the occasional XT60 that sticks. Deoxit works amazingly well to both clean the contacts and provides lube.
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 07-29-2015, 01:25 PM   #5 (permalink)
+1 to this. I use Deoxit on my XT30s too. (XT30 totally rocks on the Blade 180 / 200QX and others that size).
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 07-29-2015, 01:38 PM   #6 (permalink)
you can do it and the lube does not have to be conducting. Metal parts make electrical contact via microscopic surface roughness. The points of contact are called "asperities" (Google "asperity wiki" for more info).
Lube is excluded from these points of contact. I have used thick, pure silicone grease for this (Dow Corning Vacuum grease).
Another example are products like Noalox which is used for aluminum wire and bus-bar electrical connections. Noalox is non-conductive and acts mostly to prevent the alumium from oxidizing.
This is your brain on helicopters!
Trex 700L, Trex 700N DFC HB gasser,Trex 700N V2 HB gasser, Trex 550X. Spirit or BD3SX
rhodesengr is offline        Reply With Quote Quick reply to this message
Old 07-29-2015, 01:41 PM   #7 (permalink)
I've never heard of DeoxIT before. Are you guys talking about the DeoxIT "D" series? Would I be able to apply a dab of this inside the female EC5 and/or EC3 connectors?
Amain Team Pilot
Old 07-29-2015, 01:42 PM   #8 (permalink)
I use the Deoxit gold spray. Not cheap, but it's magical stuff for switches and electronic widgets.
http://www.amazon.com/DeoxITGOLD-Spr...dp/B003A7KHK8/
Chris Boultinghouse
Old 07-29-2015, 01:47 PM   #9 (permalink)
I'm not familiar with the names of these greases, but can't you just use a dielectric grease like the kind sold at automotive stores?
ranchhand is offline        Reply With Quote Quick reply to this message
Old 07-29-2015, 02:18 PM   #10 (permalink)
Yes. Dielectric grease is what you should use. You really do not want it conductive. Because grease will flow and migrate and when it connects between both pins. If it was conductive, you get the picture
Dan Pesonen
FBL, Don't think about it, DO IT.
mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS, T-700N
"Tri-Flow"
I put that S*** on everything!"
banditpowdercoat is offline        Reply With Quote Quick reply to this message
Old 07-29-2015, 02:22 PM   #11 (permalink)
I have used dielectric grease on my electrical connectors my only issue with using it is that it will collect dust and dirt that will eventually destroy the connector IMO.
SYNERGY N5C, Xpert, VBAR NEO, ROTOR RAGE 30%, O.S.55HZ-R SYNERGY E5s Rail 626/106,Scorpion 4035 560kv,Hobbywing ,Vbar NEO,Xpert Vcontrol N556 Xpert R2's OS Powered Nitro Beast
TEAM SYNERGY FIELD REP
XPERT TEAM PILOT
boogie12 is offline        Reply With Quote Quick reply to this message
Old 07-29-2015, 02:30 PM   #12 (permalink)
Well you learn something new everyday. Thats a great point about conductive grease possibly causing a short. Yeah i think regular old light bulb grease is a good choice.
Old 07-29-2015, 02:59 PM   #13 (permalink)
Agree.
I use it on some connectors as needed. If they seem to go together smoothly I don't use it as I don't want them to get so loose as to accidently pull apart. If I have to struggle to get them apart I don't hesitate to add dielectric grease.
Marc
Norman, OK - Synergy N7, TREX 700N DFC, TSA 700N, TSA 600N, Trex 550, Trex 500 ESP (FBL), 450L, RCHN - 700
mqowen is offline        Reply With Quote Quick reply to this message
Old 07-29-2015, 02:59 PM   #14 (permalink)
Registered User
It's anti seize grease. Keeps the metal bulb base from corroding to the metal socket. Navy at sea used to use a lot of that.
But the conductive properties are as bad as putting too much Artic Silver 5 on the CPU to heat sink junction. It oozes out and drops on the socket or down on the mother board. Being silver oxide, it's very conductive. And we don't have to tell you what happened next. ZAP!
setishock is offline        Reply With Quote Quick reply to this message
Old 07-29-2015, 03:25 PM   #15 (permalink)
Are you trying to lube the bullet connector or the plastic housing?
+1 on lubing the XT60 plastic housing.
kobbler is offline        Reply With Quote Quick reply to this message
Old 07-29-2015, 03:25 PM   #16 (permalink)
I've used dexoit gold. Worked great on my EC5s.
Field rep for Discover Card and team Visa.
MSH Brain super fan and crash test dummy.
kthane is online now        Reply With Quote Quick reply to this message
Old 07-29-2015, 03:41 PM   #17 (permalink)
I ordered the DeoxIT Gold that Chris recommended. Thank you.
Amain Team Pilot
Old 07-29-2015, 03:42 PM   #18 (permalink)
Same here, at least initially. Eventually the EC5s break in and will pull apart more easily without lube.
HeliFreak Support
Graupner MZ-32
Old 07-29-2015, 03:46 PM   #19 (permalink)
Either. I just don't like ending up with blisters on my fingers from pulling those EC5's apart.
Amain Team Pilot
Old 07-29-2015, 11:52 PM   #20 (permalink)
I've never had problems pulling EC5's apart even when they are brand new.
