Gasser Helicopters Gasser Specific Discussion |
11-26-2015, 10:28 AM | #1 (permalink) |
Spektrum Rpm sensor
Happy Thanksgiving. I'm building a Whiplash gasser and i will be using a ar7200bx on it. I would like to use the gov on it, is anyone using the Spektrum back plate RPM sensor pointed at the crankcase, if so , how does it work?
Thank you Leon
MA Graphlte 46, MA 98 SE, MA IonX2, 2 Whiplash EX, Synergy E7SE |
11-27-2015, 04:46 AM | #2 (permalink) |
The ar7200 gov has not played nice on a gasser.
If you want to still use the 7200 add a gov. The Futaba gy701 is one of the best external govs. RC Japan has it for a good price. I tried the original beastx and while it worked, it was much more nervous than other FBL units such as Vbar, BD and Ikon.
Tom TRM Power CAUTION - my posts are based on my experiences, yours may be different. |
11-27-2015, 07:09 AM | #3 (permalink) |
As Tom said, the AR7200bx gov has known issues on a gasser. The gov software was too twitchy for gasser throttle curves, resulting in the gov overshooting and hunting.
The current Beastx Plus units work great on gassers, both governor and flight characteristics.
Whiplash Gasser l Goblin Gasser |
11-27-2015, 09:36 AM | #4 (permalink) |
Thank you for the responds. I have a Spartan VX1 coming, I think i will try that first. Spartan just released new firmware.
Leon
11-28-2015, 04:47 PM | #5 (permalink) |
The spektrum rpm sensor works perfect, there are various ways to install it.
Cheap nitro engine to gasser conversion thread (OS,TT Redline, ASP)
11-29-2015, 12:42 AM | #6 (permalink) |
I am running the crank sensor on go gh56 no problems, showing up fine on My dx7s
02-04-2016, 01:26 AM | #7 (permalink) |
running sensor on my Zenoah rc290 align sensor with centre of crank and adjust spacing for correct rpm . too close will give double reading
02-08-2016, 07:18 PM | #8 (permalink) |
Would you mind posting a pic of how and where you mounted your sensor for this?
02-13-2016, 02:45 AM | #9 (permalink) |
spektrum sensor
pic can be seen in my profile album . cant figure out how to post pics, just figured it out lol make sure it is positioned over gasket separating crankcase halves , this is where the big end will be. adjust distance from case for proper reading , too close will double rpm
