Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Old 07-23-2011, 07:48 AM   #61 (permalink)
Originally Posted by BakedMopar View Post
Something that caught my attention today, my motor has end play in it ( I can push the motor down a mm or so when botled to the motor mount). I don't remember if it did or not. Can someone confirm this?
Do you mean the play in the can? IE. in the 7HV the bottom half of the can, on top, can be moved up and down. If so that is normal. All Compass motors (and many others) do that.
Chris D.
crawl is offline        Reply With Quote Quick reply to this message
Old 07-23-2011, 08:14 AM   #62 (permalink)
+1. There has to be some allowance for heat expansion.
HeliFreak Support
Graupner MZ-32
Old 07-23-2011, 09:13 AM   #63 (permalink)
Originally Posted by myrseth View Post
I hope you will comment on how it works for reference!
Tried the new motor internals on punchrc and hobbywing esc still just bogs like a madman. :-/
Sent from my SAMSUNG-SGH-I997 using Tapatalk
Chris D.
Old 07-23-2011, 09:35 AM   #64 (permalink)
Yup I'm here at the field with him and the new motor internals didn't help with power at all. His hyperion hk4035-560 has twice the power at least.
Sent from my HTC Inspire with Tapatalk
[ SAB Goblin ][ Trex 450 Pro ]
Azlum is offline        Reply With Quote Quick reply to this message
Old 07-23-2011, 12:58 PM   #65 (permalink)
Thanks Guys.
I don't have new internals but I'm not so trilled about it's "Brute" performance eighter.
BakedMopar is offline        Reply With Quote Quick reply to this message
Old 07-23-2011, 01:01 PM   #66 (permalink)
I have the replacement stator in my motor and mine has all kinds of power
Jeff
helis101 is offline        Reply With Quote Quick reply to this message
Old 07-23-2011, 03:57 PM   #67 (permalink)
I think once we get enough guys flying the new stator, we should be able to get some Eagletree data to confirm what it's delivering. I just programmed my K120HV ESC and ran the unloaded motor up and down to confim settings and such. I will be disappointed if this motor isn't the brute it was said to be. I spent too much on the ESC to afford a Scorpion motor ...LOL! To me, it didn't feel like the stator I removed. Didn't feel as much magentism, for some reason.
= Rb43 =
Rob43 is offline        Reply With Quote Quick reply to this message
Old 07-23-2011, 06:55 PM   #68 (permalink)
Im not talking just not a brute, im talking down right awful weak, bog in a flip.
Chris D.
Old 07-23-2011, 09:02 PM   #69 (permalink)
Is that with the new stator from Compass installed?
= Rb43 =
Old 07-24-2011, 03:47 AM   #70 (permalink)
I installed my new stator on Wednesday and the Mavrikk blades, flew a quick flight and with that set up I had some bog on FF to a tight loop. I blamed it on the blades being wider than my CYB, today I will fly with the CYB's and retest, will post my opinion.
Atom 500 VBar (Takes a licking), MCPx 2s (Flying ), Atom 7HV-Bar (Flying LARGE!!)
BBRFST is offline        Reply With Quote Quick reply to this message
Old 07-24-2011, 07:31 AM   #71 (permalink)
Yeah that is with the new stators. I may have just terrible luck and got another bad motor. I tested for continuity no problems there.
I will mess with timing and maybe try no Vbar gov again, but I tried all that with the last motor and it didn't make any difference.
Right now I am running the hobby wing on stock timing (5), 12khz, Vbar gov @ 1850 / 1950 on the stock 12t pinion.
Chris D.
Old 07-24-2011, 07:10 PM   #72 (permalink)
BBRFST: how about performance with the CYB's...did you get out? I don't know what I will do if this motor isn't good or the blades bog it. I have used up all of my hobby funds and vacation time to build this model. Right now, I am feeling bad for Nankin who's supported us unconditionally, and there were way too many errors in the first run. I sold two helis and everything that went with them to build this heli.
Today, since I am still waiting for the Fromeco, I removed the tensioner to look it over. The carbon arms are misdrilled. I tried flipping mine over. It helped a bit.
= Rb43 =
Old 07-24-2011, 09:55 PM   #73 (permalink)
Well after flying today I would say the motor is not living up to the promise. I put the CYB blades on today and it pretty much flew the same as with the Mavrikk blades (which I thought was the cause for the bog), bogging on tic toc's and inverted loops. I didn't have this concern with the original motor. I'm torn as to whether to use the old motor (still not sure if I would fail in flight) and wait and see what the remedy is or going out and getting a Kontronik's motor. That being said the Kontronik motors are 520KV Compass motor is 570KV what's the difference?
Oh and the CYB blades are the standard ones not FBL or stick bangers.
Old 07-24-2011, 10:03 PM   #74 (permalink)
I am thinking a Scorpion HKIII 4035-560 will be required to alleviate the Compass motor inadequacy. I don't know why is the heck we wound up with crappy motors when they tested the heck out of motors before releasing. Where's the Brute? I want the Brute.
= Rb43 =
Old 07-25-2011, 05:23 AM   #75 (permalink)
is that really compass motor on 7hv is powerless? can you guys make video on it? thank you
Team Compass - Atom 500 - Knight 50 3D - Odin 90 - Avant Aurora
jstnt is offline        Reply With Quote Quick reply to this message
Old 07-25-2011, 05:46 AM   #76 (permalink)
That's what I did to mine, and it turned the heli into a monster! Power difference from the Compass motor to the Scorpion was like going from a nitro .50 to a 12s 600e.
Sad, but true.
Old 07-25-2011, 06:22 AM   #77 (permalink)
So the concensus is the 4035-560 then?
I'll wait it out a little longer to see what Compass say regarding the lack of power, but it looks like I'll be buying a new motor before even trying out the replacement one.
Mixmaster Pilot is offline        Reply With Quote Quick reply to this message
Old 07-25-2011, 07:19 AM   #78 (permalink)
It's worth giving the stock motor a shot. It looks like there are possibly a few people happy with the stock motor.
The Hyperion 4035-560KV is a cheaper but great option as well.
just a Scorpion HK4035 re branded (and supposedly with different bearings).
It was a monster for the couple flights I had it in the 7HV.
7HV 2100RPM 13t Bogggggg (1 min 9 sec)
Chris D.
Old 07-25-2011, 07:52 AM   #79 (permalink)
In my 7HV I have installed ,,scorpion 4525 -520KV Limited Edition,, with pinion of 15T guided to 2100RPM, is a beast
Uploaded with ImageShack.us
Lynx Oxy Team Pilot
joseca is offline        Reply With Quote Quick reply to this message
Old 07-25-2011, 09:17 PM   #80 (permalink)
I misunderstood...I thought the Hyperion motor was a typ-o, as I didn't realize they made a rebrand motor. Does it already feature the extended shaft like the HKIII, or is it an add-on? I couldn't tell from Readyheli's description. Is there another source?
= Rb43 =
