Belt CP E-Sky Belt CP |
04-03-2008, 07:05 PM | #1 (permalink) |
Belt CP links
Are the belt cp ball links one way only like the align links? If so what indicates outside and inside. I had tracking issues using the 325 blades so i was doing a lot of adjusting of the links. Well one of the links got to loose and popped off in flight. I am in repair mode now. By the way, before the crash i put the 315 blades back on and solved the tracking issues. Any ideas as to why i can't track 325 blades on my cp?
Thanks...boom striker |
04-03-2008, 07:18 PM | #2 (permalink) |
Not sure about your tracking issues - could be a host of issues, especially if you're in "repair mode," as you say. Feathering shaft and blade balance are the usual suspects.
As for the linkages being one-way, my answer is no, they are not one-way. I used something akin to a ring gauge to figure out whether they were or were not, and the shaft went through to the same depth from both directions. If you had one come loose, it may have been for all the adjustments. Good luck, -V Last edited by Vendetta-NY; 04-03-2008 at 07:20 PM.. Reason: Typo |
04-04-2008, 04:31 AM | #3 (permalink) |
As posted in the other thread, it could be that your stock o-rings can't handle the bigger blades, try the V1 T-Rex dampers or even better the "new damper system" for t-rex v1 (the yellow ones)
T-Rex 500 µBeast, 450 Pro (soon to be µBeast) & a Compass 6HV And a P51D plank......SSssssshhhhhhh! BMFA & RCHA Member [B][COLOR="Blue"] |
