Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 02-26-2014, 01:58 PM   #41 (permalink)
I had a similar issue.
I got a a sheet of copper and cut it to fit.
I trimmed it in a curve at the top after I took this picture so it could rotate.
Kontronik does not recommend standoffs, so you could probably bend a piece of copper however you like.
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
Old 02-26-2014, 02:28 PM   #42 (permalink)
RJ
That looks professional Mark, especially with the Banshee label heatshrink and fuseholder. Thanks for the Kosmik info.
I see some are going to put the Kosmik fuse inline on one of the flexible battery cables instead of the lug. Sounds like a good solution too.
RJ is offline        Reply With Quote Quick reply to this message
Old 02-26-2014, 02:53 PM   #43 (permalink)
This is what the final result looks like.
I had a 100 red, 100 black and 300 yellow custom shrink made up.
Mark
Old 02-26-2014, 02:57 PM   #44 (permalink)
I may need to make up some Henseleit shink wrap at some point.
Especially if I end up with 3 different Henseleit helis
Mark
Old 02-26-2014, 03:02 PM   #45 (permalink)
RJ
I think Henseleit heatshrink would be very cool.
Old 02-27-2014, 08:55 AM   #46 (permalink)
Default SFR2 Speed Fuselage for TDR
Sorry to interrupt the heat shrink love-in but out of curiosity, why are the speed fuselages still running a tail fin? Wouldn't this also be a cause of drag and turbulence?
A small standoff or skid on the underside of the boom would prevent any issues with the tail rotor touching the ground.
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 02-27-2014, 02:29 PM   #47 (permalink)
RJ
Shhhhhhhhh! Speed secret! LOL. The stock tail fin is just for practice. The competition version gets the streamlined stinger as on the 2012 SFR1.
And now, back to heatshrink...
Regards,
Rick
Old 02-27-2014, 02:48 PM   #48 (permalink)
In my best Lee Corso voice.....Not so fast my friend..............
Extending on that, I wonder how much, if any, a cap for the end if the boom would help.
Ok, now we can go back to the shrink wrap.
_____________________
JRAY is offline        Reply With Quote Quick reply to this message
Old 02-27-2014, 03:02 PM   #49 (permalink)
RJ
I think covering the tail gearbox would help, that's why I left the tail boom long on SFR2, but I expect that air is exiting out the tailboom below the gearbox, so I think I would want to leave that open. A streamlined cover with air exit holes could be an improvement though...
Old 02-27-2014, 03:43 PM   #50 (permalink)
Yeah, that could definitely work.
Old 03-01-2014, 08:55 PM   #51 (permalink)
Mark's great heat-shrink idea moved to add-ons to stay on topic
Here's some pics of my SF2 - looks great Rick
ANd a quick and dirty video of test - no I didn't know the gardener was gonna walk through the back yard
Name:	DSC_0409 (Copy).JPG
ID:	491527   Click image for larger version
ID:	491528   Click image for larger version
Name:	DSC_0412 (Copy).JPG
ID:	491529   Click image for larger version
John
Old 03-01-2014, 11:45 PM   #52 (permalink)
RJ
Hi John,
Nice to see it finished and flying. It looks great! The orange windscreen and green comet look very visible. Thanks for posting the photos and video. Is it going to make it to the Australian Speed Cup?
Regards,
Rick
Old 03-02-2014, 02:33 AM   #53 (permalink)
Thanks Rick, well it nearly had a wipe out this arvo. Flew beautifully and on 2nd flight lost cyclic and it careered down! With a lot of luck landed on a blade and spared the fuze thank goodness. Funny, crash was largely due ro having a Scorpion BUG, switched this on to fire up the FBL then FORGOT to flick the inline switch I have in the BEC lines. Anyway took off flying only on the BUG which bugged out after a couple of runs leaving only the barest of control. The BUG lipo must have been pretty flat though wasn't flashing red funny how a backup nearly ended in disaster!
John
Old 03-02-2014, 03:18 AM   #54 (permalink)
RJ
Ohhhhhhhhh, sorry to hear about that! Sounds like a routine needs to be in place (I guess there will be one now). Hope you can get it back together soon.
Regards,
Rick
Old 03-02-2014, 03:30 AM   #55 (permalink)
HF MR Support
John,
In my Uvular, I wire the BUG so that the power from the BEC will always be on even if I forget to turn on the BUG.
Please don't use the BUG with HV BLS servos as it cause brownout the moment I turn it on.
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 03-02-2014, 03:36 AM   #56 (permalink)
Originally Posted by TommyBear View Post
John,
The BUG was being used with 451s, I use the Ultraguard with HV servos. Rickmis right, just need a new startup/shutdown procedure. I mentioned it just as an illustration as how increased complexity caused by "fail-safes" such as backup and fuses can in themselves cause disaster! Luckily the SF2 is unscathed
John
Old 03-02-2014, 03:36 AM   #57 (permalink)
I think the dx9 allows you to set checklist when turning on.
Would be a cool feature to have
helicraze is offline        Reply With Quote Quick reply to this message
Old 03-02-2014, 05:05 AM   #58 (permalink)
I think the real culprit was the inline switch for your bec.
JWILL is offline        Reply With Quote Quick reply to this message
Old 03-02-2014, 05:50 AM   #59 (permalink)
Buffer devices or packs should be last on and first off, then you will not have this scenario. Glad you saved it.
VControl
Old hand at Planks
Peter
Old 03-02-2014, 06:25 AM   #60 (permalink)
Good advice - strange heli - lot of work getting packs and fuze mounted - just plain forgot
Jan's advice about no buffer and rely on BEC keep ringing in my ears - KISS principle
John
