Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 01-20-2014, 06:38 PM   #1 (permalink)
Default Spektrum H2600 servo fitment
See the pic. These don't seem to fit. What can i do? I see the manual mentions spacers. (H0031) do i need to use those on both sides?
Fusion 180 - M2 Evo - RAW 420 - Fusion 550 - Tron 5.5 - Kraken 580 - Kraken 580n - Kraken 700 - Kraken 700n - Vcontrol Evo
vertico is offline        Reply With Quote Quick reply to this message
Old 01-20-2014, 06:47 PM   #2 (permalink)
If you use spacers you will need to use the same number of spacers on both sides. The big question is that when you have a servo horn installed can you get the link ball mounted so that it is centered on the main shaft when looking at it from the side. It's all trial and error fromthis point on....
Please let us know how you make out since I'm sure others might be interested in the outcome....
OXY / Lynx Team Pilot
mtuccio is offline        Reply With Quote Quick reply to this message
Old 01-20-2014, 07:37 PM   #3 (permalink)
Oddly enough the spacers in the manual H0031 don't exist on helidirect. Anyone have the correct part number?
Old 01-20-2014, 07:49 PM   #4 (permalink)
Here is the link: http://www.helidirect.com/sab-carbon...-s-p-25747.hdx
Old 01-20-2014, 08:12 PM   #5 (permalink)
Originally Posted by mtuccio View Post
Oh ha! I'm having a long day, that should have been obvious. On the plus side i have a ton of those
Wfu on on how many it took.
Old 01-21-2014, 02:11 AM   #6 (permalink)
I had a similar problem with the ProModeler servos I'm using. And also got confused by the part numbers. H0031 is actually the uniball; H0075-S is the CF servo spacer.
Anyways, I used Protos servo mounting plates as spacers. These fit the servo mounting loops tightly and are much easier to install than the Goblin CF spacers, particularly if you'd need more than one. Here's the post: https://www.helifreak.com/showpost.p...9&postcount=32
The servo adapters aren't sold separately, but they come with the Protos tail servo holder for 5.99: http://www.helidirect.com/msh51051-m...os-p-22716.hdx
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote Quick reply to this message
Old 02-28-2014, 12:50 PM   #7 (permalink)
To follow up I had to add 3 carbon spacers to each side of the servo in order to get it mounted properly on my 630. So since it already requires 2 to mount this equals 24 servo spacers needed total. I had to sand the edge of the horns down to achieve a full range of motion. Additionally, I had to lower the cyclic ring in my vbar in order to prevent binding on the AR bracket.
To be honest this is an awful lot to go through to get a servo to fit properly. Other servos like the BK servos do not necessarily need this much help for proper fitment and operation. The Spektrum servos appear to have the spline much closer to the edge of the servo than others have.
As far as flight goes, I am happy with them. They are fast and feel direct. The really neat thing about these is the servo lead disconnects from the servo to allow you to change the servo without redoing your wiring, they also sell different sized cables so you can get the smallest length you need for your application.
Old 03-01-2014, 04:50 PM   #8 (permalink)
Default Re: Spektrum H2600 servo fitment
BK servos fit right in with no modifying required.
Helico-pteron is offline        Reply With Quote Quick reply to this message
