Blade 450 Blade 450 Helicopters Information and Help |
05-17-2011, 10:18 PM | #1 (permalink) |
What's the difference between the 400 & 450
I was looking at the two spec sheets. Same motor, same size main blades, same length.
Other than gyro and servo's, what is the difference?
If you want to avoid a crash, stay away from the ground! IRCHA # 1261, Blade 400 (hopped up), T-rex 450 se V2, Blade cMX, Blade mSR, T-rex 250 se, Blade mCPx, Blade 130 X, Blade 300 X, Blade 450 3D, Blade nCPx, Parrot AR Drone, Blade 230S |
05-18-2011, 02:11 AM | #2 (permalink) |
larger tail boom diameter, new tail case/tail end, slightly different frame with one more mainshaft bearing, new one way bearing, a few new parts on the head, aluminum head block. Blade says it is a "completely new heli" which I believe is bs. They took the 400 and improved(who knows yet?) on some of its weaknesses.
MSH Mini Protos 4s stretch with Beastx! |
05-18-2011, 03:17 PM | #3 (permalink) |
Also looks like diff servos and better gyro
05-18-2011, 11:17 PM | #5 (permalink) |
I watched a HH video where the said they added another bearing, it sounded like stupid now that I think of it.
05-26-2011, 09:54 PM | #6 (permalink) |
you can buy a 400 right now and a 450 who knows when ha ha, naw I hope the new servos,gryo, esc is worth it. I sold my blade and miss if will be getting another one or a 450 not sure. but im sure i wont fly stock esc know for sure. servos, maybe a few flights but sure i upgrade to a name i can trust HITEC.
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs. |
06-15-2011, 12:57 PM | #7 (permalink) |
I was on a website that shows all the parts for both heli's. It looks like a majority of the part numbers are the same.. So, I'm wondering if anyone has calculated what it would cost to turn your 400 into a 450 mechanically... Minus electronics since most of us will be OR already are using high end electronics....
Goblin 380, Goblin 500, Goblin 630 |
06-15-2011, 02:27 PM | #8 (permalink) | |
06-16-2011, 01:07 PM | #9 (permalink) |
Hi
I live in the UK & still waiting for it to be available here. The difference is you can buy the 400!!!!! Last edited by Barry Isle of Wight; 06-17-2011 at 04:56 PM.. |
06-20-2011, 02:54 PM | #11 (permalink) | |
Looks like the Blade 450 will be out very soon. As a start to answer your question, let me address some of the mechanical aspects. The 450 is clearly based on the strengths of the B400, but is very much a new machine based on the same concept. If you look at the number of new parts (and the key 'tooled' ones), this will be clear. Much of the new work was done with the goal of making it stronger and stiffer, more agile, with the ability to handle more power, with less vibration, while keeping the weight quite low in the class. Some changes to this end (partial list): -Larger diameter tail boom. -New frames to hold larger boom and a few tweaks (easier servo fitting, more servo arm clearance, etc) -New material and precision ground main shaft with step -larger diameter stepped spindle. -Metal head block -New blade grips to work with new spindle (with thrust bearings) -Stronger wood main blades (batteries have improved a lot, so more power) -Stonger tail shaft -New tail gear box and hub to support this change -stiffer two sided supported tail pitch adjust bellcrank -new tail blade grips with thrust bearings!! -weighted tail blade grip (weight mod) for low servo loads and rapid response Other Mechanics: New simple, tough, and light one peice main landing gear. New Canopy Tail servo mounted to tail boom only. Inverted V flybar cage for more available cyclic control Improved mixing arms "Vented' fins for better 3D New FB paddles for more weight flexibility More erongomic canopy mounting system 70 or 80 hardness damper availibility http://www.bladehelis.com/Products/D...ProdID=BLH1600 Hope this helps! Have Fun, David |
06-21-2011, 11:49 AM | #12 (permalink) |
Just to tag onto the above, since I apparently do not have a signature setup here yet...
(Tail box is really for the belt drive... not gears... just old habits! Needed for larger Boom as well as larger shaft/bearings) David Ribbe Horizon Hobby Product Development |
