Old 11-28-2012, 02:09 PM   #1 (permalink)
Default tail grip bearings ?
who has the best tail grip bearings available for the mini protos ?
I would like to have some on hand.
scott s is offline        Reply With Quote Quick reply to this message
Old 11-28-2012, 03:52 PM   #2 (permalink)
Default Bearings..
For me, bearings in general are way way too fragile. I put ABEC 5's from BOCA in the tail and they were noticeably smoother but they probably just pack them with thinner grease to produce that effect. I got the ones with metal sheilds because they have less friction than the rubber sealed ones. The metal is very thin and the tail loads them sideways and they will bend and wear abnormaly. I could not find any combination of thrust bearings that would work. So, if you don't like the stock bearings, the only thing that in theory would be a lot better would be full ceramic and that comes to 400.00! Going to Ceramic balls would be probably worse in terms of fragility. The balls are harder than steel but its not the balls that are wearing out, it is the raceway.
CrashAddict is offline        Reply With Quote Quick reply to this message
Old 11-28-2012, 05:05 PM   #3 (permalink)
Grab a tube or two of the bulk ones from here http://www.rcbearings.com/. Quality is good and the prices are reasonable. BOCA are stupidly overpriced for what they are.
No point putting really fancy bearings in the tail, the first time you tap it on the ground you will damage them anyway.
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 12-07-2012, 05:30 PM   #4 (permalink)
Default What about these?
http://www.rcbearings.com/t04-09g-4x9x4/
These are 4x9x4 thrust bearings. Same size as stock radials. So you could run one of these with one of the stockers and have a thrusted tail.
Old 12-07-2012, 05:46 PM   #5 (permalink)
What on earth are you talking about ? LOL! The miniprotos radial tail grip bearings are
3x6x2.5 and 2 in each grip.
How you gonna get a 9mm diameter thrust bearing in there?
The mini does not need a thrusted tail. Just some better quality bearings than what came stock with my latest kit. Got some of the 3x6x2.5 bearings from rcbearings.com and they are a definite improvement from the stock ones
Old 12-07-2012, 05:52 PM   #6 (permalink)
rotflol..
I misread my own list. 3x6x2.5 it is!
ID x OD x D
6 x 12 x 4 Main Shaft Bearings (3)
2.5 X 7 X 2.5 Forward Guide Pulleys (6)
2 X 5 X 2.5 Anti Rotation Bearings (2)
2 x 5 x 2.5 Wash Out Arm Bearings (4)
4 x 8 x 3 Main Grip Bearings (4)
4 x 8 x 2.5 Thrust Bearings (2)
4 X 9 X 4 Tail Bearings (2)
4 X 7 X 2.5 Rear Guide Pulley (2)
2 X 5 X 2 Tail Control Arm (2)
3 X 6 X 2.5 Tail Grip Bearings (4)
Old 12-07-2012, 06:57 PM   #7 (permalink)
Heli guys over here swear by Japanese EZO bearings. Always wondered as Germany has plenty of manufacturers. So far I tried the stock ones and SKF and was not impressed by the play in both of these from the beginning. Might try the Japanese ones when mine make me problems.
2x MCPX I Gaui »X1« I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
