MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
12-04-2012, 12:20 PM | #1 (permalink) |
Almost have everything I need
I have been searching and reading as much as I can about a 450 that is a tough as nails, easy to maintain, and built with quality parts… I also asked two people I personally know who fly Mini P’s, they both said this is the heli you want!!! Thank you Dylan and Allen.
I have committed to build a Mini Protos, and started to buy the parts I want to fly with. I almost have everything I need; I just wanted to share my excitement with everyone. I should be flying my new Mini in January; I need a few more things and need some time to build it. I would like to hear what you guys think. Parts I have: MKS 92A+ MKS 95i Ikon FBL Tail blades (yellow) Motor 1300Kv (6S) Alu CNC pulley set Mini Ball sizer Pinion 15T Flybarless head low profile Kit stretch Mini 4x Turnigy nano-tech 1300mah 6S 45~90C Lipo Pack ESC Programming Card HK - 360mm Carbon/Glass Fiber Composite Main Blades (Blades to maiden with, I hear these fly good as well) Parts I need: MSH41501 Mini Protos Carbon Kit (YGE+Scorpion+SAB) More Batteries Parts I’m thinking about??? SAB Red/ White/ Black 350mm Main Blade Curtis Youngblood Radix 59mm Tail Blades YEI-YB-59 LE-353FBL EDGE 353mm SE Premium CF Blades LE-60SE EDGE 60mm SE Premium CF Tail Rotor Blades
A lot of RC stuff: Heli's, Quads, FPV gear, Tools, Chargers, Transmitters |
12-04-2012, 04:42 PM | #2 (permalink) |
Great setup. Cant think of anything better. good luck..
I personally like edge blades, they are reasonably priced and well designed. I avoid expensive blades whenever I can. |
12-04-2012, 05:39 PM | #3 (permalink) | |
Blades are a very personal choice though, each blade someone says is great, others will hate.
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh -Goblin 500, HC3SX, Hyp DH16/MKS980BL, Scorp 4015-1100 |
12-04-2012, 07:41 PM | #4 (permalink) | |
12-06-2012, 09:36 PM | #5 (permalink) |
That's going to be a terrific Mini Protos. Stretched. Low FBL. 6S power system. Nice servos. Ikon FBL unit (I use the MSH Brain - more or less the same thing, I understand).
The YGE 60A ESC programmed for Governor Store mode works very well on this heli. For a carrying case, I have found this one http://www.ideal4allhobbies.com/CY-R...p/thg400xl.htm to be a very good fit for a stretched Mini Protos. Regarding blades, I like the SAB 350's a little more than the Edge 353's. They are a bit lighter. The Edge blades are nice and stable, but, in my experience, they fly heavier. For some, perhaps more experienced heli pilots, that may be a positive thing. I do use Edge CF tail blades and I like those quite a lot. I hope you have a great experience with your new Mini Protos!
• SAB Goblin 500: MSH Brain, Kontronik Jive & 600-12 • MSH Protos 500: Stretched, MSH Brain • MSH Mini Protos: Stretched, MSH Brain |
12-07-2012, 12:14 AM | #6 (permalink) | |
Just wondering. I have read the YGE manual as well as the mini manual and two build threads. I don't foresee any build issues. I want to get down to business with this but I'm spending my heli money on Christmas, besides I have a big project at work due in late December. Putting off the build for a few weeks is a good life choice, not what I want. But the responsible thing to do. Sent from my iPhone using Tapatalk
12-07-2012, 10:06 AM | #7 (permalink) |
I have not used the Brain governor. If I understand things correctly, doing so would require wiring in a phase sensor. I'm still new enough to configuring helis that I have been taking gradual steps. I do look forward to using an external governor eventually, but most everyone seems to agree that, for an ESC built in governor, the YGE Governor Store mode works well.
12-08-2012, 06:41 AM | #8 (permalink) |
Sounds like a great setup, you can also get some good prices Lynx blades.
http://www.msh-direct.com/products/l...on-blades.html So far so good, and priced right MSH Direct is also great to deal with
Rick, Team pilot , EGODRIFT, KST, Helidirect, Lynx/Oxy |
