Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Like Tree31Likes
Old 04-13-2014, 03:55 PM   #561 (permalink)
HF MR Support
Default What did you do with your TDR today ?
I found that by adding a fan to the motor, it cools the internals much better and everything comes down much cooler.
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 04-13-2014, 04:07 PM   #562 (permalink)
Default Re: What did you do with your TDR today ?
HA!
Danny Dugger is offline        Reply With Quote Quick reply to this message
Old 04-13-2014, 04:18 PM   #563 (permalink)
Where can we get the fan from and how to attach it to the motor
firemedic295 is offline        Reply With Quote Quick reply to this message
Old 04-13-2014, 06:00 PM   #564 (permalink)
HF MR Support
It's a Computer processor's CPU fan.
Here's a link to my thread on how it's done.
https://www.helifreak.com/5648507-post.html
Lynh
Old 04-13-2014, 08:10 PM   #565 (permalink)
WOW!!!! Now that is a plan! Only thing is...its my BEC that is getting hot not the motor.
Very nice mod Lynh! How many flights with MKII? Is the epoxy still holding?
William Blake Team Kontronik
TDR1, Banshee 850 # 22
Diabolo 700
wblombard is offline        Reply With Quote Quick reply to this message
Old 04-13-2014, 08:15 PM   #566 (permalink)
HF MR Support
Uvular has been my speed trainer and so far everything is holding together rock solid.
I use epoxy steel this time round too, the original fan hub melted on MKI.
Lynh
Old 04-13-2014, 08:36 PM   #567 (permalink)
Nice, Lynh!
_____________________
JRAY is online now        Reply With Quote Quick reply to this message
Old 04-13-2014, 10:54 PM   #568 (permalink)
Do you think the same thing will work on a pyro 750 motor? Im keen to apply the same pricipal but a fan spinning at 20,000 RPM just sounds risky?
Diabolo 700
Old 04-13-2014, 11:29 PM   #569 (permalink)
Won't the fan upset the airflow through the motor, would think it needs to blow air AWAY from the motor to help with the airflow through the motor. Plus using some power from the motor although very little but still eating mAHr from your packs.
VControl
Old hand at Planks
Peter
Old 04-13-2014, 11:42 PM   #570 (permalink)
HF MR Support
Unlike the pyro line of motors which have internal air induction channels in the can to pull out the heat, the Scorpion won't suck any air as it spins.
The can mounted fan works because it is utilising the free momentum from the spinning can and act in a similar principle to a turbo fan design.
Personally, I've found that with the addition of the fan, everything is a lot cooler after multiple flights and the air movement inside the canopy has positive effect on the ESC too.
Lynh
Old 04-13-2014, 11:53 PM   #571 (permalink)
That is a lot of RPM on a fan!!! I would really like to apply the same principals to my Pyro Motor but I'm a little concerned.
I will however ask Kontronik for their advise and whether they approve
Diabolo 700
Old 04-14-2014, 12:26 AM   #572 (permalink)
HF MR Support
I haven't done the fan mod to my pyro yet because the pyro actually create its own air current from the channels inside the can.
Rest assured I run my Uvular at 2400RPM at the mains so the fan is definitely fine with the high HS.
Lynh
Old 04-14-2014, 01:53 PM   #573 (permalink)
Scorpion has the same air channels inside like all other motors. So blowing air down on the exit vents will cause the air to stagnate inside the motor. Not a good idea if you ask my opinion, maybe if it blew air away from the motor.....
VControl
Old hand at Planks
Peter
Old 04-14-2014, 03:43 PM   #574 (permalink)
I see an interesting experiment, measure temps in similar conditions with and without fan.
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
Old 04-14-2014, 03:53 PM   #575 (permalink)
HF MR Support
If you run the scorpion without the canopy and blades, there is no air current around it.
When you run a pyro under the same condition, you can feel the current of air blowing out wards from the can.
Lynh
Old 04-15-2014, 01:54 PM   #576 (permalink)
I'm positive the original proto D-Speed ran a fan on top of a 4530 Xera similar to Lynh's setup. Santiago's setup maybe?
X-Cell Whiplash, Konk 700-45, Skook 540, Mav 710's, YGE 160HV...
itbvolks is offline        Reply With Quote Quick reply to this message
Old 04-15-2014, 03:12 PM   #577 (permalink)
HF MR Support
Lynh
Old 04-16-2014, 09:20 AM   #578 (permalink)
You got it!
I like the setup. If you can keep the motor balanced - I don't see an issue with this setup particularly for Scorps in highly enclosed canopies....
Good setup I think.....
Old 04-20-2014, 11:50 AM   #579 (permalink)
Got my Cyclones back on my TDR and loving it!
My last flight was 9min 35sec with 3.78v
I ran 1680rpm for much of the flight.
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
Old 04-20-2014, 12:56 PM   #580 (permalink)
I replaced the mini VBar with the full size unit and am trying a completely different FBL tuning this time around. I should be able to get a flight in today or tomorrow and see if this is better.
I also installed the battery tray system from Sixt in Germany.
Ryan
Mikado USA, Kontronik, Opti-Power, MKS Servos, VTX
RyanW is offline        Reply With Quote Quick reply to this message
