Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 01-11-2012, 08:41 AM   #21 (permalink)
New main gear is it a different material?
Team MikadoUSA Team Scorpion
Logo 800,700,600,400,Diabolo,TDR
heliaddict2424 is offline        Reply With Quote Quick reply to this message
Old 01-11-2012, 08:47 AM   #22 (permalink)
Yes, it will no longer be metal.
gww528 is offline        Reply With Quote Quick reply to this message
Old 01-11-2012, 08:53 AM   #23 (permalink)
Originally Posted by epc2 View Post
Still don't undertsand why people want to fly 3d with a light E90's @2200rpm what a waste of energy IMHO!!
epc2.
So your saying that you didn't see a dramatic difference in performance between the parts of the video where the heli was flown at 2000 and when it was flown at 2200? I sure did.
don-dadda is offline        Reply With Quote Quick reply to this message
Old 01-11-2012, 09:49 AM   #24 (permalink)
don-dadd, wasnt it 1600 and 2200 in the video?
epc2.
Completely agree, there are even people who fly 2400+rpm on a 700size. that is even more
DannyvG is offline        Reply With Quote Quick reply to this message
Old 01-11-2012, 10:30 AM   #25 (permalink)
Default Regarding insane headspeeds...:
In his write up about the design philosophy behind the TDR, here is what Jan Heneleit says:
"In connection with the development of the Rigid numerous test flights with a logger data capture were carried through, which persuaded me to refrain from the exaggerated present max rotor speed hype. Thanks to light models with flybarless main rotors it is not necessary any more to race with a rotor head speed exceeding the limit of 2000. The properties when flying straight on are even fantastic at 1300 rpm at the main rotor. Every flybar head helicopter would pitch up hopelessly at these manoeuvres. Most of the 3D figures can be flown because of a lower rotor disc load also using a more moderate head speed. So more than 1800 rpm at the main rotor are unnecessary when flying this helicopter. The logger data show that the efficiency of the blades decreases rapidly with increasing head speed, so that most of the energy is wasted. For the same flight condition "Hovering at one position" 570W is required at 1300 rpm at the rotor and at 1850 rpm you already need 1000W. At more than 2100 rpm 1500W are required, i. e. nearly the triple amount, although you do nothing more than hovering.
This result shows clearly that the flight time can be increased considerably, if the rotor does not constantly rotate at full speed. All these results have contributed to and influenced the choice of the speed reduction and the recommended drive of the Rigid."
Of course, the text is about the TDR, not the Goblin, but think about what he says for a minute...
minicopter Diabolo, Henseleit TDR, X50e, X50n, Raptor 50
Futaba 2.4 GHz
DT75 is offline        Reply With Quote Quick reply to this message
Old 01-11-2012, 10:34 AM   #26 (permalink)
Originally Posted by fusionsx00 View Post
Man compass has some balls
Hey your parts.look like our parts were sueing, ohh and by the way how do you like our new tdr'ish landing gear
compass asked permission to use there designs
Compass 7HV 9180/9188 Vbar
Compass 6HV 9180/9188 Skookum,4025-630KV
Compass 6HV Savox/ 9188, Vbar,
Fusion 50 9080/9088 Beast X
Velocity 50n 9080/9088 VbarSAB Goblin 9180/9188 Kontronik helijive Coming soon
AnTi Taco is offline        Reply With Quote Quick reply to this message
Old 01-11-2012, 03:31 PM   #27 (permalink)
The main thing is which set-up you use. There're differences in Governor philosophy. In my opinion, having a good Governor with enough head-room to withstand even hard collective and cyclic pitch at 1900 to 2000 feels way more aggressive than a "soft" governor at 2200+. I would only use these extreme high-speeds for speed flying.
But that's personal taste...
-klaus
SuziLAOS-DNHP-CenturioMax-Protos500-Logo400-500-600SE
worldofmaya is offline        Reply With Quote Quick reply to this message
Old 01-12-2012, 04:50 AM   #28 (permalink)
-klaus
I think it depends on your flying style. If you need short burst pop then the energy is best stored in the blades as it's there more instantly. If you need more sustained power deliver then the energy is best stored in the battery. For me the advantage of running a lower headspeed and governing more aggressively is I get a constant headspeed throughout the flight. Those who run 100% throttle find that the headspeed decays right from the start of the flight.
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 01-14-2012, 11:48 PM   #29 (permalink)
Anyone read on the Sab website under general discussion, the post that says shipping date? Well someone quoted Sab and it said something on the lines of the first batch won't be until February 10.
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
KONTRONIK, OPTIPOWER, PRC, CANOMOD
jhheli is offline        Reply With Quote Quick reply to this message
Old 01-15-2012, 12:08 AM   #30 (permalink)
That would be 4 months to the day since I placed my order, fully paid, on Helidirect. I thought December was a on time to wait, and then January and now February.
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
bobloblaw is offline        Reply With Quote Quick reply to this message
Old 01-15-2012, 01:57 AM   #31 (permalink)
If youre not in th US use fastlad uk next time, only 10 gbp for preorder, Personally i feel SAB shoud have prevented hd from doing business this way, leaves a bad taste!
Stolla is offline        Reply With Quote Quick reply to this message
Old 01-15-2012, 02:17 AM   #32 (permalink)
I didn't have to fully pre-pay, it was my choice - money would burn a hole in my pocket so I dropped it ASAP. I called Helidirect and they were surprised I wanted to fully pre-pay as no one else had at the time.
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
Old 01-15-2012, 02:53 AM   #33 (permalink)
Default I would think some sort of down payment would be in order
At least for the guys that got there names on the canopies. Otherwise when people back out, they would be stuck with those.
TDR, Srimok N x 2, Banshee 31, Dune!
jhunter is offline        Reply With Quote Quick reply to this message
Old 01-16-2012, 04:10 PM   #34 (permalink)
The Aussie distributor has confirmed a worldwide release date for the Goblin as February 7. He believes he will have stock on this date - I would assume Helidirect will be the same. So, less than a month to wait, hopefully.
SAB Goblin 500
SAB Goblin 700
Jeti DS-16
Old 01-16-2012, 05:23 PM   #35 (permalink)
Damn so its been pushed back again.
Sponsored by :
Old 01-17-2012, 01:14 PM   #36 (permalink)
it sucks.. arrivel feb 14 in Denmark
Yoda DK is offline        Reply With Quote Quick reply to this message
Old 01-17-2012, 01:52 PM   #37 (permalink)
Who sells this in denmark?
felborn is offline        Reply With Quote Quick reply to this message
Old 01-17-2012, 02:23 PM   #38 (permalink)
Rotordisc'en:
http://rotordisc.dk/shop/helikopter-...-el-157c1.html
Futaba 2.4 GHz
Old 01-17-2012, 03:56 PM   #39 (permalink)
Sombitch starting to smell like Avant.. I to paid in full but at-least the pictures show there doing something unlike XXtreme who knows whats going on there lol...
Old 01-17-2012, 09:14 PM   #40 (permalink)
A German shop already notified their customers that they should get their kits in next week. My LHS which is part of the German and Austrian distributor still says end of this month...
-Klaus
