Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 120 SR
120 SR Blade (eFlite) 120 SR Helicopters Information and Help
Old 10-28-2011, 04:34 PM   #1 (permalink)
Default Jekyll and Hyde 120SR
I've had my 120 flying great for over a week. Last night I ran 5 batts through it with no issues and no crashes. Today, I go to fly it and it is a demon possessed. It takes hard right aileron just to get it in the air and then it flies like it has a mind of its own. It rocks back and forth, front to rear, and barely responds to stick input. Tried rebinding and a fresh battery, and still it persists. Short of an exorcism, what could be the problem? This was my best flying bird until today.
Align Trex 450 Pro & 450 Sport | E-Flite Blade CX3, mCPX and 120SR | Syma S032 and S107
Parrot AR Drone 2.0 | Futaba 10CHG | FlyMentor | Co-Pilot II | Traxxas Nitro Stampede
If my hobbies don't kill me soon, I'll die a poor man.
Miami Son is offline        Reply With Quote Quick reply to this message
Old 10-28-2011, 05:16 PM   #2 (permalink)
Did you feed it first?
Re-Bind it.
Syma S107-Syma S109-Syma X8C-Syma X8G-Syma X5HC-Syma X5HW-Mini Orion-ProtoX-Syma X5C-1
USAF RETIRED 1968-1988 Vietnam Veteran
Pfloyd is offline        Reply With Quote Quick reply to this message
Old 10-28-2011, 05:33 PM   #3 (permalink)
Re-Bind it.
kona0915 is offline        Reply With Quote Quick reply to this message
Old 10-28-2011, 06:11 PM   #4 (permalink)
Old 10-28-2011, 06:21 PM   #5 (permalink)
Have you checked the flybar? Make sure all the links are where they should be and secure. If that still doesn't work you could try changing the length of one side of the servo to swash links to get rid of the tendency.
krobinson103 is offline        Reply With Quote Quick reply to this message
Old 10-28-2011, 08:23 PM   #6 (permalink)
yeah I was wondering about the links to. Do you have a stock TX that you could try it with to make sure there isn't a setting on your DX6i that got tweaked some how.
Old 10-29-2011, 03:19 PM   #7 (permalink)
+1
When mine acts up nearly always is a link-sometimes they come off even in flight. distant 2nd is a damaged flybar-even a bent or stretched ball on fly bar can cause issues, and distant 3rd is a servo acting up-usually from speck of foreign debris. I've had servo to swash links break, but never had em be an issue if not visibly damaged.
megawhacker is offline        Reply With Quote Quick reply to this message
Old 10-30-2011, 09:31 PM   #8 (permalink)
This thing won't even fly with a link disconnected. I reset some things on the Tx and my swash level and blew out the servos with canned air and it is better, but nowhere near as good as it was a couple days ago. It is toilet-bowling pretty bad. I use to be able to hover this baby right in front of me with almost no stick movement. Now, to hold a hover I have to constantly be making big corrections in all directions just to stay within a 1-2 foot area. And it takes mostly right aileron to do that, very little left. Just don't understand why it would change literally overnight from a great flying heli to one that now is a real challenge to fly.
Old 10-30-2011, 10:01 PM   #9 (permalink)
Let's revisit the links again.
Check that their position is on the balls and that they did not pop past them and look connected but are really on the arms of the balls. Check ALL the links.
Make sure the swashplate is level with radio on. If it isn't first re-bind the radio with all trims centered. Then check it again. If it is not level when checking from the rear and the side, then remove a actuator arm from the servo to the swash plate and either screw it up or down to make your swash level. PLEASE BE CAREFUL AS THE LITTLE BALLS ON THE SWASH SNAP OFF EASILY!!!!!
Once the links are checked properly, and the swash is level with radio on and heli bound to TX, then apply a lubricant to all moving parts. I use a wet silicone spray. Others use a dry silicone powder that is applied by spray method also. Both work.
This will eliminate binding of the linkages.
Once these 3 things are done you should fly fine. Let us know after you do this. If the problem remains, try to get use some pics of everything so we can double check it for you.
~Rich
Radio-DX8
(3) Blade 120SR(RKH red trim, NiteFlite , Kestrel 500)
Blade CX3/UMX Beast/HK J3cub/Champ
Mr.Firemouth is offline        Reply With Quote Quick reply to this message
Old 10-30-2011, 10:32 PM   #10 (permalink)
May need to have it blessed by a priest?
