Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Electric
MA Electric IonX2, Razor and Furion Support forum
Old 02-05-2012, 05:45 PM   #21 (permalink)
Been flying with the Align 450pro swash driver for a while now and it fits and works very well. It is the best flying 450 I've ever flown by a long shot. I've also redesigned my custom FBL head some to be easier to make and use the Align driver arms.
http://helidirect.com/align-mixing-b...fl-p-17770.hdx
If anyone is interested in a set of these frames send me a PM.
Below is a rendering to show the basic idea. I need to refine a few things about the design and double check some dimensions but it shows the basic concept.
prototype3a is online now        Reply With Quote Quick reply to this message
Old 02-07-2012, 07:35 PM   #22 (permalink)
Here's an updated render of the head I want to have prototyped.
Old 02-09-2012, 07:03 PM   #23 (permalink)
Thinking $40 per set of my frames if anyone is interested in a set. I may try to source some screws in bulk to make life easier for people.
Right now this includes both frame halves, AR bracket, servo horn adapters, small washers to hold the HS-5084mg servos and a small tray for the rear of the heli.
To install the extra tray you'll need 'MA130-230 CNC Frame Spacer'. In the photos, my esc is strapped to this tray. It is perpendicular to the main shaft so you could mount a fbl unit to it if you wanted.
Old 02-11-2012, 12:56 PM   #24 (permalink)
Here's a rendering what I'm calling V1 of these frames. I hope to have the first batch of these frames in a week or so. These are largely the same as the ones I've been flying but have a few minor tweaks and corrections here and there.
I forgot to mention before that you will more than likely need to make a new tail control rod to use these frames as the larger cyclic servos force the battery further forward than most people probably have it on a stock Furion. This means that my fixed tail servo mount is further aft than most probably have on their stock models to help with the c/g.
Old 02-19-2012, 08:43 PM   #25 (permalink)
I may still get the custom head block made but I think the bigger problem is blade grip ball binding. (say that 5 times fast )
Anyway, I'm thinking about getting some L shaped parts made to rotate the ball on the blade grip 90 degrees so that it won't bind. These should be fairly inexpensive to have made. So, I'm taking suggestions on which balls to design them for and how far the screw hole should be spaced from the feathering shaft center.
I really like the Align balls since they come with a hex hole broached in them for easy mounting. I believe the shortest Align ball is a similar height to one of the MA Furion balls so both may work.
Old 02-19-2012, 09:13 PM   #26 (permalink)
Here is a quick rendering of what I am thinking of.
Name:	Grip Arm 1.jpg
Old 02-22-2012, 12:44 PM   #27 (permalink)
Looks good, I would add a nice fillet to the inside corner on this side. It would not really add to the cost.
Rob
heli21 is offline        Reply With Quote Quick reply to this message
Old 02-24-2012, 10:48 AM   #28 (permalink)
I've drawn it both ways. I had a 0.0625" radius... I think I'm going to make the prototype part without the fillet since it will be easier to make that way.
Old 03-04-2012, 08:49 PM   #29 (permalink)
Just to update those following this project....
There were a few production delays (tooling, material, etc) for the shop producing the frames for me. Either way, I believe they have been cut and should be shipped soon.
Old 03-08-2012, 09:07 PM   #30 (permalink)
My friend tells me that the first batch of the frames finally shipped.
In other news, I made some custom grip arms.
Old 03-09-2012, 03:11 PM   #31 (permalink)
Your grip arms look awesome ! If you make any extra I would like to buy a set .
zept is offline        Reply With Quote Quick reply to this message
Old 03-09-2012, 03:49 PM   #32 (permalink)
I've looked into getting some made by a shop here in the US but it is expensive. If I recollect correctly, the quote was around $30 per pair for a batch of 10 pair. If there is sufficient interest, I could probably get some made for less but it may take time to find the right shop.
The parts shown above, I made quick and dirty just to see how they looked, fit and flew. In other words, production parts would look even better.
Old 03-09-2012, 08:39 PM   #33 (permalink)
I was supposed to have the first batch of frames in hand today but the USPS decided otherwise. So, I should have them tomorrow when I stop by the local office to punch a hole in someone's head.
Old 03-10-2012, 10:41 AM   #34 (permalink)
I redid my v-bar setup with the new grip arms this morning and while the collective/cyclic setup values are still relatively high, they are a bit better than before and the pitch range without binding is dramatically improved. I can get ~24degrees (max collective + max cyclic) without anything binding up.
As soon as I have the V1 frames, I'm going to transfer all my parts over and take some new photos. Hopefully, it won't take very long as only minor changes were made between the last beta and V1.
Old 03-10-2012, 12:09 PM   #35 (permalink)
Got some goodies in the mail a bit ago!
Below the stack of frames, you can see the little washers for the Hitec HS5084mg mounting tabs, the horn adapter arms which get screwed to the small wheel horns, the little rear tray that can be installed below the tail box and the longer anti-rotation bracket. Seems my friend made a few extras of each of the smaller parts in case they got sucked up by the dust collector.
As I said earlier, to install the extra tray you'll need 'MA130-230 CNC Frame Spacer'. In the photo, my esc is strapped to this tray. It is perpendicular to the main shaft so you could mount a fbl unit to it if you wanted.
Old 03-10-2012, 07:06 PM   #36 (permalink)
Okay, here are the photos with the V1 frames. I'm really happy with the fit and finish on these things. Knowing this project was for a MA heli, I really wanted them to go together perfectly.
I used my flo orange zip ties so you could clearly see where the zip tie cut outs are located.
Old 03-12-2012, 10:11 AM   #37 (permalink)
Are you going to have the headblock made aa well?
WessCo is offline        Reply With Quote Quick reply to this message
Old 03-12-2012, 11:14 AM   #38 (permalink)
Probably not since the G5 + Align driver is much more economical and works very well. I'm still waiting to hear back from a few shops on the grip arms.
If the G5 block becomes unavailable in the future, I may look into it more.
Old 03-12-2012, 05:36 PM   #39 (permalink)
Just got the first quote on the grip arms back. Looks like they would be around $25 per pair shipped. If there was sufficient interest, I could get the price lower (larger batch).
Old 03-15-2012, 08:21 AM   #40 (permalink)
So the frames are still $40 shipped if anyone is interested in a set.
On the other hand, I received a quote on a very large batch of the grip arms and I may go ahead and have them made. If I have this batch made, I could lower the price significantly but I need to know that people want them.
