450 Class Electric Helicopters 450 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
01-08-2013, 10:26 PM | #1 (permalink) |
Hobbyking just released DFC head!
Nice - an exact Align DFC head copy for only $23.50!
Now if they only had it in the USA Warehouse.... hurry up HK!!
XL Power 520 / Spektrum DX6 |
01-08-2013, 10:35 PM | #2 (permalink) |
Love the turnbuckles on the DFC arms too...
That way, you arent caught in between degrees... Align needs to copy the copiers... |
01-08-2013, 10:46 PM | #3 (permalink) |
Oh nice...when it says its available globally,not in USA/Canada warehouse,what does that mean ?
Thanks again. |
01-09-2013, 12:51 AM | #4 (permalink) | |
That means you have to wait a long time for shipping. I've read that if you want it in a reasonable amount of time you need to select EMS shipping option (more expensive) Therefore it would be best to order multiple things at once from the overseas warehouse (suchs as batteries and the YEP45, SERVOS and various 450 parts or FULL KIT since you're already paying for the shipping)
01-10-2013, 07:25 AM | #5 (permalink) |
Interesting, thanks for posting that. It even includes the swashplate. Time will tell how the quality is. But it could provide an inexpensive way to try DFC.
I'm curious about it (just have the FBL head), but I'll probably wait until I need to replace the head before I'd change. If I had to choose where to put my upgrade $ at the moment, I'd probably stretch, before going DFC.
Gaui X5, iKon, Edge 100, CC BEC Pro. Tarot 450 Pro FBL, Mini VBar, Ice Lite 50. BL mCP X, Nano QX, FrSky Taranis, iCharger 308Duo. |
01-10-2013, 12:26 PM | #6 (permalink) |
I get lost with all of the 450 variants ( v1, v2, se, sport, pro, etc...)
Will this work with all of them? I have a EXI frame and flybar head, with align electronics. |
01-10-2013, 03:49 PM | #7 (permalink) | |
I'm usually about 2 weeks with the 'registered intenational' $3 service, or sometimes closer to 3 weeks with the $2 standard international. I usually go for the standard since I have to go to the postal outlet and sign for the 'registered' ones and the standard just show up in my mailbox.
TRex 250 DFC | TRex 250 DFC (Scale) 2 @ TRex 450 DFC | TRex 450 Pro 3G (Scale) TRex 550 DFC DX8 + Telemetery on all |
01-10-2013, 06:32 PM | #8 (permalink) |
^^^^^ Thanks bud,I'm still contemplating.
01-11-2013, 07:44 AM | #9 (permalink) |
can this be fitted to the hk450 v2? i like this one as it has even fewer parts than even a normal fbl head.
01-11-2013, 09:54 AM | #10 (permalink) |
The clone has (( THRUST BEARINGS)) !!
Does the Align DFC head has those ? Anyone Know ?? They should have used Delrin on the control arms to absorb vibration ; would have bin Much stronger with No weight penalty !! Bille |
01-11-2013, 10:03 AM | #11 (permalink) |
Yes the align dfc does have thrust bearings.
T-rex 450 dfc super combo, cc phoenix ice lite 50. T-rex 450 se v?, hs-65mgs, Dx 7 T-rex 250se, blade msr, blade nano cpx, Realflight 5.5 |
01-11-2013, 11:02 AM | #12 (permalink) |
Everything I've read says the align unit does NOT include thrust bearings, feathering shaft, or swashplate. This hk unit does.
01-11-2013, 11:38 AM | #14 (permalink) | |
The align DFC head is just an upgrade,not a full kit.Unless you go with the actual 3G FBL kit. I bought the DFC for maybe future upgrade on my F3C V2.Below is a pic of all you get when you buy the align DFC head upgrade. |
01-11-2013, 09:19 PM | #15 (permalink) |
Sorry. I thought the question was asking if the head contained thrust bearings not if the upgrade came with them. My kit was a dfc so i don't know anything about the upgrade.
08-03-2015, 01:09 PM | #16 (permalink) |
Can anyone confirm parts interchangeability on these heads with the original Align head? Does it use the SE V2 feathering shaft?
08-11-2015, 04:22 PM | #19 (permalink) |
Ended up finding replacement parts, figured I'd post up here since this is where a google search leads to:
Feathering Shaft - HK PRODUCT ID: GT450pro-143 - GT450PRO Feathering Shaft (51x4mm) 2pcs Main Shaft - HK PRODUCT ID: 155000125 - HK-450 PRO Flybarless DFC Main Shaft (110x5mm) Control Arms - HK PRODUCT ID: 9155000268-0 - Assault 450L/450DFC TT & Belt Flybarless 3D Helicopter Control Arm (2pcs) It also appears the head is nearly identical to the Align model H45162 though I can't confirm the parts are 100% interchangeable. |
