Hurricane 200 Discussion and support of the Gaui Hurricane 200 |
07-28-2014, 06:55 AM | #1 (permalink) |
HELP! - Mainshaft removal problem
I have a 200 and 200 V2. Got both secondhand, "RTF" - so didn't build them myself. (have built numerous other helis)
Despite removing all collars I cannot extract the V2 Mainshaft. It will slide freely up and down about 5mm within the one-way bearing, but stops solidly in both directions. I can see no burrs. I note on spare shafts there is a hole near the lower end which is hidden within the main gear. I see no use for this hole on the (rudimentary) manual - might it contain a pin? Might a ball or roller bearing from the one-way have got loose into this hole? If no solutions will have to dismantle frame, but am reluctant to do this if there is a simple explanation. Many thanks for any help. Philip |
07-30-2014, 12:47 PM | #2 (permalink) |
My way to remove my bent mainshaft is, I first uninstall the head system and the bottom plate and then hitting down the mainshaft carefully not too hard using a handle of screwdriver.
JR Vibe 50 NEX FBL - HC3-SX Gaui NX4 - HC3-SX JR 450 Forza - Spirit Pro Rave 450 FBL - Spirit FBL |
