Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600/600 PRO Aftermarket Upgrades and Mods
600/600 PRO Aftermarket Upgrades and Mods Align T-REX 600/600 PRO Aftermarket Upgrades and Mods Support
Old 06-30-2010, 09:02 AM   #1041 (permalink)
Default Help! Motor just shakes
I'm just getting everything set up and attempted my maiden voyage and ..... big let down. Upon attempting to spool up, the 4025-630 shakes for about 2 seconds and then stops. It acts as if one of the motor wires is not connected. I resoldered and changed the bullet connectors to no avail. I connected my old Align motor and us spools up and spins fine.
Is there something in my Castle link programming that I should look for? Bad motor? I dupicated the first castle set up on page one if this thread....
strokermtr is offline        Reply With Quote Quick reply to this message
Old 06-30-2010, 09:41 AM   #1042 (permalink)
hows your gear mesh ? loosen the motor mounts and move it back from the main gear. Now try to run up your throttle..what happens
SkinWalk3r is offline        Reply With Quote Quick reply to this message
Old 06-30-2010, 10:01 AM   #1043 (permalink)
Originally Posted by rceccleston View Post
Thanks.
I've removed the motor completely from the heli and attempted to spool it up on the table..:... same results. It shakes for a second or two and is then shut down, buy the ESC I think.
Old 06-30-2010, 10:18 AM   #1044 (permalink)
Since you have confirmed there is not an issue with the esc, it looks like you may have a faulty motor.
Recommend contacting your dealer for a replacement.
T-Rex 700e 'Chrome Edition', Skookum 720, Turnigy , Scorpion motors, Align servos. DX8 with Turnigy 4000Mah Li-Po
rceccleston is offline        Reply With Quote Quick reply to this message
Old 07-01-2010, 08:15 AM   #1045 (permalink)
I agree. I spoke to Lucia at Innovative rc. And he claims to have never had a bad Scorpion motor. He also schooled me on how to test the windings and connections of the motor. Everything checks out. I'm left to conclude that this is definitely a bad motor. It's just a bummer to go through the R M A process as helihobby is across The country from me = week long shipping. It will take 2 weeks. One week to return the motor and another week waiting for the new one to arrive. I wished I could find it closer. I'd purchase another motor and fly this weekend.
Old 07-01-2010, 12:56 PM   #1046 (permalink)
Co2m is offline        Reply With Quote Quick reply to this message
Old 07-01-2010, 04:51 PM   #1047 (permalink)
spin the motor with your fingers, that does it some times, you may also have a bad solder joint somewhere
P.I.Engineer is offline        Reply With Quote Quick reply to this message
Old 07-01-2010, 07:06 PM   #1048 (permalink)
how do I get these KBDD paddles on ? just twist them on till it bottoms how do I lock them down..super glue ?
Old 07-01-2010, 08:30 PM   #1049 (permalink)
I'm late to this party... Align motor is not rated for 12s. Are you sure your packs are wired correctly for 12s? I know it sounds stupid... never hurts to check. One other thing you could try is reversing the spin of the motor in the CC software and see if that makes any difference. Motor may be seized up.
Rush 700 * Trex 700N x 2 * Trex 600Pro * Goblin 570 * 450L Dominator - V-Bar on all
AMA #934662
caralmar is offline        Reply With Quote Quick reply to this message
Old 07-01-2010, 08:39 PM   #1050 (permalink)
GOOD POINT !
hey is your ESC set up for 12s..just checking !
Old 07-01-2010, 11:27 PM   #1051 (permalink)
The motor is definitely not seized as I can turn it by hand. When I tries the Align motor with my ESC I only used one battery 6s. The proposed idea of the ESC not being set for 12s is very possible as I have no idea whY you're referring to. Please explain how to set the ESC for 12s.
Old 07-01-2010, 11:29 PM   #1052 (permalink)
Yes. My packs are definitely wired in series.
Old 07-01-2010, 11:39 PM   #1053 (permalink)
Ok, cool, just checking! The ESC doesn't really have a "12s" setting. The only battery section I've found is under the governor settings in the Throttle tab. If you set up your battery info there, it will show up in the settings page when you print the settings from the menu. You can then go back to fixed endpoints and the battery settings are kept. I'm not sure that you need to fill this out if you're running on fixed endpoints.
If the motor isn't seized up and your ESC is good, and your packs are in series and outputting 50v or so freshly charged, then I dunno man, does sound like your motor may be toast. Anyone in your club fly the same motor? Might be a good test to see if it spools up fine with your ESC, just to rule out the ESC... as they're easier to source locally than the motor.
Good luck!
AMA #934662
Old 07-02-2010, 02:04 PM   #1054 (permalink)
my aileron rolls feel anaemic. I even have the KBdd paddles.
Old 07-03-2010, 02:33 AM   #1055 (permalink)
Default Progress
After several calls to Inno8ative (Scorpion Motors) and Castle Creations, my problem has been tied down to the ESC. Their customer service is great. Castle shipped out an ESC to me immediately with return packaging for the bad ESC included. No expense to me at all! Gil at Castle went over all my ESC settings and thoroughly check my ESC over the phone.
Old 07-03-2010, 12:12 PM   #1056 (permalink)
How much aileron throw do you have (pitch wise?)
Logo 500 SK720, 4025-890, CC ICE 100
T-Rex 600 ESP w/3G - 12S, 4025-630, CC ICE 80HV
Blade 400 w/ HS5065MG, CopterX FBL, ICE Lite 50
eRaptor Conversion, 12S, 4035-500, JR 8700g, 3xDS610s
meatbob is offline        Reply With Quote Quick reply to this message
Old 07-03-2010, 05:58 PM   #1057 (permalink)
how do I measure it ..I do have a pitch gauge but dont know how to measure the aileron and elevator throw
Old 07-03-2010, 06:34 PM   #1058 (permalink)
btw - is 2350 rpm high for my stock Align ESP blades ? I coult only find the 14t in 6mm
Old 07-03-2010, 06:59 PM   #1059 (permalink)
First line up the main blades in line with the tail boom, then make sure your flybar is 90 degrees to the main shaft. Next you need to be at center stick, then give left or right aliron and use you pitch gage to see how much throw you have( you should be about 6-8 degrees, some use as much as twelve). Then move the main blades 90 degrees to the tail boom so that your flybar is in line with the boom, then check the elevator throw. I hope this helps......
The day I STOP learning new trick's, is the day I DIE!!
HDX-Align 450
Align 600
climbing-n-flying is offline        Reply With Quote Quick reply to this message
Old 07-03-2010, 08:50 PM   #1060 (permalink)
If you are running 2350 RPM, even 4 degrees of cyclic pitch will spin the heli right around. What are you comparing the roll rate to? A Trex 450? The Trex 600 is larger and suffers from the very real inertia that makes it precise and manageable for me.
I'm running a Revco 13T 6mm pinion from ReadyHeli.
