Go Back   HeliFreak > R/C Batteries and Charging Support > A123
A123 A123 Battery Support
Old 02-15-2012, 08:39 PM   #1 (permalink)
Default how to charge a life pack
just purchased a 2100 mah rx 6.6v i use a tritan 2 charger,should i charge on lipo and how many volts,it only gives me 3.7 and 7.7 to chose from,
bobby77402 is offline        Reply With Quote Quick reply to this message
Old 02-16-2012, 06:08 AM   #2 (permalink)
Need to use A123 setting for charging if the charger has it. LiFe cells are 3.3v.
Team Synergy/Rail Blades, Team Scorpion, VelTye, YS Engines, JAG-RC, Electron Retracts
kcordell is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 03:18 PM   #3 (permalink)
I have a Triton2 and it don't have the option to charge Life packs, you should get a charger that can do Life packs.
|Michalis|
...let the flying be second nature!
acidla is offline        Reply With Quote Quick reply to this message
Old 02-20-2012, 06:35 PM   #4 (permalink)
Default Help please
I just got a 1100 mAh, 6.6V 2S LiFe and when I charge it on the LiFe setting it goes from 6.6v to 7.2v in less than a minute and puts in 20 mAh. Then I'll try to discharge it to storage and the voltage drops to 6.6V within a minute and it takes 20 mAh out of the pack...
What's the deal with these?? I've tried 3 chargers and 2 batteries all the same results.
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote Quick reply to this message
Old 02-21-2012, 02:36 AM   #5 (permalink)
This is normal for Life packs, once they put into operation the voltage drops instantly at 3.3V per cell and stays there for a very long time.
|Michalis|
Old 02-21-2012, 06:14 AM   #6 (permalink)
I changed the discharge cutoff from 3.3v/ cell to 2.7v/ cell and pulled 500 mAh out of the pack. It stayed around 6.4-6.0 while discharging. I wasn't expecting them to be so different from LiPos .
Old 02-21-2012, 07:32 AM   #7 (permalink)
Keep in mind that 6Volts (3V/cell) is the minimum voltage, beyond this point the voltage will drop like a rock and you will not have any control.
You can use up to 70% of the capacity without affecting voltage much.I usually use around 50%.
|Michalis|
Old 02-21-2012, 08:27 AM   #8 (permalink)
I'm actually using the pack as a buffer with my BEC at 7.2V. I just wanted to make sure the battery was working properly before I installed it. Thank you!!!
Old 02-21-2012, 09:20 AM   #9 (permalink)
No worries mate
|Michalis|
Old 04-03-2012, 03:59 PM   #10 (permalink)
That's dandy...now how do we tell what 50% is? On a LiPo we judge by voltage, but that doesn't apply linearly to a LiFE. What do we do, measure it in mA that gets applied during charging?
MeatRocket is offline        Reply With Quote Quick reply to this message
Old 04-03-2012, 09:45 PM   #11 (permalink)
Basically yes, fly a few flights and charge the pack, this will show you how much you use per flight then select number of flights you will fly to get to about 70% used.
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 08-12-2012, 07:11 PM   #12 (permalink)
I'd just fly one flight how you typically fly at first and recharge. This will give you a good starting point. Load checking is no good with A123. You'll get 6.67 until the battery is almost dead.
pferg is offline        Reply With Quote Quick reply to this message
Old 08-17-2012, 06:00 AM   #13 (permalink)
I bought a 3s LiFe for my TX and I still do not understand a life and thus I'm afraid to use it inside my TX. Same issues that it will drop from 10,8V really fast and input mAh is small etc.
3,6 x 3 = 10,8 V
3,3 x 3 = 9,9 V
3,0 x 3 = 9 V
When is a LiFe full and when is it empty, at what voltages? What should be the warning voltage level for a LiFe?
Thanks All,
Raimo
Align T-Rex 600EFL Pro DFC, 3GX v4.0, TM1000; Align T-Rex 600N Pro DFC, 3GX v5.0; DX9
Riff is offline        Reply With Quote Quick reply to this message
Old 08-19-2012, 09:05 PM   #14 (permalink)
3,6 x 3 = 10,8 V
3,3 x 3 = 9,9 V
3,0 x 3 = 9 V
Thanks All,
Raimo
3.6V is full but it will drop almost immediately to ~3.3 where it will stay until it is almost flat. I would set the alarm for 3.2, but be aware that is a charge now value, you may only have 10mins or so left at that point.
IMO the best bet is to charge it after every flight session or few (depends on how much you fly) no reason to let it go almost flat first.
-DX8
Old 10-09-2012, 08:56 PM   #15 (permalink)
3.0V per cell is still a lot. The lowest discharge limit is 2.0v.
http://www.multirotorforums.com/showthread.php?t=5669
goraplx is offline        Reply With Quote Quick reply to this message
Old 10-10-2012, 10:41 PM   #16 (permalink)
True, but a LiFe cell at 3V is pretty much flat, voltage drops off very fast from that point.
-DX8
