BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
08-30-2011, 08:58 PM | #1 (permalink) |
V3, loss control of servo
Upgraded to V3 firmware from V2. Redoing setup ran into few issues.
- Binded to dx6i - Selected Receiver type as purple for Spectkrum satellite (OrangeRX Satelite) - Cofnfigured failsafe - Power off MB - Turn on power and then went in to run setup. - Went in to do setup When I get to step E for tail endpoints, servo don't move and tail won't move. Same with step G. Next problem after step H, setup ends and there is nothing that I can setup. Did I miss anything, wrong receiver? I am using the optional specktrum adapter for Orange RX. According to information, I can now plug orange rx directly to MB, but manual saids still need to use optional adatper. Also do I have to manual configure channels? ' |
08-30-2011, 09:05 PM | #2 (permalink) |
Sounds to me your in parameter menu and not setup menu
To enter setup menu, push and hold the button until the blinking light become solid. |
08-30-2011, 09:05 PM | #3 (permalink) |
you were not in set up mode but in parameter mode! That is all
08-30-2011, 10:25 PM | #4 (permalink) |
You guys are great, thanks that was it. Hope I didn't mess up my parameter setup, since I tought i was in setup.
08-30-2011, 10:42 PM | #5 (permalink) |
Takes all of 2 minutes to reset parameters or just cycle thru the parameter lights and se if the correct colors and or flashes show up
08-30-2011, 10:44 PM | #6 (permalink) |
yep, just did that but confuse on step A or parameter setup. It doesn't explain what color is default, so I just left it at red. Everything else set color back to default for now.
08-30-2011, 11:11 PM | #7 (permalink) |
"A" allows you to "level the swash plate" there is not color led indication. If your heli does not climb straight up you can adjust the swash plate from that menu.
08-31-2011, 03:47 AM | #8 (permalink) |
Parameter step A re-calibrates G, and vice versa, it mentions it in the V2 manual. I haven't looked in the V3 manual but I assume it is there too. What this means in practice is that if you then re-visit G and get it all nice and level, you will in effect have reset parameter A as well.
I know you have re-done it now, but for clarity for others, if you have been in the wrong menu, and configured things, thinking you are doing something else, you have to go back over them or they will likely be at values that you did not want or expect. I know because I have done it too. Cheers Sutty
Regards, Sutty BeltEXI, mCX, mSR, 4G3, FBL Trex250SE µB, FBL Trex450Pro µB, FBL Trex550e VX1 Pro, FBL Trex600ESP VX1e, Parkzone P51D, QRX350Pro |
