Old 04-14-2009, 02:22 PM   #1 (permalink)
Default Vibration problem after rebuild
This evening I have replaced the Head Block/Rotor houseing. I have also put on the new blades and a new feathering shaft. But I find when I throttle up the helicopter vibrates quite badly just before takeoff and still slightly vibrates while in the air. Also when I come to land and power down it does exactly the same thing. Can anyone put any light on this please?
Jez
OneLifeBoard.com - Discussion forum about relationships, health, living, university and life in general. Built up from the remnants of the BBC One Life sunday surgery site, we exchange information and advice on topics that matter to you!
JezUK1 is offline        Reply With Quote Quick reply to this message
Old 04-14-2009, 02:34 PM   #2 (permalink)
Is the main shaft bent? That is hard to see by eye after a crash.
The E-flite blades (not sure if that is what you are using) more often than not are out of balance brand new - at least that is my experience.
Fendbass22 is offline        Reply With Quote Quick reply to this message
Old 04-14-2009, 02:37 PM   #3 (permalink)
No sorry I forgot to say its a brand new shaft. I have never had any problums with the stock blaes before. hhhmmm
Jez
Old 04-14-2009, 02:42 PM   #4 (permalink)
first off did you put the brass step washers back in between the flybar frame and the seasaw flybar holder?
you may loosen the jesus bolt and wiggle the head to make sure its seated properly
did you messure the distance between the flybar frame and the flybar paddles for equal distance.
did you put back the 4 shim`s and 1 step washer perside on the feathering shaft between the headblock and the blade grips
how tight do you have the blades
Crashs come easy Patience does`nt
retired the 3 year old blade400
fast400 is offline        Reply With Quote Quick reply to this message
Old 04-14-2009, 02:55 PM   #5 (permalink)
I also had a set of brand new eflite blades and they were way out of balance. Also check the first main bearing on the main shaft, its usually the first one to be damaged in a decent crash.
conetica is offline        Reply With Quote Quick reply to this message
Old 04-14-2009, 03:07 PM   #6 (permalink)
Were or what is the jesus bolt which you talk about wiggleing?
Yes the flybar frame and the flybar paddles are equal distance.
I did put back all the shims etc into the feathering shaft.
The blades are not too tight or too loses.
Do you have a pic of this so I can see were they should be?
Jez
Old 04-14-2009, 03:38 PM   #7 (permalink)
the jesus bolt is the screw with the lock nut that hold`s the head on the main shaft.
and make sure you have these line pins in the washout block
first pic is the brass washer i spoke of, the step goes towards the bearing just like ones on the feathering shaft
second pic is the bolt i spoke of
third pic is of the alignment pins or whatever their called
ID:	91740   Click image for larger version
ID:	91741   Click image for larger version
Old 04-14-2009, 04:02 PM   #8 (permalink)
You balanced the blades and centered the flybar to within a millimeter?
Old 04-14-2009, 04:03 PM   #9 (permalink)
Wow your a star.
Yes I have the brass washer all in place both sides.
Yes the alignment pins are in place.
As for the bolt, what Im I feeling for? Should the head move a bit?
Jez
Old 04-14-2009, 04:08 PM   #10 (permalink)
Wow your a star.
yes loosen the bolt and wiggle the head to make sure you have it seated on the shaft properly.
and if youve replaced the feathering shaft the mainshaft. and everything else is in line, then like blade tightness and balanceing are good. then you have a serious problem somewhere.
Old 04-14-2009, 04:24 PM   #11 (permalink)
Looks like a trip to my LHS
Jez
