Blade 450X Blade 450X Helicopters Information and Help |
07-16-2013, 01:10 AM | #1 (permalink) |
Elevator Lever Horn Slop
Has anyone noticed there is a little up and down play with the black elevator control lever between the frames?
07-16-2013, 08:00 PM | #2 (permalink) |
After crashes, this horn sometimes rotates and the hex locator gets rounded off...could easily cause slop.
Also it could be bad bearings or maybe a damaged/worn frame (where it locates the bearings).
12S 4035-500 Gaui X5 Formula VBar, 6S 2520-1880 Gaui X3 AR7200BX, Phantom 3 Professional |
07-16-2013, 11:16 PM | #3 (permalink) |
Yes... thank you! The horn had rounded edges to cause the play. Just put a new one on and no slop.
07-17-2013, 04:55 AM | #4 (permalink) |
Glad it was an easy fix!
07-19-2013, 09:50 AM | #5 (permalink) |
heh..I just posted about having the same issue in another older thread before I saw this one.
https://www.helifreak.com/showthread.php?t=416115 It seems to be going around. I wonder if it has something to do with the hotter weather causing the plastic parts to be softer and easier to strip...
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon) Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi) AMA Member, HCAM Member |
