Old 09-21-2015, 07:07 AM   #1 (permalink)
Default Running a 6S 450L on 3S advice please.
Ok, I have a 6S 450L, from what I can see, the only difference between the 3S and 6S kits is the motor and main blades, please correct me if I am wrong. Any way I have enough 3S packs where I would be stupid to not run this heli on them, so want to run this heli on either 3S or 6S. Am I able to do this with one setup, gearing and so on. If so, what would ou guy recommend? I am running stock electrics.
Necroscope is offline        Reply With Quote Quick reply to this message
Old 09-21-2015, 10:36 AM   #2 (permalink)
subscribed..... I am looking at buying a similar setup and was curious as well
lycokayaker is offline        Reply With Quote Quick reply to this message
Old 09-21-2015, 05:06 PM   #3 (permalink)
The 6s Dominator kit also has different servos that are a bit stronger to deal with the bigger disc.
You can run the 3s packs on the stock 6s helicopter. It will be a very low headspeed with very low power and torque. Good for learning to use the collective precisely though and longer flight times.
Old 09-22-2015, 02:54 AM   #4 (permalink)
me too
Going on some advice in another thread, I just ordered a 450L 6S last night, should arrive by the weekend. Also the 6S appears to have the Gpro as standard whereas the 3s is advertised with the 3GX
I have about 7 3S packs that I would like to use. And I'm still learning to fly, so don't want high head speeds, so the 3S batteries should hopefully fit the bill.
Darren@Oz is offline        Reply With Quote Quick reply to this message
Old 09-22-2015, 03:06 AM   #5 (permalink)
I'd suspect that you would hardly get off the ground with a 3s battery in a 6s dominator. Rotor RPM will be close to half of what's possible on 6s so even if it does fly it will be VERY sluggish. Very low headspeed is also much harder to fly because the tail hold is sloppy and you don't have the collective 'punch' to get out of trouble.
It would be easy enough to convert a 6s 450 Dominator to 3s by changing the motor to one with much higher kV, but it's not possible to have a heli that will fly (with good 3D performance) on either a 6s or 3s battery.
Old 09-22-2015, 03:32 AM   #6 (permalink)
Ok, what about the reverse then, running a 3S on 6S?
Old 09-22-2015, 03:35 AM   #7 (permalink)
Originally Posted by Darren@Oz View Post
me too
Yeah, forgot about the different fbl systems, doesn't really effect me because I am running a Skookum 720 on mine and will also be running a GPS unit as well.
It may be the case where I eventually buy a good clone 450l frame etc, and kit it out with Align hardware for 6S and change the motor over on this one. Can't seem to find a bare bones 450l Align kit.
Old 09-22-2015, 04:04 AM   #8 (permalink)
Putting a 6s battery in a 3s heli would send the current through the roof and destroy the motor and/or ESC is very short order... definitely a bad idea.
Old 09-22-2015, 05:14 AM   #9 (permalink)
I thought the same, hence I was originally going to buy a 3S.
But there is a video someone posted in the 450 picture thread of guys flying 450L 6S on 3S batteries. They seemed to fly well. Also someone else mentioned in the same thread they fly on both 3S and 6S packs no problems. Just can't do the hardcore 3D stuff on 3S- which suits me just fine because I couldn't do that stuff even if I wanted to lol
Old 09-22-2015, 05:51 AM   #10 (permalink)
That suites me fine as well. I think I will just give it a go and see what happens, a throttle and pitch curve for each voltage I guess and go from there.
I will probably build a second one at some stage but don't really see the new for it right now.
Old 09-22-2015, 10:40 AM   #11 (permalink)
It definitely works and you can get off the ground. As shown. It will require a very skilled collective management to fly like that though.
NEW Align TRex 450L - LOW RPM (3s) 3D Flight by Ben Storick (5 min 26 sec)
Old 09-23-2015, 01:04 AM   #12 (permalink)
New Align TRex 450L - LOW RPM (3s) 3D Flight by Ben Storick - YouTube
Hmmm, that could be my down fall. Any way thanks for the video it was quite impressive.
Old 09-23-2015, 01:38 AM   #13 (permalink)
me too.... I'm still a learner
I was going to buy a 3S (as I already have 7 near new 3S packs) butit was recommended by a couple of other people in the other thread that I should buy the 6S and just run 3S batteries...
worst case I'm going to have to stretch the budget to buy 1 x 6S battery pack to get me started....
Old 09-24-2015, 11:58 AM   #14 (permalink)
So i have been flying the 450L 6 cell for almost a year now and now currently playing with low head speeds...i did scrap the stock ESC and am now using CC 50 light.
6 cell has mad head speed. About 3500 rpm on 100% tc. I was using about 85% and my flight would start out with 3200 rpm and dip to 3000 by the end of flight landing at 5:30 min. Not using the governor.
Im now using 70%....and still has plenty of head speed to do light loops, rolls and slow climbing. But getting 7 min flight time.
I read that if going to a 3 cell set up on the 6 cell dom, you would need 100% tc and hi C rating and double your milli amps. So say your using 1450's 6 cell...you would need about 3000 3 cell with a hi discarge rating.
I have not done it yet, but i would guess that if you can just lower your head speed like i am and not damage the ESC or packs you would be just fine.
My packs are coming down a little warmer than when i was running 85% but my NON free whealing ESC is still at the same temps. And im flying in 90* degree weather.
Food for thought......
adjday is offline        Reply With Quote Quick reply to this message
Old 09-25-2015, 02:18 AM   #15 (permalink)
I'm starting to think I should have stuck with my own instinct and gone with the 3S version. My 6S just arrived today.....
I didn't want to buy 6S packs as I already have a pile of near new 3S packs. But as a beginner, who is still struggling to fly a 450, I'll be dirty if I crash the heli on it's maiden flight because it's a compromised setup.
I guess I'll just have to bite the bullet splash out more money to buy a couple of 6S packs and tame the insane headspeed down as much as I can.
Old 09-25-2015, 08:29 PM   #16 (permalink)
If your that worried about the 6s vs the 3s then you can just buy the dominator 3s motor (60 bucks new, cheaper on here if you can find one). But really, if you crash, it wont matter which motor or which hs you have. The damage will be just about the same. Running a 3s on a 6s motor is fine. Espeically if your just hovering around. A good setup of your fbl unit will give you a good platform to operate from. If you need help setting ir up, just post a question. There are plenty of people here that'll be more than happy to help.
(I.Y.A.O.Y.A.S.)
Old 09-27-2015, 04:16 AM   #17 (permalink)
Another way, if you don’t worry much about weight increased, and you willing to use your 3S batteries. You will need 2 packs of 3S battery, using Y connector to connect 2 of them in series. Your 2 x 3S batteries (@11.1v) will become 1 x 6S battery (@22.2v). This can drive your 6S motor.
First 3S pack inserted in battery slot, the 2nd one is under skid landing tied with battery hook&loop fastener.
Sam19600 is offline        Reply With Quote Quick reply to this message
Old 09-28-2015, 08:07 AM   #18 (permalink)
thanks for the suggestions
I've decided to go with Necroscope's suggestion.
I just ordered a 3S motor. It cost me $60, but it's going to save me a lot of headaches and I'll always have the 6S motor to upgrade to when/if I ever get to a skill level to utilise it.
Old 09-28-2015, 11:03 AM   #19 (permalink)
I bought a 6S Dom because I wanted a GPro and the better servos. But I fly with my 3S LiPo packs which I already had. I just put a 3S motor in it and 325mm main blades (I don't know if a 3S setup can handle 360er blades)
Yilld is offline        Reply With Quote Quick reply to this message
Old 09-29-2015, 01:44 AM   #20 (permalink)
Do remember to set your timing to high if using the default esc with the 3S motor. Some have reported motor lock ups during flight with medium timing.
Goblin Black Thunder TGY 725MG, BK 7006HV, XNOVA 4525-560KV, Spirit Pro Goblin 500 Sport - KST, HW 100V3, Quantum 1200KV, Spirit Pro, Trex 450L, Spektrum DX9
jgiannakas is offline        Reply With Quote Quick reply to this message
