Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion Electric Motors, Gearing, Speed Controls, Gyros, Receivers and Other Electronics Discussion |
07-31-2015, 01:08 AM | #1 (permalink) |
Scorpion 3226 14 pole can / cooling for a 42mm can
Was planning on getting a 3226 -900kv motor rewound to around 725kv and felt like in going to such a low KV, I would be better off running a 14 pole can.
I know the 3026 has a 14 pole can available. I anyone aware of a 14 pole can for the 3226? Second I am currently running a 4260 600kv that does not have an integrated cooler on the bottom like a typical heli motor. However it does have cutouts on the backplate that would match a standard cooler although they are not deep enough to just put a flat plate on them. It has a standard 4 bolt pattern on the bottom 4 -2mm I think where a cooler or prop adapter could be mounted. Question is does anyone know of a 42mm integrated cooler that has a 4 bolt mounting patrern? Cobra motors offers coolers that fit their motors with a 3-bolt pattern this is as close as I have found? I don't want to ask for either of these In the wanted section if they do not exist.
MSRX CX450 Black Angel Stretch DFC -HW 50v3, Hyperion 2221-6 3dx450b3 Scale Huey Rescue, TGY Sk3 3600kv, Yep 45a, Robird, CX rigid 3 blade head Protos Carbon Stretch, MSH Scorpion, YGE, Ikon |
