Old 10-02-2015, 04:24 PM   #1 (permalink)
Default Anti-rotation Bracket
Hi Gang,
I am down to the final strokes of completing a 450 SE V2 DFC conversion. I am just in the process of putting the head together and leveling the swash. Most everything is done so now comes the fiddle work. I ran into a snag, (Now THERE is a surprise) with the anti-rotation bracket. I bought the new swash plate with the 90 degree offset inner ball links and it would seem that the stand-offs that they lower balls screw into are beefier and protrude about 2mm more (when referenced from the main shaft) than on the stock fly-barred swash. This means that there is less clearance for the anti-rotation shaft. When I just set it up it back ball link on the anti-rotation shaft will bind ever so slightly in the groove on the bracket in full negative. I can think of a couple of solutions like sanding the groove in the bracket or hacking the frame a little to move the bracket back but I was wondering if anyone else has had this problem and what they did to solve it?
Thanks,
Dan
Dan MacKay is offline        Reply With Quote Quick reply to this message
Old 10-02-2015, 06:00 PM   #2 (permalink)
I had a similar issue. I simply took a file to the groove in the anti-rotation bracket until there was no binding.
Oxy 2, Gaui X3 #1, Protos 380, Gaui X5, Synergy 766, Specter 700
Oxy 2/X3/Protos 380/X5/766/Specter 700 Consecutive Successful Flights (Current) = 32/16/12/145/7/50
Consecutive Successful Flights (Max) = 145
macdad is offline        Reply With Quote Quick reply to this message
Old 10-02-2015, 07:13 PM   #3 (permalink)
Hi Macdad,
That is likely what I am going todo as well. Just seeing if someone had a better idea or substitute part.
Dan
