Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > Banshee Helicopters
Banshee Helicopters Banshee Helicopter Support
Old 03-22-2014, 03:23 AM   #1 (permalink)
Default Shaving the banshee
I did a first today, shaved the teeth off the 2nd stage belt (the large one)
I actually changed that belt not long ago to be sure it would not strip.
Going back a couple of weeks i fitted a 4535le motor on 24s, first flights were brutal and crazy. We had speed cup last week so lots of speed runs.
The other day the tail sounded strange, turns out the tail blades had collapsed internally (possibly from fighting torque of 4535 motor).
So i replaced tails and mains also as precaution
Then today looking back i felt it slightly down on power. Thought maybe from cold lipos
Within 30 secs coming out of power loop blades i could count them spinning! It was too late to low to the ground heli hit large weeds but still damaged canopy, frame, some bearings, blades, skids.
Rebuild has began had most
Parts just expressing some the frame and bits to restock.
Replacing all belts as precaution
So now i put back 4530 motor on 14s!
ID:	496465Click image for larger version
ID:	496466Click image for larger version
helicraze is offline        Reply With Quote Quick reply to this message
Old 03-22-2014, 06:34 AM   #2 (permalink)
HC sorry to hear about that, so I guess there is a limit!!!
Helicopters Don't Fly - They Beat The Air Into Submission
Logo 500SE
Minicopter Diabolo 700
Banshee # 45 700 LE and 850
jcflyer is offline        Reply With Quote Quick reply to this message
Old 03-22-2014, 11:33 AM   #3 (permalink)
Default AW: Shaving the banshee
Bad to see that. Have you informed the Banshee guys? What I know, it shouldn't be possible to strip the 2nd stage belt.
Regards, Helmut
Banshee 700 LE #50 and some others ...
KU-HELI7 is offline        Reply With Quote Quick reply to this message
Old 03-22-2014, 04:25 PM   #4 (permalink)
Yes i let them know. Normally i wouldnt mind but replaced that belt to stop this ahhhh
Too much torque for aggressive flying i think. Even tail blades collapsed inside
Old 03-22-2014, 05:53 PM   #5 (permalink)
Sorry!
BTW what do you mean by tail blades collapsed inside? Pictures or more details ?
E.T. - Glowing Finger (0 min 12 sec)
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is online now        Reply With Quote Quick reply to this message
Old 03-22-2014, 06:16 PM   #6 (permalink)
Bugger dude!
Sent from my GT-I9305 using Tapatalk
Darcy Brown- ZenRC Field Rep
RED! Goblin 500, Quantum 4120-1200, BK Servos, from www.zenrc.com.au
ORANGE! Goblin Speed, Kosmik Kool 200HV, Pyro 850-50L, BK Servos, Brain
NevErSn0w is offline        Reply With Quote Quick reply to this message
Old 03-22-2014, 09:41 PM   #7 (permalink)
CHC Benefactor
Attachment 496465Attachment 496466Attachment 496467
Wow!
Didn't realize you were on 24S. Would be great to know the difference. Was it faster? It definitely was fast
Old 03-23-2014, 04:01 AM   #8 (permalink)
Originally Posted by Raptorapture View Post
Wow!
I assume 24S is a typo.
Old 03-23-2014, 04:15 AM   #9 (permalink)
Sorry fat fingers only 14s.
The rail tail blades i heard strange noises from my heli when i check i can move tail blades (try to flex) and it makes crunching noise, they did not delaminate but broken inside for sure
Old 03-23-2014, 06:46 AM   #10 (permalink)
That's pretty serious. Do you think that you had massive tail vibrations while running your tail blades at I'm guessing 14,000+ rpm, or maybe blade stall buffetting that just pummelled them?
The RotorTech tail blades are a lot lighter and should reduced any tail vibrations by quite a bit if that is the reason. Banshee recommends them in their manual.
Mark
Old 03-24-2014, 06:30 AM   #11 (permalink)
Maybe from super wag sometimes after installing x8 tail servo.
Not sure.
My friend faster is trying to get carbon canopy fixed for me and re clear it.
Hopefully parts ship out tommorow
Old 03-28-2014, 03:02 AM   #12 (permalink)
I wonder how 96mm rotortech will go at 1800rpm? My tail gains are fairly low compared to most 700, the tail ratio is 5.5:1
Old 03-28-2014, 07:45 AM   #13 (permalink)
I run my Rail 96 tails at 1750 with low gains and have no issues...
Logo 500SE
Old 03-31-2014, 06:15 AM   #14 (permalink)
Thanks ill try rotortech
Got my banshee parts today, all re programmed and will tach and check for vibes tommorow then test fly
Old 04-16-2014, 07:04 AM   #15 (permalink)
Mr Banshee has been flying fine, done around 6 flights on it since rebuild.
Put some rail 716mm on it and flying really well.
Ive decided to get a new "hairdo" as the wife calls it, insane canopy job custom, banshee is sending a blank white canopy, cant wait to see the result!
Old 04-16-2014, 07:06 AM   #16 (permalink)
HF MR Support
You mean you can't reorder the original CF canopy?
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 04-16-2014, 07:21 AM   #17 (permalink)
Nice!! I cant wait to see the new Hairdo.
Lynh, No you can order another CF canopy.... a bit crappy, thats why mine sits on the shelve
William Blake Team Kontronik
TDR1, Banshee 850 # 22
Diabolo 700
wblombard is offline        Reply With Quote Quick reply to this message
Old 04-16-2014, 08:13 AM   #18 (permalink)
Are there any parts for the Banshee you cant buy?
Old 04-16-2014, 08:41 AM   #19 (permalink)
Nope
Old 04-16-2014, 09:12 AM   #20 (permalink)
So you could build yourself another banshee or of spares? :o
