Old 08-23-2015, 03:11 PM   #1 (permalink)
Default Bought a 250, copterx
So after trashing the pos 450hk , I bought a copterx 250 $51 shipped to the U.S. ! It's the disassembled version couldn't pass up. Any advice for building or tips?
My setup
Elite 45a lite pro esc
Hk401b gyro
Mg 90 servos
Jr 9001 tail servo
Zippy 1000mah
Just need motor, don't want anything over powered either
Dstaks is offline        Reply With Quote Quick reply to this message
Old 08-23-2015, 06:39 PM   #2 (permalink)
Hi, don't use the belt from the kit at all. Get the yellow 'Kevlar' belt ('Super tail belt for T-REX 250').
Norbert
EyP3 is offline        Reply With Quote Quick reply to this message
Old 08-23-2015, 07:12 PM   #3 (permalink)
Norbert
Is it weak?
Old 08-23-2015, 11:10 PM   #4 (permalink)
the belt that came with my CopterX kit was weak and brittle. Replaced it during the build with an Align one but next time will replace with the yellow kevlar one
boykster is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 02:21 AM   #5 (permalink)
>Is it weak?
Yes, as boykster said.
Old 08-24-2015, 10:25 AM   #6 (permalink)
What I've noticed with the clone 250's is the way the belt/tail assy is packaged. The belt is usually coiled then tucked into the boom-end of the tail assy. This crimps the belt cracking the rubber. While fragile the clone replacement belts will work. Just my 2cents .
dmorrow71 is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 10:31 AM   #7 (permalink)
They shouldn't package them like this. Actually, it would be nice if they came completely unassembled.
Old 08-24-2015, 12:37 PM   #8 (permalink)
I put the Align belt on mine during assembly. Put some silicone grease on the belt, only tighten the belt enough to prevent skipping teeth on the gears, and I've had zero belt problems in about 2.5 years of nearly daily flight.
navigator2011
Fusion 180 / OMP Hobby M2 & M1 / TBS Tango 2 / Radiomaster TX16S.
Navi's Channel / Navi's RCGroups Blog
navigator2011 is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 08:31 PM   #9 (permalink)
check the main gear... mine was warped. My feathering shaft wasn't machined properly, main shaft wasn't up to par either. I replaced the swash after first flight. Once the align main shaft, gear, swash and feathering shaft... flew great then very stable. hot glue the gyro
JG6743 is offline        Reply With Quote Quick reply to this message
Old 08-25-2015, 12:57 PM   #10 (permalink)
Hope I have some luck with my kit. We will see!
Old 11-11-2015, 09:52 AM   #11 (permalink)
OP, I'm surprised at your commentary about the HK kit. I have both the CopterX and HK250GT kits. I hadn't gotten around to building the HK kits but just built my CopterX 250 FBL. I had to scrounge a part from the HK kit as there was a dud on the CopterX kit.
The shared parts are the exact same. The bags, the parts, even the screwdrivers are the same. Colors and markings are the only difference. Maybe they just throw in the lower tolerance parts into the HK kits? Dunno.
Anyway, my kit went together pretty well. The tail has less slop than my real Trex. Only notable issues were the canopy, its malformed and hits the swash links and my belt was pretty frayed. I ended up shaving it and using a lighter to get rid of the rest. Yes, I love to live dangerously, but I bet I'll crash it before the belt goes Also some of the ball links are smaller than others and seemed to be in the wrong places, ie elevator was uber tight and head was super loose, reversing them fixed it. .
yakky is offline        Reply With Quote Quick reply to this message
Old 11-19-2015, 10:57 PM   #12 (permalink)
i found that there was a lot off slop inthe head changed it for aftermarket dfc style with that the heli came alive and responded to the sticks quickly
My ex wife gave me an ultimatum Helis or me
t rex 250 pro dfc robird, 450 pro dfc robird,gaui N X 4 mini v bar ,Velocity 50 n2 ikon ,Ely Q 90 ikon taranis X9D
rob221 is offline        Reply With Quote Quick reply to this message
Old 03-29-2016, 12:32 AM   #13 (permalink)
So how are these birds? Can the tail and heads be trusted?
I just got a hold of one, doing kinda a trade for a guy im fixing his and he is giving me one. ive never had a 250 what size battery most of you fly to make them balance well?
they both have cheap HK TP90 ( i think is the number) servos. have to look at tail servos.
well I think his is a real trex 250 mine is a copter x. also got a 450 copter x. same thing anyone know if any parts on it should be changed?
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs.
Old 03-29-2016, 06:58 AM   #14 (permalink)
I don't think there are any parts that need to be replaced before they fly but you will need to check everything over. Especially if someone else built it. But that is true with almost all clones.
Old 03-29-2016, 08:25 AM   #15 (permalink)
+1 to the guy who said to get the Super Tail belt. I got one for mine after my Align belt pooped out (didn't last long...) and it's great. It's never gonna break... ever. The Align ones can break/shred in crashes.
You can get it in the USA, and it's cheaper than the Align.
http://www.infinity-hobby.com/main/p...ducts_id=11595
I also suggest getting an Align hardware pack, and replace every single 0.9mm hex with a 1.3mm hex (thread size is the same so it will fit). It takes a while but it was worth it for me. No more stripped 0.9mm bolts... especially with the clone Cheesium bolts.
http://www.amainhobbies.com/rc-helic...25033a/p158466
Keith - FrSky | OMP | KST | KC3D
Protos 800X Evo | OMP: M7, M4 MAX | M4*2 | M2 EVO*2 | M1 EVO | So Many Airplanes
KC3D LLC - Charge Cases, Starter Adapters, Heli Upgrades, and More
Number is offline        Reply With Quote Quick reply to this message
Old 03-29-2016, 10:59 AM   #16 (permalink)
I've had great luck with the Align belts--I run them rather loose and I coat them in silicone grease, never had a problem. Even so, you cannot go wrong with the Super Tail belts mentioned above by Number, so I just pulled the trigger on two of them.
Thanks, Number, for reminding me about the Super Tail belts.
navigator2011
