Old 03-06-2012, 12:47 PM   #1 (permalink)
Default wich flybarless set up to buy
there are so many they sound wonderful on paper
what is the deal with the skookum unit is says it has 6 axis gyros what are the benafits ?
i have the futaba 8fgs radio should i use the futaba fly barless unit with there gryo
beastx ?
or any othere set up
im looking for ease of use and performance and STABILTY
this is for a trex450p hitec 65 karbonlight cyclic and futaba tail servo
just spent a ton of time settin up the FLymentor. what a PIA
would love to finde something that drops right in with out too much headech
thanks
Bob
kayakboy69 is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 10:17 PM   #2 (permalink)
The Beastx is excellent, easy to use and works great, or if you on a budget the Tarot unit is very good as well, with use of pc link makes the tarot easier.
I have both and very happy.
Good luck
Rick,
Team pilot ,
EGODRIFT, KST, Helidirect, Lynx/Oxy
crickr1 is offline        Reply With Quote Quick reply to this message
Old 03-07-2012, 09:53 AM   #3 (permalink)
+1 BeastX
wrench76 is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 12:13 PM   #4 (permalink)
+2 Beastx
newbheliusr is offline        Reply With Quote Quick reply to this message
Old 03-11-2012, 10:35 PM   #5 (permalink)
Good luck
:+1 here
Goblin 700, Goblin 380, Gaui NX7, T-Rex 700N, T-Rex 450
iKon, because I am connected to my heli. Are you connected to yours?
RCHN #15
PauloG is offline        Reply With Quote Quick reply to this message
Old 03-11-2012, 10:39 PM   #6 (permalink)
beastx
nothinbetr2do is offline        Reply With Quote Quick reply to this message
Old 03-11-2012, 10:48 PM   #7 (permalink)
To those making recomendations what systems do or have you owned or have experience with?
Team Miniature Aircraft
Team GensAce ~ Mavrikk
MXRACERX43 is offline        Reply With Quote Quick reply to this message
Old 03-11-2012, 11:04 PM   #8 (permalink)
3GX, vbar, beast and after this weekend with 5 successful flight ZYX
The ZYX is the best bang for your buck. Specially beginners.
RCHN #15
Old 03-11-2012, 11:13 PM   #9 (permalink)
In my book that gives you a legitimate opinion!
I just think it is all too common in VS threads were users may onl;y have experience with one particular unit and they reccomend it over others they have 0 experince with.
Old 03-11-2012, 11:42 PM   #10 (permalink)
I have 3 copterx and 3 beastx and I think the beastx flies much better. I felt that the beastx is worth paying 5 times as much for.
Mcpx/Trex250/HK450/Protos500
no flybars allowed/Beastx ftw
infamousnation is offline        Reply With Quote Quick reply to this message
Old 03-12-2012, 09:55 AM   #11 (permalink)
I've got 3gx V2 and beastx b3.8. Those two are both good, and the price is the same. But if I need to choose one - of course - beastx. More things to set and tune, and it doesn't feel as cheap as 3gx. Although, I have some vibration problems with 3gx, but only when I lend. So if you fly bigger helis, 3gx is not a bad unit, but get beastx. If you fly smaller, get beastx. cheers.
emil_dimitrijevic is offline        Reply With Quote Quick reply to this message
Old 03-20-2012, 03:24 AM   #12 (permalink)
beastx ?
thanks
Bob
I confess having only used 3G and SK720, but if you want STABILITY the SK720 will fly like a coaxial, or a demon, depending on the settings. I fly gentle scale type and have SK720s on my 450 and 500. I leave the self leveling on all the time, but you can turn down the %age. I don't think any system "drops right in", but you can download the SK manual and see if it looks readable, and there's great help over on the Skookum robotics forum.
Nelson NZ
npomeroy is offline        Reply With Quote Quick reply to this message
Old 03-22-2012, 08:30 AM   #13 (permalink)
I have a beastx and a tarot zyx and both are good units. Beastx is definitely better and easier to setup but if your on a budget you can't beat the tarot for the price and if you spend the 5$ for the pc cable it's super easy to setup by way of laptop or computer
Mike Martin, MSH BRAIN USA Team Manager
MSH USA FLIGHT TEAM,
CYCLONE BLADES, XNOVA MOTORS,
JETI USA
www.MSHUSA.com, www.MSheli.com
mamartin is offline        Reply With Quote Quick reply to this message
Old 03-29-2012, 01:11 AM   #14 (permalink)
Tarot ZYX is only 1/3 of the BeastX $$, it is big different. Does it really perform close enough? I'm planning to upgrade a new head, not sure if a good idea to go for FBL or just go for a new head?
autosonline2002 is offline        Reply With Quote Quick reply to this message
Old 03-29-2012, 02:03 AM   #15 (permalink)
I tried to set up a MicroBeast and I found it annoying to use the LED's
and the sticks on my transmitter. I did finish the setup, but didn't get to fly it.
In the end I bought a second hand VBar and I like the fact, that I can use
my PC to set it up. I can go both forwards and backwards in the procedure.
With the BeastX I can't go backwards.
I have flown my 500 with the VBar only two times, and it worked very well.
I never got to fly the MicroBeast. But it's very popular here and I have reason
to believe it performs on the same level as the VBar.
For me the real issue was personal - ease of programming. I haven't considered
any cheaper alternatives.
Cheers
Erik
Beam600, 6203SB, 4025-630, ICE2HV80, Black VBar, Ino-Lab750, Savöx 1290MG
Goblin 500, Quantum motor, BK mini servos, HobbyWing 100A v3, Fut. 6203SB, Vortex Vx1e.
oy2503 is offline        Reply With Quote Quick reply to this message
Old 04-01-2012, 02:44 PM   #16 (permalink)
I have two CopterX units and one BeastX. The CopterX units work fine and are a great bang for your buck. If you just want to get your feet wet with FBL to see what it is like you can't really go wrong with the 3X1000 or the ZYX. But the BeastX is in another league, especially with the V3 firmware. The tail in particular is much better than the CopterX.
Lloyd Robinson
Fusion 550, Protos 500, Blade 400, Simple T-copter
fishboy77 is offline        Reply With Quote Quick reply to this message
Old 04-01-2012, 08:26 PM   #17 (permalink)
I have the zyx setup. I had difficulty with the setup but only because I was WAY over thinking things. I used the PC link and now that I know not to over analyze things I can have it setup in no time flat. 10 minutes easy and 20 tops! With the john_nz software you can't go wrong. HH is great, tail is solid as a rock and the heli "feels" like it has a lot of weight to it even though its a 450 if that makes since. A head and gyro can be had for under $90.
2003 SVT Cobra 538RWHP
2010 Corvette ZR1 all stock
Blade 450FBL, PRÔTOS 500CF FBL
My98stang46 is offline        Reply With Quote Quick reply to this message
