600 Class Electric Helicopters 600 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
11-18-2015, 07:30 AM | #1 (permalink) |
TREX 600CF FBL conversion with BeastX
I'm trying to get that elusive blue light on the BeastX for my TREX 600CF flybarless conversion. I'm using the non-DFC head. With the bell cranks the linkages on the servo wheels have to be at the outer holes (same distance from rotation axis) as on the bell cranks, so the linkages are parallel, to avoid binding/strain. But since the bell crank arm to the swash is about twice as long as the ones that connect to the servo this results ina lot of throw (the servo throw is doubled), which is too much to get a blue LED light.
I'm sure this exact type of conversion has been done a zillion times, so I hope someone out there can point me in the right direction. |
11-21-2015, 08:28 AM | #2 (permalink) |
If I understand you correctly you have your servo linkages setup something like this ...
This will not work for the BeastX setup. You'll need to relocate the servo linkage to something like this to get the proper geometry.
MSR x1 / mCPX x2 / 450 x4 / Chaos600 test bed / Chaos600 Air-Wolf / American WereWolf 800 / KFrame800/900/1000 / Assorted Fixed Wing JR9303 / JR9503 / Futaba10CHP |
