Old 07-14-2011, 05:17 AM   #1 (permalink)
Default How much pitch is everybody running?
I'm at 13.5 but thinking about stretching it to 14.5. How much pitch is everybody running at and what motor? BTW I'm on the stock 510mx.
kouasupra is offline        Reply With Quote Quick reply to this message
Old 07-14-2011, 07:08 AM   #2 (permalink)
I settled on +- 13 and 2250 HS. Running the 510kv motor, 693 blades and 5100 mAh packs. It stops and starts great and the tail behaves on 105mm blades.
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote Quick reply to this message
Old 07-14-2011, 08:36 AM   #3 (permalink)
15' pitch 5035 custom 478kv scrop 710mm RT SC 3D blades 2250hs
Wow Déjà vu
https://www.helifreak.com/showthread...ighlight=pitch
lol you asked it the exact same as last time to
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c
f22warzone is offline        Reply With Quote Quick reply to this message
Old 07-14-2011, 09:33 AM   #4 (permalink)
I'm pretty reserved with my setup, 11 to -11 and a HS of 1875 w/690 blades and a 700MX 510kv motor.
Train Fixer is offline        Reply With Quote Quick reply to this message
Old 07-14-2011, 10:25 AM   #5 (permalink)
1917 w/13T
710 Radix FBL
2150 HS
13.5 degrees
I have backed off a little to:
1917 w/12T
690 Radix FBL
2050 HS
14.0 degrees
This combo holds headspeed better than the one above did - I think at least partly due to pinion change. May actually have a little more pop too...
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 07-15-2011, 01:39 AM   #6 (permalink)
i dont know how much
actually i dont even have a pitch gauge LOL
invertsick is offline        Reply With Quote Quick reply to this message
Old 07-15-2011, 02:29 AM   #7 (permalink)
That's how you know that's dangerous! LOL
Old 07-15-2011, 04:59 AM   #8 (permalink)
I'm running like 15° and 713s... I wonder if that's the reason that my jive 80 is hitting cut-off lately with the summer high temps?....
Minicopter Diabolo 800+ - Minicopter Triabolo - Srimok FAIFA
Jeti DS-16
tribe3 is offline        Reply With Quote Quick reply to this message
Old 07-15-2011, 05:24 AM   #9 (permalink)
^^^ I would have to agree. 15 degrees of pitch is really unnecessary when using the larger blades or at all really. I would go down to at least 13. What is your headspeed?
raptorz499 is offline        Reply With Quote Quick reply to this message
Old 07-15-2011, 05:34 AM   #10 (permalink)
That would cause the jive to work harder. What is your headspeed anyways?
Old 07-15-2011, 06:25 AM   #11 (permalink)
I fly at 2050HS and occasionally switch to 2150.
I have to redo all my links methinks since to be at 13 I'm too low on the Vbar's settings
Jeti DS-16
Old 07-15-2011, 07:43 AM   #12 (permalink)
13* of pitch and about 8* on the cyclic at 2000 in idle up 2 box stock heli
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote Quick reply to this message
Old 07-15-2011, 09:21 PM   #13 (permalink)
+/-13 and no idea on Aileron and Elevator since I have a microbeast fbl controller. I have it in transmitter mode set at 105. I run 2150 in IU1 and 2200 in IU2 with 690 blades. Super fast and no bogging from start to finish.
I ran +/-14 for a while but found that I couldn't keep from climbing during tic tocs
Jim
Trex 250 ---- Trex 450 Pro ---- Trex550 FBL ---- Trex 700E FBL ---- Avant Aurora 90E ---- Goblin 700
Keep it off the Ground....but just barely
rctazz is offline        Reply With Quote Quick reply to this message
Old 07-16-2011, 06:02 AM   #14 (permalink)
It's the Vbar Cyclic that matters 80-100, think mine is @ 78.
The Collective does not matter if < 80
13 deg.
Does not really matter 13,14 if you don't push the sticks all the way,,
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
