Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Closed Thread
Old 08-07-2012, 09:46 AM   #1
kavic5150
Post hyperion (scorpion) 2221-1630 not dead?
I was doing some setup and accidentally reversed my throttle channel. Had to grab the rotor to prevent any indoor carnage and I saw and smelled smoke coming from the motor.
At the time I just assumed the motor was toast but today I hooked it up to a 3s ESC and it beeped normally, then spooled up just fine under no load. It ran for 30 seconds and did not heat up the motor. The 25a 3s esc was barely warm.
Did I just get lucky or what? How do I test to see if the motor is ok?
Hoss X4e 6s, Gaui 550, Protos 500 12s, Losi Speed-T.
Save the flybar !!
kavic5150 is offline
Closed Thread
