Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Like Tree7Likes
Old 12-01-2011, 03:13 PM   #41 (permalink)
I'll edit the 1st post to add the Spyder and update the other one. Do you have dimensions for that Spyder?
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
The Front Porch, Nexgens Lounge
nexgen is offline        Reply With Quote Quick reply to this message
Old 12-01-2011, 03:16 PM   #42 (permalink)
SpyderBatteries Black Widow 6S 4000mAh 30C LiPo
SpyderBatteries provide an unbeatable combination of price and performance; their low internal resistance and high cycle life ensure that you are getting maximum value from your battery.
While their C ratings may be 30-100% lower than other brands, you'll find that Spyder packs will regularly outperform their competitors' higher rated batteries. SpyderBatteries products are always advertised with their actual C ratings - compare their internal resistance values with other brands and you'll see the difference.
The 6S 4000mAh pack has a maximum discharge rate of 30C, while you can charge it at up to 5C to get back to action as fast as possible.
Applications
600 Helis
Specifications
Dimensions: 137x42x51mm
Weight:610g
Voltage: 22.2V
Maximum Continuous Discharge: 30C (120A)
Maximum Charge Rate: 5C
Cell IR: 2.8 milliohms
Pack IR: 25 milliohms
Main Charge Lead: T-Plug connector, 12 AWG wire
Balance Lead: JST-XH connector, 24 AWG wire
Warranty: 60 days
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 12-01-2011, 04:14 PM   #43 (permalink)
Spyder 5300 30C (very underrated compared to batts rated 2x) which works best for my COG
Dimensions: 135x62x42mm
Weight: 716g
Spyder 4000 30C
Weight:610g
No battery fence on my x5 so someone else might be able to confirm that
whippo is offline        Reply With Quote Quick reply to this message
Old 12-01-2011, 04:42 PM   #44 (permalink)
Weight: 716g
What are your flying times on those?
Jack2010 is offline        Reply With Quote Quick reply to this message
Old 12-07-2011, 11:14 AM   #45 (permalink)
great info, thank you!
- Dan G. -
Former person of medium importance:
Team Lynx Heli Innovations, Hirobo USA Product Specialist, Revolectrix Ambassador, writer at RC Heli Magazine, Fly RC, Model Airplane News, RC Heli Pilot Magazine
darkfa8 is offline        Reply With Quote Quick reply to this message
Old 12-08-2011, 09:02 PM   #46 (permalink)
added the Spydre batts to the top, and moved the Kypom to the confirmed. Any others, poste em up.
Old 12-24-2011, 03:58 AM   #47 (permalink)
No 3d... 7m20s min put 61% back in
On the 4k packs I put 73% back on 7m20s
________________
Naked & Afraid
Old 01-13-2012, 11:58 PM   #48 (permalink)
I can confirm that the Turnigy 4000mAh 40C lipo's fit. You need to place them side-on. Despite what the HK website says, they are no longer than the 30C, but are slightly wider, heavier, and have 8AWG leads. Balance of my X5 is good with it installed.
I don't have the battery fence, so I can't comment on that.
Harrow is offline        Reply With Quote Quick reply to this message
Old 02-06-2012, 12:50 AM   #49 (permalink)
Some body try this battery Turnigy nano-tech 3850mah 6S 65~130C Lipo Pack?
Weight: 662g (including wire, plug & case)
Dimensions: 136 x 44 x 55mm
megalis is offline        Reply With Quote Quick reply to this message
Old 02-07-2012, 02:44 PM   #50 (permalink)
Default Chrome 3700 45C
I've ordered some Chrome Packs for my X5. Should fit just fine comparing the dims to my present Hyperions (4200 45C). Here's the details -
CRC45-3700 Chrome 6s1p 3700 mAh 45C Lipo Pack
6s1p 3700 mAh 45C Lithium battery
Capacity: 3700mAh
Pack Configuration: 6S1P
Continuous Discharge Rate: 45C
5C Charge rate
Dimensions: 50mm X 43mm X 136mm
Pack Weight: 595 grams
Deans compatible "T" style Output connector
JST XH (E-flight compatible)
Rob Davis
X5 / Ikon
T-Rex / YS50
onemetre is offline        Reply With Quote Quick reply to this message
Old 02-09-2012, 03:42 AM   #51 (permalink)
Capacity: 3700mAh
5C Charge rate
Can you please post back what you think of them. I started to order a couple of them a couple months back but I have a hard time convincing myself to use my baby as a guenea pig on a new brand
Mike Martin, MSH BRAIN USA Team Manager
MSH USA FLIGHT TEAM,
CYCLONE BLADES, XNOVA MOTORS,
JETI USA
www.MSHUSA.com, www.MSheli.com
mamartin is offline        Reply With Quote Quick reply to this message
Old 02-09-2012, 04:09 PM   #52 (permalink)
Winmax 4200mah 6S 30C-60C nano-platinum
Weight: 653g (COG good)
8C charge
Dimensions: 135mm x 44mm x 53mm
Internal resistance cold, less than 4 per cell (iCharger 208)
Good fit even with the battery settle kit.
I've also had a good run with Winmax batteries in my 450 helis (2200mah 3S 50C). Just received some 2650mah 6S 30C for the 500s.
Gaui X2 FES ZYX, Gaui X3 MB, Gaui X4 II VBar, Gaui X5 FES MB
250 DFC ZYX, 450 DFC Sport MB, ALZRC 450L Pro VBar, Devil 450 FAST VCTRC FBL
500E DFC Pro VBar, 500E SDC ZYX-S
KDS 550 VBar, 550E DHPS VBar, 550E DFC Pro VBar, 700E DFC HV iKon
Last edited by beenflying; 02-10-2012 at 04:06 PM.. Reason: Added the measured dimensions
beenflying is offline        Reply With Quote Quick reply to this message
Old 02-09-2012, 08:17 PM   #53 (permalink)
Well, I got them and they aren't 135mm but 150mm. I'm not thinking I'm going to keep them.
Rob
Rob Davis
X5 / Ikon
T-Rex / YS50
Old 02-10-2012, 03:34 PM   #54 (permalink)
Rob
Oooh, that's tight. I have some 146mm Turnigys and they are a snug fit.
Old 02-10-2012, 04:08 PM   #55 (permalink)
8C charge
Added the measured dimensions.
Old 02-10-2012, 05:42 PM   #56 (permalink)
Yeah, I got the RMA today to send the Chrome packs back. Going to try the Spyder packs. Spoke to David at Progressive to be sure the dims are real.
Rob Davis
X5 / Ikon
T-Rex / YS50
Old 02-13-2012, 12:41 AM   #57 (permalink)
Default Can I use Turnigy XT60 plugs?
I've got a bunch of XT60 plugs. Are they up to the task for this X5?
Soldering up the ESC and batteries now.
CD
fstclyz is offline        Reply With Quote Quick reply to this message
Old 02-13-2012, 02:29 AM   #58 (permalink)
CD
I'm using them and they seem fine. They seem to be getting maybe about 5 degrees warmer than ambient temperature during a flight. Or to put it another way, I can only just tell that they have warmed slightly when I feel them after a flight. I'm not flying hard 3D, just simple aerobatics, gentle flips, big loops, etc. Might be a different story if you are running 2600rpm and smacking it around.
Old 02-13-2012, 02:52 AM   #59 (permalink)
CD
I use XT60's but I switched to these EC5's for my X5:
http://www.hobbyking.com/hobbyking/s...idProduct=9194
http://www.hobbyking.com/hobbyking/s...dProduct=17664
Old 02-13-2012, 05:06 AM   #60 (permalink)
*** Update ***
The Turnigy 4000mAh 40-50C lipos do fit with the battery fence installed. They are snug, but they fit.
