Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 07-06-2012, 05:47 AM   #81 (permalink)
Let's see some smack flying! how much pitch does the tail seem to hold?
honey bee king II
andersn is offline        Reply With Quote Quick reply to this message
Old 07-06-2012, 06:51 AM   #82 (permalink)
SWEET CANOPY!!!
crashingrc is offline        Reply With Quote Quick reply to this message
Old 07-06-2012, 07:40 AM   #83 (permalink)
I'm keen to hear how that Turnigy motor is performing for you.
SAB Goblin 700 - CCHV120 - BEC Pro - AR7200BX - TM1000 / 450 Pro - GT5 - Tarot head / T-Rex 550 V2.1 - CC100 - BEC Pro - AR7200BX - TM1000 /
1004ron is offline        Reply With Quote Quick reply to this message
Old 07-06-2012, 07:45 AM   #84 (permalink)
A clubmate of mine has been flying that same motor in his Trex 550 for over a year now with excellent results. And I have the 880kv version of it in my Fusion 50 on 8S, and it has performed very well for me. If I build one of these HK550s that would be the motor I'd use!
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 07-07-2012, 05:42 PM   #85 (permalink)
Darn it! Another interesting kit to mess around with! Have the power system laying around (1100KV Turnigy motor / CC 100 ICE), S9254, BEC & receiver....
So...other than the main gear and head, what have you changed to make it flyable? I started with an EXI 500 couple of years ago and changed all shafts, gears & swashplate to bring it to standards...
Looking forward to a bit more "aggresive" sports flying report!!
AMA #976001
HELIS: TREX 500 (6s), Trex 600 ESP (12S) & Trex 550 (12S): ALL FBL
PLANKS: Hangar 9 Pulse 60, Alpha 40 & Great Planes Revolver
nieves50 is offline        Reply With Quote Quick reply to this message
Old 07-08-2012, 10:28 AM   #86 (permalink)
I tool my heli apart to replace the Gear and found that the tail shaft bearing blew out. UGH! Im going to see if my 600 TT tail bearings are the same.
Old 07-08-2012, 01:54 PM   #87 (permalink)
Sorry to hear that crashingrc...hopefully the 600 has the same bearings!
Blade 450 FBL, Trex 550 FBL
cdbarnett is offline        Reply With Quote Quick reply to this message
Old 07-08-2012, 02:04 PM   #88 (permalink)
Ok, got my build done yesterday. Really impressed with the heli. The build went failry smooth and wiring is pretty clean. First spool up was perfect. Hoping to get to the field today!
Only things I replaced, were the main gear, the head, CF tail control rod and skids (like the lower stance of the F3C).
ID:	330269   Click image for larger version
ID:	330270   Click image for larger version
ID:	330271   Click image for larger version
ID:	330272   Click image for larger version
ID:	330274   Click image for larger version
Old 07-08-2012, 02:58 PM   #89 (permalink)
Thank you. Yup! There the same.
Nice build!
Old 07-08-2012, 06:26 PM   #90 (permalink)
Cool
I had my first flight at the field today. I really didn't want to push it too hard on the first flight, so I did a nice short flight. The flight could not have gone better. Now I have to pull the flight logs, and check my amp draw, and temps. Also want to go over the entire airframe to make sure everything is ok and nothing came loose before my next flight. Here's the video:
[ame]http://m.youtube.com/watch?v=Ut1NfErMmkY[/ame]
cbarnettone is offline        Reply With Quote Quick reply to this message
Old 07-08-2012, 06:37 PM   #91 (permalink)
Ha! I'd have to learn how to fly smack first! I'm running +\- 13 on the collective, and the tail is holding great!
Old 07-08-2012, 06:40 PM   #92 (permalink)
So far so good on the motor! The first flight went great, and it seemed to have a ton of power! I didn't notice the motor bogging at all, but I didn't push it much. I'll push a little harder next time out.
Old 07-08-2012, 06:45 PM   #93 (permalink)
Really only "needed" to replace the main gear since it was so warped. I only replaced the head because I wanted go flybarless. The flybarred head looks really nice though. The tail is really solid and smooth. Now we just have to wait and see how things hold up!
Old 07-08-2012, 07:59 PM   #94 (permalink)
Nice flying 'bro!
I was not able to get to the field today...hopefully tomorrow!
Old 07-25-2012, 10:23 PM   #95 (permalink)
Snuck out to the field to get in another flight... even though it was VERY windy! Still loving this heli though...
[ame]http://www.youtube.com/watch?v=JIxqIjcDJfA[/ame]
Old 07-25-2012, 10:34 PM   #96 (permalink)
I just pulled my flight log from today’s flight. My charger says that I put 3070 mA back in the pack even though the Castle logging says that I consumed 2450 mA. Not sure what is going on there, but I think the charger’s data has to be more accurate, so I’ll use its data.
I’m running 4500 packs, and I only want to consume 80% (3600 mA), so that is what I’ll use for the calculations below.
Today’s Flight:
- 440 seconds (7.33 minutes)
- 3070 mAh consumed
- 418 mAh / Min
- 1950 RPM Headspeed
Based on the above, I should be able to safely fly for 8.6 minutes (3600 / 418) @ 1950 RPM. This setup seems to be very efficient!!
Old 07-26-2012, 08:34 AM   #97 (permalink)
my guess is that your charger did put in more 'mah', but some of it was cooked off balancing the cells.
texasclouds is offline        Reply With Quote Quick reply to this message
Old 07-26-2012, 09:48 AM   #98 (permalink)
The sustained flat spot on the power out, along with the drop in head speed is an indicator that your packs aren't up to the job near the end of the flight. I'm curious what the ripple was at that point.
Learning to walk was so much easier than learning to fly.
Hoosiermo1 is offline        Reply With Quote Quick reply to this message
Old 07-26-2012, 07:25 PM   #99 (permalink)
Ahh... Well, that makes a lot of sense! I'll test the theory when I charge tonight. I'll just do a straight charge rather then a balance charge to see if the numbers between the charger and the flight log match better.
Old 07-26-2012, 07:29 PM   #100 (permalink)
Yeah... I'm running Turnigy Nano-techs. They are supposed to be 35-75c, but they consistently come down hot (not warm). So, I think they are really overstating the C rating. Going to try my brother's Zippy 45c packs this weekend to see how they compare. They are coming down at ambient temperature on his machine.
