Old 04-13-2014, 01:48 PM   #1 (permalink)
Default Trex 450 shudder????
Hi All,
I had a crash with my trex 450 and had to replace main shaft and main blades now I have fitted the new parts when I spool up it has a slight shudder but then when head speed goes up to hovering all is fine and stable but if I push forward and back fast on the cyclic ( like a fast snap forward and back) the heli has a shudder for a quick moment then gets back to steady hover???? it is the 450 pro fbl with 3gx.. any ideas where to start looking for the problem? cheers peeps
Dx7S T rex 450l Dominator x2 - T rex 500l Dominator - T rex 550l Dominator - Radian Pro - Radian Eflite Inverza
Lee777 is offline        Reply With Quote Quick reply to this message
Old 04-13-2014, 01:50 PM   #2 (permalink)
Loose links/parts then bearings
r/c helis lifestyle
HeliSmith is offline        Reply With Quote Quick reply to this message
Old 04-13-2014, 01:58 PM   #3 (permalink)
All seems tight with no slop
Old 04-13-2014, 02:52 PM   #4 (permalink)
Is it possible the tape got knocked loose? Checking bearings make sure you test side load
r/c helis lifestyle
Old 04-13-2014, 03:06 PM   #5 (permalink)
what tape????? the 3gx foam tape??
Old 04-13-2014, 03:08 PM   #6 (permalink)
For the 3GX
r/c helis lifestyle
Old 04-13-2014, 03:20 PM   #7 (permalink)
No the 3gx is in the body of the pro and just checked and it is solid....
Old 04-14-2014, 06:47 AM   #8 (permalink)
I am not an expert but in my experience, when replacing a main shaft I have found the bearing in the upper bearing block to be damaged and/ or gritty necessitating replacement.
Definitely look for and find the cause of your problem to prevent failure or damage.
Vibrations like you describe are typically mechanical in origin.
Check your main rotor tightness. Maybe too loose?
Make sure your cyclic servos are running smooth. Maybe the elevator servo or the others lost a tooth.
Thorr
Trex 550E DFC V3, Trex 450 Pro V2, Trex 450 Sport V2 DFC
Blade 130X, MCPX V2.
AR7200BX FBL. DX6i
Victor Kovalev is offline        Reply With Quote Quick reply to this message
Old 04-14-2014, 08:43 AM   #9 (permalink)
feathering shaft bent?
mcx/msr/mcpx/trex 550e super combo/600esp dfc conv ama#1037612
kheinink is offline        Reply With Quote Quick reply to this message
Old 04-14-2014, 09:17 AM   #10 (permalink)
Default shakes
This could be any number of things...if all is tight and and gyro secure with no slop to be detected then maybe a gyro gain adjustment is in order.
Sometimes new parts like bearings and what have u may make for a smoother drivetrain and so gains would need to be dialed down some....just an option
Another is the motor pinion...ive had a motor pinion have just a tiny bit of back and forth play....almost unoticeable...and of course with the slight change in head load it would shudder...
Good luck with the duagnostic...keep us posted.
cafediablo_30 is offline        Reply With Quote Quick reply to this message
Old 04-14-2014, 06:14 PM   #11 (permalink)
Feathering shaft, bent torque tube, bad bearing, damaged tt gears....
Did you spool it up without blades on to check for vibes?
CrashNburn420 is offline        Reply With Quote Quick reply to this message
Old 04-15-2014, 05:48 AM   #12 (permalink)
How tight are your main blades in the grips. Dfc doesn't like to loose of blades. Mine was doing the same thing on spin up. It would just start shacking at 3/4 speed before lift off. Tightened the blades a little and it all went away. I never flew it this way before it tightened them. But it flew fine after I tightened them. Know has 35 flights on it and that was all I did to correct it. Just something else to check maybe. Hope this helps.
jazsop is offline        Reply With Quote Quick reply to this message
Old 04-20-2014, 09:34 AM   #13 (permalink)
Lee did you get this resolved? Never heard back from you on the PM so I keep watching this thread
r/c helis lifestyle
Old 04-26-2014, 10:55 AM   #14 (permalink)
My 450 DFC Pro had a similar issue after maybe 15 -20 flights.
It would shudder every now and then especially in hover. It turned out to be worn main bearings. I had the same thing happen with my 500 DFC Pro. With the 500 I replaced the stock bearing blocks with KDE thruster bearing blocks and that solved the problem permanently.
Sadly KDE doesn't have thruster bearings for the 450.
Align: Trex 550 Pro DFC, Trex 500 Pro DFC, Trex 450 Pro DFC, Trex 250 Pro DFC, Trex 150 DFC, Blade: CX2, mSR X, 120 SR, Nano QX, 300X. Spektrum: DX6i, DX8, DX9
DWill is offline        Reply With Quote Quick reply to this message
Old 05-13-2014, 03:50 PM   #15 (permalink)
Hi Lads,
replaced feathering shaft and the wobble on spool up calmed a lot, but still has a really bad few second shudder in steady hover about every 40 seconds, gonna try the bearings next in the blocks and see if that solves it, the tail isn't holding very well either
Old 05-13-2014, 04:40 PM   #16 (permalink)
I had a shudder on my 450 when I had the stock BL450M, 3500 KV motor. It would shudder around zero pitch and quit as soon as I gave it a little pitch.
After I swapped in a scorpion motor and castle lite ESC, the shutter went away. That was the only thing changed on the setup. Don't know why but the shutter quit.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Tasteles is offline        Reply With Quote Quick reply to this message
Old 05-13-2014, 04:42 PM   #17 (permalink)
Will be interested to see what it is , I had a shake / shudder on my 450 I searched everything , and replaced loads , still get it now and the but turning the gain down stopped it
Dx9, Blade Nano ,Trex 450pro ,Trex 550L , Trex 700
aevans692 is offline        Reply With Quote Quick reply to this message
Old 05-13-2014, 07:55 PM   #18 (permalink)
I am unsure what you mean by "shudder". Is it a violent shake that seems to suggest balance issues, or could it be electronically induced? It would seem if it becomes stable in hover and only unstable after specific maneuvers, that it is gyro related. Cyclic wobble is supposedly a symptom of too high aileron/elevator gain on the 3GX (the two pots on the unit).
Sefrez is offline        Reply With Quote Quick reply to this message
Old 05-13-2014, 10:33 PM   #19 (permalink)
In my case when mine was doing it, the shutter was kinda like blade flutter. The heli didn't shake or anything, it just gave off a fluttering sound. Changing to different kind of dampers did nothing. Gain settings on my beastx did nothing.
I upgraded my motor and esc just because I got a good deal on both. I was wanting the logging and governor capabiltties of the castle so since I got the deal, I changed out both. Never had the flutter again after that.
