Old 05-14-2012, 11:57 PM   #141 (permalink)
Is anybody just tapping into the wire harness that leads from the power switch board to the main board?
The wires are labeled on both boards. It seems like it would be easier to simply splice into the 2 wires (gnd and pwr) than to solder onto the board. I feel safer splicing wires into a jumper that is easily replaceable than taking the chance of messing up a board. I have OK skills with the soldering pencil but any board solders still look a bit rough.
You could use the original HK harness after cutting all but #2 and 3 ,to allow for disconnect.
Think I will try this tomorrow if I don't hear any reasons not to. Will post pictures unless disaster strikes.
Thanks to all for the great info here.
Jason
jwright1 is offline        Reply With Quote Quick reply to this message
Old 05-15-2012, 02:05 AM   #142 (permalink)
I'll try to help here with whatever knowledge of limitation I have..lol
@jwright1
The tute followed the original which tapped from the board. But I'm sure you could even tap from the small connection that carries the power from the battery holder. The 2 wires are the power wires so as long as you can get power to them, it'll still work. I'm sure you can solder to a spliced wire from the battery compartment.
@born ready
Is the ribbon cable that connects the LCD display put in straight and fits snugly? As the tute mentions, be careful with that thin brown ribbon cable. Did you get any kinks in it or scraped the copper on it? Unscrew the cover and wiggle that ribbon in again to ensure you have it all the way in together with the little plastic clip that shoves into the connector as well.
As for the covering, if your refering to the thin plastic sheet that protects the panel itself, then thats no prob as it's a mere protective cover. You could even use a CellPhone display cover and stick on to replace that. When lining up the LED panel to the LCD screen try to stick them along the sides rather than in between. That way nothing moves or gets slanted when you squash them back together. If you have thin acetate plastic sheet you could cut that to size and use that as a covering. Another option is to use Dbl-sided tape but the thin type for paper work, and cut thin narrow strips applying them to the side edges of the LED panel. That way it will also stick to the LCD screen like a sandwich with no space penalty. You won't see the tape as the is a border covering the outside edges of the internal display when you screw the TX covers back.
As for the extra 5pin socket....hmmm I don't think there should be one!! Have a look at the tute pics and see if everything matches. Which empty socket issit? Could it be the roller selector connector?
Anyone else have any suggestions, please feel free to add on!!
ScratchBuild Fomies(Too many have come and gone!)-Quadcopter-Little UMX planes!
timatworksg is offline        Reply With Quote Quick reply to this message
Old 05-15-2012, 10:15 AM   #143 (permalink)
I don't believe there is suppose to be an open socket inside. And as far as the plastic protective covering, i pealed mine off and it works great !
It may even be a little brighter and then again, it maybe just me thinking it is.....lol, but you do have to be very careful or you will scratch the LCD screen.
Like you timatworksg, i think it is probably the ribbon cable or whatever the open socket might be.
Could you take a picture of the inside so we can all get a look at the open socket you speak of and we may also get a look at what may be causing your problem that way.
BigRHS is offline        Reply With Quote Quick reply to this message
Old 05-15-2012, 08:36 PM   #144 (permalink)
Did that mod tonight and just love it!!!
Thank you timatworksg!!!
Hobbyking Yak-54 with SuperTiger .10 - Parkzone Extra 300 - SkyAngel F-16 and F-18 EDF 50mm - Blade 400
BlackBeast is offline        Reply With Quote Quick reply to this message
Old 05-16-2012, 08:51 PM   #145 (permalink)
Got my blue backlight today from HK. Went step by step and did not have any problems. I did do something different tho. I unloaded the unused wires from the connector instead of cutting off then wrapped with heat shrink to protect connector just like it came in package. A little off to one side but other than that love it. Going to do my dads next in green. Here is a pic of mine completed.
A BIG thanks to timatworksg for this awesome write up!!
Blade 450 3D, Blade 120SR, Blade MQX, Blade MCX2, Blade Scout, Heli-Max 1sq Quad, Griffin Heli, Traxxas QR-1, DX6I DSMX w/ blue backlighting.
Mini Tmaxx is offline        Reply With Quote Quick reply to this message
Old 05-16-2012, 09:01 PM   #146 (permalink)
Originally Posted by born ready View Post
Hi All,
Well, I hate to be a spoil sport, but, after the mod, I have a display only now and then. The back lite panel stays lit, but the display is intermittent. Display comes on and stays on for a moment if I tap on the bottom of the case.
I have an empty 5 pin socket on the main board. Is that normal?
Thanks,
Also...I applied the two sided tape to the covering of the led panel. Of course the display and all shifted, making the display off center. The obvious solution is to remove the cover and tape directly to the panel. Is there a problem doing that? Most folks say that they don't remove any thing.
I'm looking forward to your help.
BR
I too noticed a extra slot open on board when I took it apart. If you look close to that empty socket there is some initials next to it signifying what is used for. I can't remember off hand what mine said. Sorry. I will look at my dads when I do his and repost what it says. It might be used on a different model and not used on the dx6I.
Old 05-17-2012, 07:07 AM   #147 (permalink)
Thumbs up
Thanks a lot Timatworksg, that mod has been a walk in a park because of you. Very helpful tutorial.
xavure is offline        Reply With Quote Quick reply to this message
Old 05-18-2012, 09:14 PM   #148 (permalink)
Default Always on
Thanks for the write up. Everything went well (as far as I can tell) except my backlight is always on. Did I get something crossed somewhere?
Thanks.
jktravis is offline        Reply With Quote Quick reply to this message
Old 05-18-2012, 09:37 PM   #149 (permalink)
I found the problem with the light always being on. I accidentally soldered the wrong connection. I'm lucky I didn't really mess anything up. Thanks again for the write up!
Old 05-18-2012, 11:18 PM   #150 (permalink)
My dads after the green backlight on left. Mine after the blue backlight on right.
Old 05-19-2012, 07:22 AM   #151 (permalink)
Default A million and one 'your welcome's"
To all backlight modders, your most welcome!
I'm glad everything worked out as explained, even with some hiccups, it all ended up the way it's supposed to!
@jktravis
Glad you sorted it all out! LOL! Good thing nothing went 'blip!'..eek!
Could've doubled up as a night light though...lol!
@Mini Tmaxx, xavure, BlackBeast
Your welcome! I'm sure the LED makes the DX6i suddenly worth a little more since the day you paid for it...!
Old 05-28-2012, 04:42 AM   #152 (permalink)
Just finished mine thanks op
Sent from my iPad3 using Tapatalk HD
Name:	ImageUploadedByTapatalk HD1338198032.186275.jpg
E-Flite Blade 450x
DanXbix is offline        Reply With Quote Quick reply to this message
Old 05-31-2012, 10:56 PM   #153 (permalink)
Awesome job OP! Thanks!
MESummersII is offline        Reply With Quote Quick reply to this message
Old 06-06-2012, 01:13 PM   #154 (permalink)
Completed two back light mods last weekend. One blue for my buddy and mine in green. I LOVE the green! Thanks for the tutorial.
I found a circuit to turn off the backlight on a timer but honestly the circuit takes more power than leaving the backlight on so I didn't do it. I don't notice any battery drain from it.
Sent from my DROID3 using Tapatalk
DX6i (with back light), Mini Titan E325 V1 converted FBL w/ SK-720, Mini Titan V1 converted FBL w/ ZYX-S, mCPx V2 converted BL with HK parts, Phoenix
CopterGuy is offline        Reply With Quote Quick reply to this message
Old 06-06-2012, 09:32 PM   #155 (permalink)
Just finished mine with blue, LOOKS GREAT! Thanks OP.
Ken
Sigma, MCX, MSR, BOL, B400
BSR, EXI 450 Pro FBL, mCPX
Align 500ESP FBL
AXN FPV
Daddy is offline        Reply With Quote Quick reply to this message
Old 06-07-2012, 02:01 AM   #156 (permalink)
Great write up, just ordered a blue backlight for mine.
tbone77 is offline        Reply With Quote Quick reply to this message
Old 06-09-2012, 12:12 AM   #157 (permalink)
kml.krk is offline        Reply With Quote Quick reply to this message
Old 06-10-2012, 07:21 PM   #158 (permalink)
Had the backlight kit for a while now but not game to try it until I read your tutorial.
Worked like a charm, and now I can finally see my screen in low light.
Thanks for taking the time.
ingleburn is offline        Reply With Quote Quick reply to this message
Old 06-13-2012, 11:33 AM   #159 (permalink)
timatworksg: Thanks for the info on how to add the backlight; makes a good radio great ! ! ! My tweaks were filing down the high solder joints on the board where the 3M Super Strength Molding Tape (Item 03609) attaches to try to get the board/backlight screen to sit as low as possible; I put the 2 lower board screws in all the way, and left the upper 2 board screws about 1 1/2 turns short of tight because I could detect board flexing..... also found the perfect on/off switch for backlight power, (mounted on top) at RadioShack, part # 275-0624, finger tight on the nut that holds it in... photos enclosed. Thanks
Name:	Dx6i Backlight Project 005.JPG
ID:	324212   Click image for larger version
Name:	Dx6i Backlight Project 008.JPG
Airscrew is offline        Reply With Quote Quick reply to this message
Old 06-15-2012, 12:38 AM   #160 (permalink)
Hi All,
I have
a couple of back light kits that I don't need.
A blue and a green.
$10 bucks shipped...USPS Priority Mail.
Please PM if you're interested.
Thanks,
born ready is offline        Reply With Quote Quick reply to this message
