Castle Creations ESC and Software Castle Creations ESC Software and Hardware Support |
03-24-2016, 09:53 PM | #1 (permalink) |
Talon 90 setup help
I want to setup flat throttle curve like 70% on IU1 & 90% on IU2. So do i use governor mode or fixed endpoints on Talon 90 menu.
03-24-2016, 10:26 PM | #2 (permalink) |
You can do either. Fixed endpoints with a flat throttle curve is easy to setup, yet understand that as the battery voltage drops during flight, the headspeed also drops; therefore 70% headspeed/rpm at the beginning of the flight will be greater than that same 70% at the end of the flight. How much the headspeed drops off is dependent upon battery condition, flight time, etc.
Running gov mode isn't difficult to setup, and alleviates any rpm loss as your flight progresses; yet requires some fine-tuning and experimentation to get your heli dialed in for the rpm you want to fly. There are many happy flyers in each camp, so the choice is up to you.
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8 |
03-25-2016, 02:45 PM | #3 (permalink) |
Need some help. I soldered the bullets onto the motor leads but i cut the wires a little too short. I can get the bullets into the ESC but the wires are a little tight when plugged in. Will this be a problem & if so what is remedy other than buying another ESC or motor. ESC is a Talon 90.
03-28-2016, 10:00 PM | #4 (permalink) |
Castle creations recommends not plugging the motor wires directly into the esc as many motors have very rigid leads and will lead to vibration failure of solder joints in the esc. That being said you can buy some 5.5 mm male/ female connectors and make some extensions
http://www.castlecreations.com/blog/...d-talon-hv120/
Compass Chronos, Logo 550sx,Logo 400se Jeti Protos Max Leggero Evoluzione 800 |
03-29-2016, 05:26 PM | #5 (permalink) | |
04-01-2016, 07:05 PM | #6 (permalink) | |
