600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
07-02-2011, 11:34 PM | #41 (permalink) |
Ambient Temperature = 80F Avg: 115 Max: 145 Throttle Type Governor Mode Set RPM Governor Gain Medium (25) Initial Spool-Up Rate Medium (5)(*) Head Speed Change Rate High (8) Auto Rotate Enabled True Governor Mode Type Fixed Vehicle Setup - Battery Type LiPo Vehicle Setup - Number of Cells 12 Vehicle Setup - Battery Voltage 44.4000 Vehicle Setup - Gear Ratio 8.615 Vehicle Setup - Motor Kv 510 Vehicle Setup - Motor Number of Poles 10 Desired Head Speed 1 2008 Desired Head Speed 2 2106 Desired Head Speed 3 2204 Cutoff Voltage Auto Li-Po (Default) Auto-Lipo Volts/Cell 3.2 Volts/Cell (Default) Current Limiting Insensitive (180A) Cutoff Type Soft Cutoff Motor Start Power Medium (59) (Default) Motor Timing Low (0) Direction Forward (Default) PWM Rate 8 Khz
When the wife asks "How many helicopters do you need?" The answer is always "Just one more!" |
07-02-2011, 11:45 PM | #42 (permalink) | |
I started with Governor Gain Low (15), I'm no stick banger, and it bogged badly performing basic 3D maneuvers. I switched Gain to Medium 25, where all my other 3D and Scale Heli's are set, and the 600E is no longer bogging and flies fantastic.
07-03-2011, 02:30 AM | #43 (permalink) |
Anything above 11 for me I start to see tail artifacts and hear oscillations on the motor.
07-03-2011, 07:51 AM | #44 (permalink) |
Thank you for posting your graphs BT. I had to accept a Gov gain of about 7 or 8 on my 700E 3G due to anything higher would produce the dreaded tail kick. I was told by Castle more than once that excessive high gain can and eventually will wipe the teeth right off the main gear.. I have run as high as 15 and it seemed the tail did act a bit funny. . It looks as if your temps are in line with mine. 8PWM seems to be the sweet spot. I will probably re-visit the Gov gain again and increase to see what it yields.. To be honest, Ive been fixated on temps that I haven't noticed much else.
700N DFC 3GX OS91HZR 700E DFC IKON KDE XF700-505 CCHV160 600E PRO 3GX 450 PRO 3GX KDE BLING RAPTOR 90 3D OS91HZ 1ST HELICOPTER |
07-07-2011, 10:15 AM | #45 (permalink) |
I just logged a 5 min flight with 2350 for HS in idle 2. To my surprise, the ESC came down exceptionally cooler this time. I think the hottest it got was 105. It appears the higher the HS the more efficient. This was with 8 PWM low timing. Im satisfied with this as the final setting and feel a lot better about the ESC now. I will just spot check at the field for temps.
07-08-2011, 10:11 PM | #46 (permalink) |
Can someone define what should be considered the normal and high operating temperatures of the ESC?
David
T-Rex 700E Pro DFC, Spirit FBL Unit, Futaba R6303SB/8FGHS Blade mCPx 140mm boom, DX7 RealFlight 7 |
07-08-2011, 10:43 PM | #47 (permalink) |
According to Castle, the ESC doesn't start to shut down until the log shows 250F. In practice, temps above 170F are generally considered on the 'too high' side.
07-09-2011, 10:49 AM | #48 (permalink) | |
I was told by Castle not to be concerned as long as it hovered around 145 and not much higher. In looking at B TITANIUMS logs, it appears that that was a hard 3D flight. One thing as I said in my last post that the 2350+ HS was the cure with my current settings. I will prob not be pulling any more data logs unless it starts to rise . I don't feel it nec to continue to monitor the data after its dialed in. I now want to see if there is any tweeking in the 3GX program that I need to do. Time to research that thread. Happy Flying to all of you !!
07-10-2011, 10:38 PM | #49 (permalink) |
I just checked my logs, and my max temp hovering was 140. Outside air temp was 105. I'm like you, don't know what they are supposed to be for a max. My temps were with no canopy and mounted on the top of the block.
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550 Amain Hobbies Team Rep |
07-10-2011, 11:02 PM | #50 (permalink) |
Running 130 to 150 with 96*F ambient temps. This is with 8 gov gain, at 2100 HS 12khz pwm. The test flight for this was running full collective banked turns for a solid 5 minutes to push that motor. Temps with mild to medium 3D and general flying hover around 135 to 140 and sit there for the duration of the flight when ambient temps are 85 to 95*F. Stock gearing.
"You need more rockets. Everything is better with rockets" Mike Dipalo--Synergy RC, MKS Electronics |
08-28-2011, 02:59 PM | #51 (permalink) | |
08-30-2011, 09:03 PM | #52 (permalink) |
I think I will sit on my 80HV for the duration as opposed to sending it in to Castle. The logs are consistent after many flights. Maybe ,,,Just Maybe., I got a good one ? My HV 160 is still consistent on the 700 as well for over 2 years now. I will have to see the fire for myself I guess . I'll be dammed if I'll take another chance in getting a sub par replacement after waiting weeks with a downed Heli. I will wait to see how the replacements act for others. Any one else going to keep theirs?
